楼主 |
发表于 2014-8-24 10:34:08
显示全部楼层
// matrix2pcs20140821.ino
const int SH_CP = 8;
const int DS = 9;
const int ST_CP = 10;
//声明4个数组临时变量
byte part_A[8], part_B[8],part_C[8],part_D[8],
part_A_A[8],part_B_B[8],part_C_C[8],part_D_D[8],
part_E[8],part_F[8],part_G[8],part_H[8];
//字符列数据,规则是二维数组的第1维代表上下两个矩阵,第二维中第0数组和第1数组分别是左边的8*8点阵和右边的8*8点阵
byte Col[][2][16]={
{0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFC,0x03,0xFD,0xFF,0xFD,0xFF,0xC0,0x0F,0xDF,0xEF},
{0xDF,0xEF,0xDF,0xEF,0xC0,0x0F,0xFF,0xFF,0xDB,0x77,0xDD,0xBB,0xBD,0xBB,0x7F,0xFB},/*"点",0*/
{0xFF,0xBF,0x83,0xBF,0xBB,0xBF,0xB4,0x01,0xB7,0x7F,0xAF,0x5F,0xB6,0xDF,0xB6,0x03},
{0xBB,0xDF,0xBB,0xDF,0xBB,0xDF,0x94,0x01,0xAF,0xDF,0xBF,0xDF,0xBF,0xDF,0xBF,0xDF},/*"阵",1*/
{0xFF,0x7F,0xDF,0xBF,0xE8,0x03,0xEE,0xEF,0x7D,0xB7,0xBB,0x7B,0xBE,0xDF,0xEC,0x0F},
{0xEF,0xEF,0xDF,0x77,0x1E,0xAF,0xDC,0xDF,0xDA,0xEF,0xD6,0xB7,0xDE,0x79,0xFE,0xFF},/*"滚",2*/
{0xFF,0xFF,0xC0,0x07,0xDF,0xF7,0xDF,0xF7,0xC0,0x07,0xDB,0xEF,0xDD,0xDF,0xD0,0x07},
{0xDD,0xDF,0xDD,0xDF,0xC0,0x03,0xDD,0xDF,0xBD,0xDF,0xBB,0xDF,0x7B,0xDF,0xF7,0xDF},/*"屏",3*/
{0xDF,0xBF,0xC1,0x81,0xB7,0x6F,0x7F,0xFF,0xC0,0x07,0xDF,0xF7,0xC0,0x07,0xDF,0xF7},
{0xC0,0x07,0xDF,0xF7,0xC0,0x07,0xF7,0xDF,0x00,0x01,0xF7,0xDF,0xEF,0xDF,0xDF,0xDF},/*"算",4*/
{0xFF,0xBF,0xDF,0xBF,0xEF,0xBF,0xEF,0xBF,0x78,0x03,0xBF,0xBF,0xBF,0xBF,0xEF,0xBF},
{0xE0,0x01,0xDF,0xBF,0x1F,0x7F,0xDE,0xFF,0xDD,0xEF,0xDB,0xF7,0xD0,0x03,0xFB,0xFB},/*"法",5*/
byte Row[] = {1,2,4,8,16,32,64,128};
pinMode(SH_CP, OUTPUT);
pinMode(DS,OUTPUT);
pinMode(ST_CP,OUTPUT);
//定义待显示字符数量
byte ch_num=6;
//定义显示速度变量
byte speed = 10;
//初始化点阵移动计数器
byte counter=0;
//col[][]二维数组中两个数组,均为16个数据,循环16次,将数据分配各临时变量,4个临时变量对应4个8*8点阵,
//对应顺序是part_A对应左上;part_B对应右上;part_C对应左下;
//A和C点阵都是数组中的计数数据;B和C都是数组中的偶数数据
for(int c=0; c<ch_num; c++){
byte a=0;
byte b=0;
for(int i=0; i<16; i++){
//i%2==0证明是数组中的偶数数据,包括0%2==0,故col数组中0,2,4,6,8,10,12,14,16相应数据装入part_A和part_C
if(i%2==0)
//如果读取的字符数据时字符数据库col中的倒数第二个数据时,
if(c==(ch_num-2)){
part_A[a]=Col[c][0][i];
part_C[a]=Col[c][1][i];
//第二个点阵数据为倒数第一个数据
part_A_A[a]=Col[c+1][0][i];
part_C_C[a]=Col[c+1][1][i];
//缓冲数据为字符库数据中开头数据
part_E[a]=Col[0][0][i];
part_G[a]=Col[0][1][i];
//将col[]数组中的数据逐一分配给临时变量
a++;
//如果读取的字符数据时字符数据库col中的倒数第一个数据时,
else if(c==(ch_num-1)){
//循环到字符数据库的开头数据
part_A_A[a]=Col[0][0][i];
part_C_C[a]=Col[0][1][i];
part_E[a]=Col[1][0][i];
part_G[a]=Col[1][1][i];
a++;
//这段是正常思路:逐个获取字符数据
part_E[a]=Col[c+2][0][i];
part_G[a]=Col[c+2][1][i];
a++;
//与i%2==0相对应,如果i%2≠0,就执行下面else里面的内容
//如果读取的字符数据时字符数据库col中的倒数第二个字符数据时
if(c==(ch_num-2)){
part_B[b]=Col[c][0][i];
part_D[b]=Col[c][1][i];
//第二个点阵数据为字符数据库中最后一个字符数据
part_B_B[b]=Col[c+1][0][i];
part_D_D[b]=Col[c+1][1][i];
//为了循环显示,缓冲数据回到字符数据库开头数据
part_F[b]=Col[0][0][i];
part_H[b]=Col[0][1][i];
b++;
//如果读取的字符数据时变量c为字符数据库col中的倒数第1个字符数据时
part_B_B[b]=Col[0][0][i];
part_D_D[b]=Col[0][1][i];
part_F[b]=Col[1][0][i];
part_H[b]=Col[1][1][i];
b++;
//这个else里面的内容为正常思路,逐字符获取数据
else {
part_F[b]=Col[c+2][0][i];
part_H[b]=Col[c+2][1][i];
b++;
//第一次dowhile循环将点阵B数据移动到点阵A的位置;点着A_A数据移动到点阵B的位置。
do{
for(int t=0; t<speed; t++){
for(int i=0; i<8; i++){
digitalWrite(ST_CP, LOW);
shiftOut(DS, SH_CP, MSBFIRST, part_A[i]<<counter|part_B[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_B[i]<<counter|part_A_A[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_A_A[i]<<counter|part_B_B[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_B_B[i]<<counter|part_E[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, Row[i]);
shiftOut(DS, SH_CP, MSBFIRST, part_C[i]<<counter|part_D[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_D[i]<<counter|part_C_C[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_C_C[i]<<counter|part_D_D[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_D_D[i]<<counter|part_G[i]>>(8-counter));
digitalWrite(ST_CP, HIGH);
counter++;
//第二次dowhile循环将点阵A_A数据移动到点阵A的位置;将点阵B_B的数据移动到点阵B的位置;第二个完整的字进入显示屏。
while (counter<8);
counter=0;
do{
shiftOut(DS, SH_CP, MSBFIRST, part_E[i]<<counter|part_F[i]>>(8-counter));
shiftOut(DS, SH_CP, MSBFIRST, part_G[i]<<counter|part_H[i]>>(8-counter));
counter++;
while (counter<8);
counter=0;
