发表于 2014-12-1 19:59:07
显示全部楼层
int dht11_read(int pin)
// BUFFER TO RECEIVE
int bits[5];
int cnt = 7;
int idx = 0;
// EMPTY BUFFER
for (int i=0; i< 5; i++)
{bits[i]= 0;}
// REQUEST SAMPLE
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delay(18);
digitalWrite(pin, HIGH);
delayMicroseconds(40);
pinMode(pin, INPUT);
// ACKNOWLEDGE or TIMEOUT
unsigned int loopCnt = 10000;
while(digitalRead(pin) == LOW)
if (loopCnt-- == 0) return -2;
loopCnt = 10000;
while(digitalRead(pin) == HIGH)
// READ OUTPUT - 40 BITS => 5 BYTES or TIMEOUT
for (int i=0; i<40; i++)
loopCnt = 10000;
unsigned long t = micros();
loopCnt = 10000;
if ((micros() - t) > 40) bits[idx] |= (1 << cnt);
if (cnt == 0) // next byte?
cnt = 7; // restart at MSB
idx++; // next byte!
else cnt--;
// WRITE TO RIGHT VARS
// as bits[1] and bits[3] are allways zero they are omitted in formulas.
humidity = bits[0];
temperature = bits[2];
int sum = bits[0] + bits[2];
if (bits[4] != sum) return -1;
return 0;
