查看: 73533|回复: 31
RFID-RC522卡的读取问题
发表于 2014-8-10 18:27:37 | 显示全部楼层 |阅读模式
我用的是RFID-RC522,还有Arduino Uno开发板。
参照网上的连线,已经确定各个脚都没有连错,用电压表也确定有电压输出,但是把参考程序写进去后,读不出卡的信息,刚开始能读出,但是出来是unknow,后来就读不出来了,怎么接触都不行。
我在想会不会是卡坏了,还是什么其它原因,求有这方面的经验的人给点建议。
发表于 2014-8-10 23:21:09 | 显示全部楼层
[pre lang="arduino" line="1" file="RFID-RC522"]/*实现功能:刷卡,点亮和关闭接在数字pin3口的LED,此点灯熄灯代码为自己添加
接线:Arduino端            RC522端
         VCC----------------->3.3V
         GND----------------->GND
         D5----------------->RST
         D10----------------->SDA
         D11----------------->MOSI
         D12----------------->MISO
         D13----------------->SCK
时间:2014/6/10
修改作者:彬彬*/
#include <SPI.h>
#define uchar unsigned char
#define uint unsigned int
//data array maxium length
#define MAX_LEN 16
//set the pin
const int chipSelectPin = 10;
const int NRSTPD = 5;
//LED
int led=3;
char count=0;
//MF522 command bits
#define PCD_IDLE 0x00 //NO action; cancel current commands
#define PCD_AUTHENT 0x0E //verify password key
#define PCD_RECEIVE 0x08 //receive data
#define PCD_TRANSMIT 0x04 //send data
#define PCD_TRANSCEIVE 0x0C //send and receive data
#define PCD_RESETPHASE 0x0F //reset
#define PCD_CALCCRC 0x03 //CRC check and caculation
//Mifare_One card command bits
#define PICC_REQIDL 0x26 //Search the cards that not into sleep mode in the antenna area
#define PICC_REQALL 0x52 //Search all the cards in the antenna area
#define PICC_ANTICOLL 0x93 //prevent conflict
#define PICC_SElECTTAG 0x93 //select card
#define PICC_AUTHENT1A 0x60 //verify A password key
#define PICC_AUTHENT1B 0x61 //verify B password key
#define PICC_READ 0x30 //read
#define PICC_WRITE 0xA0 //write
#define PICC_DECREMENT 0xC0 //deduct value
#define PICC_INCREMENT 0xC1 //charge up value
#define PICC_RESTORE 0xC2 //Restore data into buffer
#define PICC_TRANSFER 0xB0 //Save data into buffer
#define PICC_HALT 0x50 //sleep mode
//THe mistake code that return when communicate with MF522
#define MI_OK 0
#define MI_NOTAGERR 1
#define MI_ERR 2
//------------------MFRC522 register ---------------
//Page 0:Command and Status
#define Reserved00 0x00
#define CommandReg 0x01
#define CommIEnReg 0x02
#define DivlEnReg 0x03
#define CommIrqReg 0x04
#define DivIrqReg 0x05
#define ErrorReg 0x06
#define Status1Reg 0x07
#define Status2Reg 0x08
#define FIFODataReg 0x09
#define FIFOLevelReg 0x0A
#define WaterLevelReg 0x0B
#define ControlReg 0x0C
#define BitFramingReg 0x0D
#define CollReg 0x0E
#define Reserved01 0x0F
//Page 1:Command
#define Reserved10 0x10
#define ModeReg 0x11
#define TxModeReg 0x12
#define RxModeReg 0x13
#define TxControlReg 0x14
#define TxAutoReg 0x15
#define TxSelReg 0x16
#define RxSelReg 0x17
#define RxThresholdReg 0x18
#define DemodReg 0x19
#define Reserved11 0x1A
#define Reserved12 0x1B
#define MifareReg 0x1C
#define Reserved13 0x1D
#define Reserved14 0x1E
#define SerialSpeedReg 0x1F
//Page 2:CFG
#define Reserved20 0x20
#define CRCResultRegM 0x21
#define CRCResultRegL 0x22
#define Reserved21 0x23
#define ModWidthReg 0x24
#define Reserved22 0x25
#define RFCfgReg 0x26
#define GsNReg 0x27
#define CWGsPReg 0x28
#define ModGsPReg 0x29
#define TModeReg 0x2A
#define TPrescalerReg 0x2B
#define TReloadRegH 0x2C
#define TReloadRegL 0x2D
#define TCounterValueRegH 0x2E
#define TCounterValueRegL 0x2F
//Page 3:TestRegister
#define Reserved30 0x30
#define TestSel1Reg 0x31
#define TestSel2Reg 0x32
#define TestPinEnReg 0x33
#define TestPinValueReg 0x34
#define TestBusReg 0x35
#define AutoTestReg 0x36
#define VersionReg 0x37
#define AnalogTestReg 0x38
#define TestDAC1Reg 0x39
#define TestDAC2Reg 0x3A
#define TestADCReg 0x3B
#define Reserved31 0x3C
#define Reserved32 0x3D
#define Reserved33 0x3E
#define Reserved34 0x3F
//4 bytes Serial number of card, the 5 bytes is verfiy bytes
uchar serNum[5];
    Serial.begin(57600);
    SPI.begin();
    pinMode(chipSelectPin,OUTPUT); // Set digital pin 10 as OUTPUT to connect it to the RFID /ENABLE pin
    digitalWrite(chipSelectPin, LOW); // Activate the RFID reader
    pinMode(NRSTPD,OUTPUT); // Set digital pin 5 , Not Reset and Power-down
    pinMode(led,OUTPUT);//位于3脚的led灯
    digitalWrite(led,LOW);//led初始状态为熄灭
    MFRC522_Init();
    uchar status;
    uchar str[MAX_LEN];
    // Search card, return card types
    status = MFRC522_Request(PICC_REQIDL, str);
    if (status != MI_OK)
        return;
    // Show card type
    ShowCardType(str);
    //Prevent conflict, return the 4 bytes Serial number of the card
    status = MFRC522_Anticoll(str);
    // str[0..3]: serial number of the card
    // str[4]: XOR checksum of the SN.
    if (status == MI_OK)
        Serial.print("The card's number is: ");
        memcpy(serNum, str, 5);
        ShowCardID(serNum);
        // Check people associated with card ID
        //我个人的理解,这里相当于一个小型的数据库,用来验证IC卡的合法性
        uchar* id = serNum;
        if( id[0]==0xB4 && id[1]==0xDB && id[2]==0x97 && id[3]==0xDD ) {
            count++;//IC卡验证通过,加1,此段代码是自己修改的,可以实现通过IC卡来点灯和熄灯
            if(count%2!=0)
              Serial.println("Hello KuangBin!");
              digitalWrite(led,HIGH);//IC卡验证通过,点亮led
            if(count%2==0)
               Serial.println("Byebye KuangBin!");
               digitalWrite(led,LOW);//IC卡验证通过,点亮led
        } else if(id[0]==0x3B && id[1]==0xE6 && id[2]==0xD1 && id[3]==0x3B) {
            Serial.println("Hello Greg!");
        }else{
            Serial.println("Hello unkown guy!");
    MFRC522_Halt(); //command the card into sleep mode
    delay(200);
* Function:ShowCardID
* Description:Show Card ID
* Input parameter:ID string
* Return:Null
void ShowCardID(uchar *id)
    int IDlen=4;
    for(int i=0; i<IDlen; i++){
        Serial.print(0x0F & (id>>4), HEX);
        Serial.print(0x0F & id,HEX);
    Serial.println("");
* Function:ShowCardType
* Description:Show Card type
* Input parameter:Type string
* Return:Null
void ShowCardType(uchar* type)
    Serial.print("Card type: ");
    if(type[0]==0x04&&type[1]==0x00)
        Serial.println("MFOne-S50");
    else if(type[0]==0x02&&type[1]==0x00)
        Serial.println("MFOne-S70");
    else if(type[0]==0x44&&type[1]==0x00)
        Serial.println("MF-UltraLight");
    else if(type[0]==0x08&&type[1]==0x00)
        Serial.println("MF-Pro");
    else if(type[0]==0x44&&type[1]==0x03)
        Serial.println("MF Desire");
        Serial.println("Unknown");
* Function:Write_MFRC5200
* Description:write a byte data into one register of MR RC522
* Input parameter:addr--register address;val--the value that need to write in
* Return:Null
void Write_MFRC522(uchar addr, uchar val)
    //address format:0XXXXXX0
    SPI.transfer((addr<<1)&0x7E);
    SPI.transfer(val);
    digitalWrite(chipSelectPin, HIGH);
* Function:Read_MFRC522
* Description:read a byte data into one register of MR RC522
* Return:return the read value
uchar Read_MFRC522(uchar addr)
    uchar val;
    //address format:1XXXXXX0
    SPI.transfer(((addr<<1)&0x7E) | 0x80);
    val =SPI.transfer(0x00);
    return val;
* Function:SetBitMask
* Description:set RC522 register bit
* Input parameter:reg--register address;mask--value
* Return:null
void SetBitMask(uchar reg, uchar mask)
    uchar tmp;
    tmp = Read_MFRC522(reg);
    Write_MFRC522(reg, tmp | mask); // set bit mask
* Function:ClearBitMask
* Description:clear RC522 register bit
* Return:null
void ClearBitMask(uchar reg, uchar mask)
    uchar tmp;
    Write_MFRC522(reg, tmp & (~mask)); // clear bit mask
* Function:AntennaOn
* Description:Turn on antenna, every time turn on or shut down antenna need at least 1ms delay
* Input parameter:null
* Return:null
void AntennaOn(void)
    uchar temp;
    temp = Read_MFRC522(TxControlReg);
    if (!(temp & 0x03))
        SetBitMask(TxControlReg, 0x03);
* Function:AntennaOff
* Description:Turn off antenna, every time turn on or shut down antenna need at least 1ms delay
* Return:null
void AntennaOff(void)
    ClearBitMask(TxControlReg, 0x03);
* Function:ResetMFRC522
* Description: reset RC522
* Return:null
void MFRC522_Reset(void)
    Write_MFRC522(CommandReg, PCD_RESETPHASE);
* Function:InitMFRC522
* Description:initilize RC522
* Return:null
void MFRC522_Init(void)
    digitalWrite(NRSTPD,HIGH);
    MFRC522_Reset();
    //Timer: TPrescaler*TreloadVal/6.78MHz = 24ms
    Write_MFRC522(TModeReg, 0x8D); //Tauto=1; f(Timer) = 6.78MHz/TPreScaler
    Write_MFRC522(TPrescalerReg, 0x3E); //TModeReg[3..0] + TPrescalerReg
    Write_MFRC522(TReloadRegL, 30);
    Write_MFRC522(TReloadRegH, 0);
    Write_MFRC522(TxAutoReg, 0x40); //100%ASK
    Write_MFRC522(ModeReg, 0x3D); //CRC initilizate value 0x6363 ???
    //ClearBitMask(Status2Reg, 0x08); //MFCrypto1On=0
    //Write_MFRC522(RxSelReg, 0x86); //RxWait = RxSelReg[5..0]
    //Write_MFRC522(RFCfgReg, 0x7F); //RxGain = 48dB
    AntennaOn(); //turn on antenna
* Function:MFRC522_Request
* Description:Searching card, read card type
* Input parameter:reqMode--search methods,
* TagType--return card types
* 0x4400 = Mifare_UltraLight
* 0x0400 = Mifare_One(S50)
* 0x0200 = Mifare_One(S70)
* 0x0800 = Mifare_Pro(X)
* 0x4403 = Mifare_DESFire
* return:return MI_OK if successed
uchar MFRC522_Request(uchar reqMode, uchar *TagType)
    uchar status;
    uint backBits; //the data bits that received
    Write_MFRC522(BitFramingReg, 0x07); //TxLastBists = BitFramingReg[2..0] ???
    TagType[0] = reqMode;
    status = MFRC522_ToCard(PCD_TRANSCEIVE, TagType, 1, TagType, &backBits);
    if ((status != MI_OK) || (backBits != 0x10))
        status = MI_ERR;
    return status;
* Function:MFRC522_ToCard
* Description:communicate between RC522 and ISO14443
* Input parameter:command--MF522 command bits
* sendData--send data to card via rc522
* sendLen--send data length
* backData--the return data from card
* backLen--the length of return data
uchar MFRC522_ToCard(uchar command, uchar *sendData, uchar sendLen, uchar *backData, uint *backLen)
    uchar status = MI_ERR;
    uchar irqEn = 0x00;
    uchar waitIRq = 0x00;
    uchar lastBits;
    uchar n;
    uint i;
    switch (command)
        case PCD_AUTHENT: //verify card password
            irqEn = 0x12;
            waitIRq = 0x10;
        case PCD_TRANSCEIVE: //send data in the FIFO
            irqEn = 0x77;
            waitIRq = 0x30;
        default:
    Write_MFRC522(CommIEnReg, irqEn|0x80); //Allow interruption
    ClearBitMask(CommIrqReg, 0x80); //Clear all the interrupt bits
    SetBitMask(FIFOLevelReg, 0x80); //FlushBuffer=1, FIFO initilizate
    Write_MFRC522(CommandReg, PCD_IDLE); //NO action;cancel current command ???
    //write data into FIFO
    for (i=0; i<sendLen; i++)
        Write_MFRC522(FIFODataReg, sendData);
    //procceed it
    Write_MFRC522(CommandReg, command);
    if (command == PCD_TRANSCEIVE)
        SetBitMask(BitFramingReg, 0x80); //StartSend=1,transmission of data starts
    //waite receive data is finished
    i = 2000; //i should adjust according the clock, the maxium the waiting time should be 25 ms???
    do
        //CommIrqReg[7..0]
        //Set1 TxIRq RxIRq IdleIRq HiAlerIRq LoAlertIRq ErrIRq TimerIRq
        n = Read_MFRC522(CommIrqReg);
        i--;
    while ((i!=0) && !(n&0x01) && !(n&waitIRq));
    ClearBitMask(BitFramingReg, 0x80); //StartSend=0
    if (i != 0)
        if(!(Read_MFRC522(ErrorReg) & 0x1B)) //BufferOvfl Collerr CRCErr ProtecolErr
            status = MI_OK;
            if (n & irqEn & 0x01)
                status = MI_NOTAGERR; //??
                n = Read_MFRC522(FIFOLevelReg);
                lastBits = Read_MFRC522(ControlReg) & 0x07;
                if (lastBits)
                    *backLen = (n-1)*8 + lastBits;
                    *backLen = n*8;
                if (n == 0)
                    n = 1;
                if (n > MAX_LEN)
                    n = MAX_LEN;
                //read the data from FIFO
                for (i=0; i<n; i++)
                    backData = Read_MFRC522(FIFODataReg);
            status = MI_ERR;
    //SetBitMask(ControlReg,0x80); //timer stops
    //Write_MFRC522(CommandReg, PCD_IDLE);
    return status;
* Function:MFRC522_Anticoll
* Description:Prevent conflict, read the card serial number
* Input parameter:serNum--return the 4 bytes card serial number, the 5th byte is recheck byte
uchar MFRC522_Anticoll(uchar *serNum)
    uchar status;
    uchar i;
    uchar serNumCheck=0;
    uint unLen;
    //ClearBitMask(Status2Reg, 0x08); //strSensclear
    //ClearBitMask(CollReg,0x80); //ValuesAfterColl
    Write_MFRC522(BitFramingReg, 0x00); //TxLastBists = BitFramingReg[2..0]
    serNum[0] = PICC_ANTICOLL;
    serNum[1] = 0x20;
    status = MFRC522_ToCard(PCD_TRANSCEIVE, serNum, 2, serNum, &unLen);
        //Verify card serial number
        for (i=0; i<4; i++)
            serNumCheck ^= serNum;
        if (serNumCheck != serNum)
            status = MI_ERR;
    //SetBitMask(CollReg, 0x80); //ValuesAfterColl=1
    return status;
* Function:CalulateCRC
* Description:Use MF522 to caculate CRC
* Input parameter:pIndata--the CRC data need to be read,len--data length,pOutData-- the caculated result of CRC
* return:Null
void CalulateCRC(uchar *pIndata, uchar len, uchar *pOutData)
    uchar i, n;
    ClearBitMask(DivIrqReg, 0x04); //CRCIrq = 0
    SetBitMask(FIFOLevelReg, 0x80); //Clear FIFO pointer
    //Write data into FIFO
    for (i=0; i<len; i++)
        Write_MFRC522(FIFODataReg, *(pIndata+i));
    Write_MFRC522(CommandReg, PCD_CALCCRC);
    //waite CRC caculation to finish
    i = 0xFF;
    do
        n = Read_MFRC522(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04)); //CRCIrq = 1
    //read CRC caculation result
    pOutData[0] = Read_MFRC522(CRCResultRegL);
    pOutData[1] = Read_MFRC522(CRCResultRegM);
* Function:MFRC522_Write
* Description:write block data
* Input parameters:blockAddr--block address;writeData--Write 16 bytes data into block
uchar MFRC522_Write(uchar blockAddr, uchar *writeData)
    uchar status;
    uint recvBits;
    uchar i;
    uchar buff[18];
    buff[0] = PICC_WRITE;
    buff[1] = blockAddr;
    CalulateCRC(buff, 2, &buff[2]);
    status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff, &recvBits);
    if ((status != MI_OK) || (recvBits != 4) || ((buff[0] & 0x0F) != 0x0A))
        status = MI_ERR;
        for (i=0; i<16; i++) //Write 16 bytes data into FIFO
            buff = *(writeData+i);
        CalulateCRC(buff, 16, &buff[16]);
        status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 18, buff, &recvBits);
            status = MI_ERR;
    return status;
* Function:MFRC522_Halt
* Description:Command the cards into sleep mode
* Input parameters:null
* return:null
void MFRC522_Halt(void)
    uchar status;
    uint unLen;
    uchar buff[4];
    buff[0] = PICC_HALT;
    buff[1] = 0;
    status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff,&unLen);
}[/code]
 楼主| 发表于 2014-8-10 23:37:38 | 显示全部楼层
接线:Arduino端           ...
你好,我又按照你所回复的检查了一遍连线,也把你的代码借用了,但是我用钥匙扣靠近并接触RFID-RC522的卡时,Arduino 板上的RX灯不会亮,而且串口上面也没有反馈任何信息,波特率设置肯定没错,与程序一致。请问这到底是出什么问题了?
发表于 2014-8-11 01:00:57 | 显示全部楼层
lvehikaru 发表于 2014-8-10 23:37
你好,我又按照你所回复的检查了一遍连线,也把你的代码借用了,但是我用钥匙扣靠近并接触RFID-RC522的卡 ...
咦,你的怎么会不行咧,要不你仔细的检查一下你的硬件连接。我刚刚试了一下,我的可以的,,我的图
要想灯亮,这个地方的代码必须要和卡号匹配才会亮的,,
你先刷一下卡,看看你的卡号,然后将上面标的红颜色的数值用你的卡号(卡号共有8位)从左到右依次2位替换就可以了,,
祝你成功哦~~
 楼主| 发表于 2014-8-11 20:14:27 | 显示全部楼层
要 ...
````我第一步读卡就没反应,串口的波特率设置应该没错,每次刷卡时,Arduino板上的RX灯都不会闪,好像根本没有读数据,我就是在想是不是RFID-RC522坏了,怎么测试它的好坏?我怕如果是它坏了,那我搞再多也是无用功呀
 楼主| 发表于 2014-8-11 22:36:04 | 显示全部楼层
要 ...
非常感谢你的帮助啊,原来是我焊接电路的时候除了问题,应该是某个脚没有焊好,我重新焊了排针后,然后显示出来了,很感谢你提供的代码
发表于 2014-8-12 09:53:20 | 显示全部楼层
lvehikaru 发表于 2014-8-11 22:36
非常感谢你的帮助啊,原来是我焊接电路的时候除了问题,应该是某个脚没有焊好,我重新焊了排针后,然后显 ...
{:soso_e113:} 嘻嘻,不谢的,大家都互相学习的嘛~~
发表于 2014-8-15 15:45:27 | 显示全部楼层
如果要多張卡用呢?应耍怎样.谢谢!
 楼主| 发表于 2014-8-15 20:14:34 | 显示全部楼层
leong118 发表于 2014-8-15 15:45
如果要多張卡用呢?应耍怎样.谢谢!
你是想问多张卡刷了之后,灯会亮还是怎么样?
发表于 2014-8-15 21:01:52 | 显示全部楼层
非常感谢你的回復,我想問怎样可以输入多張卡号,使多张卡都可以亮灯,谢谢!
 楼主| 发表于 2014-8-15 21:27:56 | 显示全部楼层
            if(count%2!=0)
修改程序,这个程序中,if(id[0=0xB4····]),后面,就是你事先读出的卡号,先读出你想要亮灯的卡号,写多几个if语句,然后让digitalWrite(led,HIGH),就是灯亮,这样就可以了。
发表于 2014-8-15 21:59:54 | 显示全部楼层
if( id[0]==0xB4 && id[1]==0xDB && id[2]==0x97 && id[3]==0xDD )//卡号1
if( id[0]==0xB5 && id[1]==0xDc && id[2]==0x98 && id[3]==0xDE )//卡号2
            if(count%2!=0)
是否这样就可以?
 楼主| 发表于 2014-8-15 22:11:51 | 显示全部楼层
if( id[0]==0xB5 && id[1]==0xD ...
额,if不能这样写的吧,你这样就会变成了两个同时成立才会亮了。
分别单独写,
            if(count%2!=0)
            count1++;//IC卡验证通过,加1,此段代码是自己修改的,可以实现通过IC卡来点灯和熄灯
            if(count1%2!=0)
另外要注意加粗的地方,为了防止不同卡之间产生干扰,最好设置不同的中间量,这样,就可以了
发表于 2014-8-15 22:22:38 | 显示全部楼层
            if(count%2!=0)
            if(count1%2!=0)
count //卡号1
count1//卡号2
count2//卡号3
count3//卡号4.........
多張卡就是这样么?
 楼主| 发表于 2014-8-15 22:29:36 | 显示全部楼层
            if(coun ...
嗯,因为这个程序是刷一次卡,灯亮,刷第二次,灯灭。如果你的中间量都是同一个,那么第一张卡去刷,灯亮,第二张卡去刷,灯就会灭了。所以要用不同的中间量,不过记得要在最前面定义这些量~你可以用三张卡试试,说太多也没用,先连接硬件,把程序烧进去看看~~
GMT+8, 2024-4-21 00:34 , Processed in 0.062961 second(s), 20 queries .
