发表于 2011-11-30 10:00:49
显示全部楼层
前几天我也试验了一下,用的是28BYJ-48 Stepper Motor 12V+ULN2003APG
改了改一个代码,现在的效果是电位计控制正反转- /*
- This program drives a unipolar or bipolar stepper motor.
- The motor is attached to digital pins 8 - 11 of the Arduino.
- Created 11 Mar. 2007
- Modified 30 Nov. 2009
- by Tom Igoe
- #include <Stepper.h>
- const int stepsPerRevolution = 64; // change this to fit the number of steps per revolution for your motor
- // initialize the stepper library on pins 8 through 11:
- Stepper myStepper(stepsPerRevolution, 8,9,10,11);
- const int aInPin=A0;
- int val;
- void setup() {
- // set the speed at 60 rpm:
- myStepper.setSpeed(200);
- // initialize the serial port:
- Serial.begin(9600);
- void loop() {
- val=analogRead(aInPin);
- val=map(val,0,1023,0,99);
- Serial.println(val);
- // step one revolution in two direction:
- if(val>50){
- Serial.println("clockwise");
- //原library是整步,整步走的角度是半步走的角度的两倍,半步走的声音比较小,平稳些,启动时最好是半步的走比较稳定
- //022中library修改为半步模式不成功???FUCK
- //四拍运行时步距角为θ=360度/(revolution*4)(俗称整步),八拍运行时步距角为θ=360度/(revolution*8)(俗称半步)
- myStepper.step(stepsPerRevolution/2);//
- delay(500);
- else{
- // step one revolution in the other direction:
- Serial.println("counterclockwise");
- myStepper.step(-stepsPerRevolution/2);
- delay(500);
复制代码 |
