查看: 12419|回复: 2
有空的帮我看看。nrf2401
发表于 2014-7-24 11:24:25 | 显示全部楼层 |阅读模式
我的代码,双向通信。时好时坏,知道什么原因。
void RTX_Comm()
  digitalWrite(CE, 0);
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P2, RX_ADDRESS2, 1); // Use the same address on the RX device as the TX device
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P3, RX_ADDRESS3, 1); // Use the same address on the RX device as the TX device
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P4, RX_ADDRESS4, 1); // Use the same address on the RX device as the TX device
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P5, RX_ADDRESS5, 1); // Use the same address on the RX device as the TX device
  SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + RX_PW_P1, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + RX_PW_P2, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + RX_PW_P3, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + RX_PW_P4, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + RX_PW_P5, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
  SPI_RW_Reg(WRITE_REG + EN_AA, 0x3f);      // Enable Auto.Ackipe0 3f:543210 ack.
  SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x3f);  // Enable Pipe0 recive 3f 543210
  SPI_RW_Reg(WRITE_REG + RF_CH, 40);        // Select RF channel 40
  SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  //SPI_RW_Reg(WRITE_REG + DYNENABLE, 0x3f);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  //SPI_RW_Reg(WRITE_REG + DYNACK, 0x06);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a);//
  digitalWrite(CE, 1);                             // Set CE pin high to enable RX device
void RX_Mode()
    currMode = 0;
    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);     // Set PWR_UP bit, enable CRC(2 unsigned chars) & Prim:RX. RX_DR enabled..
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0,MyselfAddr, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P1, RX_ADDRESS1, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
    SPI_Write_Buf(WRITE_REG +TX_ADDR, MyselfAddr, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
  //  This device is now ready to receive one packet of 16 unsigned chars payload from a TX device sending to address
  //  '3443101001', with auto acknowledgment, retransmit count of 10, RF channel 40 and datarate = 2Mbps.
void TX_Mode(unsigned char num)//发射
    currMode = 1;
    digitalWrite(CE, 0);//
    SPI_Write_Buf(WRITE_REG+TX_ADDR,TransferAddr,5);//
    SPI_Write_Buf(WRITE_REG+RX_ADDR_P0,TransferAddr,5); //
    SPI_Write_Buf(WR_TX_PLOAD,tx_buf,num);
    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);    //
这样双向设置是可以的,有试过。
但是在转换收发模式时,有时好,有时坏。不知道什么原因?
是不是与时间有关??我打算修改一下延迟试试。
发表于 2017-3-16 10:12:05 | 显示全部楼层
有没有用库函数实现双向通信的,你这有点难啊?????
发表于 2018-8-18 23:35:12 | 显示全部楼层
谢谢分享,新手学习
GMT+8, 2024-3-29 23:21 , Processed in 0.040644 second(s), 19 queries .
