因为前面我跟大家说过,Cb1我不打算继续支持它的CbOS了,所以我决定,拿他当Cloud Server
以前智能家居的帖子我也发了,后面因为手机升级了iOS7,siriproxy不能用了,所以暂停了。
我现在给cb弄了个盒子,准备安装smb,开始计划咯~
这是盒子,本来里面装姜母鸭的:
亮亮的,看到了吗
里面其实有个灯
上面写的是Cubie,用电烙铁切的,万能烙铁,被我拿去焊锡,切亚克力,切塑料,熔松香粘
然后ssh登录,我这是有给cb固定ip的,105
因为以前不玩文件共享,所以这是第一次安装samba:
[color=rgb(46, 166, 255) !important]复制代码
顺便说下,我用mac系统,没法使用这个协议,因此安装另一个软件——vsftpd- apt-get install vsftpd -y
我的配置:- # Example config file /etc/vsftpd.conf
- # The default compiled in settings are fairly paranoid. This sample file
- # loosens things up a bit, to make the ftp daemon more usable.
- # Please see vsftpd.conf.5 for all compiled in defaults.
- # READ THIS: This example file is NOT an exhaustive list of vsftpd options.
- # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
- # capabilities.
- # Run standalone? vsftpd can run either from an inetd or as a standalone
- # daemon started from an initscript.
- listen=YES
- # Run standalone with IPv6?
- # Like the listen parameter, except vsftpd will listen on an IPv6 socket
- # instead of an IPv4 one. This parameter and the listen parameter are mutually
- # exclusive.
- #listen_ipv6=YES
- # Allow anonymous FTP? (Beware - allowed by default if you comment this out).
- anonymous_enable=YES
- # Uncomment this to allow local users to log in.
- local_enable=YES
- # Uncomment this to enable any form of FTP write command.
- write_enable=YES
- # Default umask for local users is 077. You may wish to change this to 022,
- # if your users expect that (022 is used by most other ftpd's)
- local_umask=077
- # Uncomment this to allow the anonymous FTP user to upload files. This only
- # has an effect if the above global write enable is activated. Also, you will
- # obviously need to create a directory writable by the FTP user.
- #anon_upload_enable=YES
- # Uncomment this if you want the anonymous FTP user to be able to create
- # new directories.
- #anon_mkdir_write_enable=YES
- # Activate directory messages - messages given to remote users when they
- # go into a certain directory.
- dirmessage_enable=YES
- # If enabled, vsftpd will display directory listings with the time
- # in your local time zone. The default is to display GMT. The
- # times returned by the MDTM FTP command are also affected by this
- # option.
- use_localtime=YES
- # Activate logging of uploads/downloads.
- xferlog_enable=YES
- # Make sure PORT transfer connections originate from port 20 (ftp-data).
- connect_from_port_20=YES
- # If you want, you can arrange for uploaded anonymous files to be owned by
- # a different user. Note! Using "root" for uploaded files is not
- # recommended!
- #chown_uploads=YES
- #chown_username=whoever
- # You may override where the log file goes if you like. The default is shown
- # below.
- #xferlog_file=/var/log/vsftpd.log
- # If you want, you can have your log file in standard ftpd xferlog format.
- # Note that the default log file location is /var/log/xferlog in this case.
- #xferlog_std_format=YES
- # You may change the default value for timing out an idle session.
- #idle_session_timeout=600
- # You may change the default value for timing out a data connection.
- #data_connection_timeout=120
- # It is recommended that you define on your system a unique user which the
- # ftp server can use as a totally isolated and unprivileged user.
- #nopriv_user=ftpsecure
- # Enable this and the server will recognise asynchronous ABOR requests. Not
- # recommended for security (the code is non-trivial). Not enabling it,
- # however, may confuse older FTP clients.
- #async_abor_enable=YES
- # By default the server will pretend to allow ASCII mode but in fact ignore
- # the request. Turn on the below options to have the server actually do ASCII
- # mangling on files when in ASCII mode.
- # Beware that on some FTP servers, ASCII support allows a denial of service
- # attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
- # predicted this attack and has always been safe, reporting the size of the
- # raw file.
- # ASCII mangling is a horrible feature of the protocol.
- #ascii_upload_enable=YES
- #ascii_download_enable=YES
- # You may fully customise the login banner string:
- #ftpd_banner=Welcome to blah FTP service.
- # You may specify a file of disallowed anonymous e-mail addresses. Apparently
- # useful for combatting certain DoS attacks.
- #deny_email_enable=YES
- # (default follows)
- #banned_email_file=/etc/vsftpd.banned_emails
- # You may restrict local users to their home directories. See the FAQ for
- # the possible risks in this before using chroot_local_user or
- # chroot_list_enable below.
- chroot_local_user=YES
- # You may specify an explicit list of local users to chroot() to their home
- # directory. If chroot_local_user is YES, then this list becomes a list of
- # users to NOT chroot().
- # (Warning! chroot'ing can be very dangerous. If using chroot, make sure that
- # the user does not have write access to the top level directory within the
- # chroot)
- #chroot_local_user=YES
- chroot_list_enable=YES
- chroot_list_file=/etc/vsftpd.chroot_list
- # You may activate the "-R" option to the builtin ls. This is disabled by
- # default to avoid remote users being able to cause excessive I/O on large
- # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
- # the presence of the "-R" option, so there is a strong case for enabling it.
- #ls_recurse_enable=YES
- # Customization
- # Some of vsftpd's settings don't fit the filesystem layout by
- # default.
- # This option should be the name of a directory which is empty. Also, the
- # directory should not be writable by the ftp user. This directory is used
- # as a secure chroot() jail at times vsftpd does not require filesystem
- # access.
- secure_chroot_dir=/var/run/vsftpd/empty
- # This string is the name of the PAM service vsftpd will use.
- pam_service_name=vsftpd
- # This option specifies the location of the RSA certificate to use for SSL
- # encrypted connections.
- rsa_cert_file=/etc/ssl/private/vsftpd.pem
之后可以用user用户登录,账户允许chroot文件:- root@cubieboard:~/source_code/cloudserver# cat /etc/vsftpd.chroot_list
- user
试了下phpmailer,没成功,就是一直卡着,不知道为啥
然后我自己写的ledc程序,用cron启动,每5分钟ping一次谷歌,当然我觉得ping百度更好,因为谷歌有时候不通,通就亮灯,不通灭灯,通过GPIO控制,引入的文件就是gpio的控制文件- #include <stdlib.h>
- #include <stdio.h>
- #include "gpio_lib.c"
- #include <string.h>
- int dy(int port)
- //printf("SUNXI GPIO tool\n");
- if(SETUP_OK!=sunxi_gpio_init()){
- printf("Failed to initialize GPIO\n");
- return 1;
- if(SETUP_OK!=sunxi_gpio_set_cfgpin(SUNXI_GPD(port),OUTPUT)){
- printf("Failed to config GPIO pin\n");
- return 1;
- if(system("ping google.com -c 1") != 0){
- //Is network OK?
- printf("No network!\n");
- if(sunxi_gpio_output(SUNXI_GPD(port),LOW)){
- printf("Failed to set GPIO pin value\n");
- return 1;
- }else{
- printf("Fine!\n");
- if(sunxi_gpio_output(SUNXI_GPD(port),HIGH)){
- return 1;
- sunxi_gpio_cleanup();
- return 0;
- int main(int argc,char* argv[]){
- dy(0);
用crontab -e编辑文件,增加:- */5 * * * * /root/source_code/cloudserver/ledc > /tmp/netlog
好了,大家慢慢玩~
