更新的库基本重写了,加入软SPI,可以使用任意引脚驱动,也可以选择硬件spi;
加入数据接收是否启用中断;
不再是杂乱无章的测试代码,有规划的一个库;
各个功能实现库分开,下次更新不需要改变函数传入参数;
支持5路通道接收数据;
忘记把uint8_t 改成 byte了,uint8_t = byte; 不改也可以用,有uint8_t 的地方都可以用byte替换
2月6号更新
加入用户界面基于字符串模式选择
通过 int set_reg(String reg, String data);进行操作,例句:nrf.set_reg("Rate","2M");这个是设置nrf24l01为2M速率,如果输入错误的模式与命令会返回"1000"(模式错误) ,"1001"(命令错误)
库已更新-版本号:v1.1
"Mode"-> "Receive" or "Send" //模式 "Power"-> "up" or "Down" //电源模式
"CRC"-> "16bit" or "8bit" //CRC校验模式
"RF_Power"->"0dBm"or"-6dBm"or"-12dBm"or"-18dBm" //功率
"Rate"->"1M"or"2M"or"250k" //速率
"RF_Channel"->数值 //信道
int set_reg(String reg, String data);源代码
- int Multiple::set_reg(String reg, String data)
- uint8_t tmp;
- //-------------命令检查模块-------------
- boolean cmd_tmp=false;
- boolean data_tmp=false;
- boolean cmd_RF_Channel=false;
- String cmd[]={"Mode","Power","CRC","RF_Power","Rate","RF_Channel","NULL"};
- String cmd_data[]={"Receive","Send","up","Down","16bit","8bit","0dBm","-6dBm","-12dBm","-18dBm","1M","2M","250k","NULL"};
- for(uint8_t i=0;cmd[i]!="NULL";i++)
- if(reg==cmd[i])
- {cmd_tmp=true;}
- if(reg=="RF_Channel")
- {cmd_RF_Channel=true;}
- if(!cmd_tmp)
- { return 1000;}
- for(uint8_t i=0;cmd_data[i]!="NULL";i++)
- if(data==cmd_data[i])
- {data_tmp=true;}
- if(!cmd_RF_Channel && !cmd_RF_Channel)
- { return 1001;}
- //-------------命令检查模块---------------//
- digitalWrite(_CE,LOW);
- if(reg=="Mode")
- tmp=Read(0x00);
- if(data=="Receive")
- {tmp |=0x01;}
- else if(data=="Send")
- {tmp &=0xfe;}
- RW_Reg(WRITE_REG + 0x00,tmp);
- if(reg=="Power")
- tmp=Read(0x00);
- if(data=="up")
- { tmp |=0x02;}
- else if(data=="Down")
- { tmp &=0xfd;}
- if(reg=="CRC")
- tmp=Read(0x00);
- if(data=="16bit")
- {tmp |=0x04;}
- else if(data=="8bit")
- {tmp &=0xfb;}
- //-----------------CONFIG--------------
- if(reg=="RF_Power")
- tmp=Read(0x06);
- if(data=="0dBm")
- {tmp |=0x07;}
- else if(data=="-6dBm")
- { tmp &=0xf9;
- tmp |=0x04; }
- else if(data=="-12dBm")
- { tmp &=0xf9;
- tmp |=0x02; }
- else if(data=="-18dBm")
- { tmp &=0xf9;
- tmp |=0x00; }
- RW_Reg(WRITE_REG + 0x06,tmp);
- if(reg=="Rate")
- tmp=Read(0x06);
- if(data=="1M")
- { tmp &=0xd7;
- tmp |=0x00; }
- else if(data=="2M")
- { tmp &=0xd7;
- tmp |=0x08; }
- else if(data=="250k")
- { tmp &=0xd7;
- tmp |=0x20; }
- tmp=atof(data.c_str());
- RW_Reg(WRITE_REG + 0x05,tmp);
- digitalWrite(_CE,HIGH);
- return tmp;
面向用户开放的库头文件函数:
- * Copyright (c) 2015 by Mylife1213 <[url=mailto:[email protected]][email protected][/url]>
- * Nrf24l01P library for Arduino.
- * This file is free software; you can redistribute it and/or modify
- * it under the terms of either the GNU General Public License version 2
- * or the GNU Lesser General Public License version 2.1, both as
- * published by the Free Software Foundation.
- * version v1.0
- #ifndef Multiple_H_
- #define Multiple_H_
- #include "nrf_base.h"
- #define uint8_t unsigned char
- class Multiple : public nrf_base
- public:
- 构建函数,使用硬件spi
- Multiple(uint8_t ce, uint8_t csn);
- 构建函数,使用SOFT SPI
- Multiple(uint8_t ce, uint8_t csn,uint8_t clk,uint8_t mosi,uint8_t miso);
- 设置成读取模式,参数: p1接收主地址,p2_p5其余接收地址首位
- uint8_t read_mode(uint8_t* p1, uint8_t* p2_p5);
- 设置使用中断模式
- void Interrup(uint8_t pin,void (*func)() );
- 中断模式下的接收数据读取,channel通道,data读取的数组
- uint8_t Interrup_read(uint8_t channel,uint8_t* data);
- 普通模式下的数据读取,channel通道,data数据数组
- 返回值 1:收到数据 0:没有数据
- uint8_t read(uint8_t channel,uint8_t* data);
- 设置发送模式,参数p0:发送的地址数组
- uint8_t send_mode(uint8_t* p0);
- 发送数据,addr:发送地址 data:发送数据数组
- uint8_t send(uint8_t* addr, uint8_t* data);
- 手动修改寄存器,reg:修改的寄存器 data:数值
- uint8_t set_reg(uint8_t reg, uint8_t data);
- 寄存器调试变量,需设置模式前启用
- uint8_t _EN_AA;
- uint8_t _EN_RXADDR;
- uint8_t _SETUP_RETR;
- uint8_t _RF_CH;
- uint8_t _RF_SETUP;
- uint8_t _SETUP_AW;
- uint8_t _CONFIG;
- uint8_t _RX_PW;
- uint8_t _TX_EN_AA;
- uint8_t _TX_EN_RXADDR;
- uint8_t _TX_SETUP_RETR;
- uint8_t _TX_RF_CH;
- uint8_t _TX_RF_SETUP;
- uint8_t _TX_SETUP_AW;
- uint8_t _TX_CONFIG;
- uint8_t _TX_PW;
- private:
- #endif
已带不同场景例程,全部有进行测试
例程代码:
Spi_send 使用硬件spi进行发送 - /**
- * version v1.0
- nrf24l01 arduino
- csk-> csk
- mosi-> mosi
- miso-> miso
- ce-> 用户设置
- csn-> 用户设置
- #include"Multiple.h"
- Multiple nrf(9,8);//构建函数,参数分别为CE,CSN
- uint8_t tx_addr[] = { 0x03, 0xFF, 0xFF, 0xFF, 0xFF};//发送地址
- uint8_t tx_data[32]={1,2,3,4};//发送的数据,32位
- void setup() {
- nrf.send_mode(tx_addr);//设置为发送模式,参数为发送地址
- void loop() {
- tx_data[0]++;
- nrf.send(tx_addr,tx_data);//发送数据,参数:发送地址,数据
- delay(5000);
例程Soft_spi_send使用软SPI进行发送 - /**
- * version v1.0
- nrf24l01 arduino
- csk-> 用户设置
- mosi-> 用户设置
- miso-> 用户设置
- ce-> 用户设置
- csn-> 用户设置
- Multiple nrf(9,8,3,4,5);//构建函数,参数分别为CE,CSN,CLK,MOSI,MISO
- void setup() {
- void loop() {
- tx_data[0]++;
- delay(5000);
例程Read_no_interrup_mode不使用中断接收 - /**
- * version v1.0
- nrf24l01 arduino
- csk-> csk
- mosi-> mosi
- miso-> miso
- ce-> 用户设置
- csn-> 用户设置
- uint8_t rx_addr_p1[6]={ 0x01, 0xFF, 0xFF, 0xFF, 0xFF};//接收地址
- uint8_t rx_addr_p2_5[6]={0x02,0x03,0x04,0x05}; /**
- 通道2至5地址,各地址=各个数
- 组元素+rx_addr_p1后4位**/
- uint8_t rx_data[32];//接收数据存储
- uint8_t channel;//接收通道
- uint8_t tmp;
- void setup() {
- Serial.begin(9600);
- nrf.read_mode(rx_addr_p1, rx_addr_p2_5);//设置为接收模式,参数:通道1地址,通道2-5地址
- void loop() {
- tmp=nrf.read(channel,rx_data);//读取接收数据,有数据返回1,参数:通道,数据
- if(tmp==1)
- Serial.print("Channel= ");
- Serial.print(channel);
- Serial.print(" rx_data[0]= ");
- Serial.println(rx_data[0]);
例程Read_interrup_mode使用中断进行数据接收 - /**
- * version v1.0
- nrf24l01 arduino
- csk-> csk
- mosi-> mosi
- miso-> miso
- ce-> 用户设置
- csn-> 用户设置
- isr-> 用户设置中断引脚
- 通道2至5地址,各地址=各个数
- void setup() {
- nrf.Interrup(0, r_data);//设置为中断接收,参数:中断号,中断函数
- void loop() {
- void r_data()
- nrf.Interrup_read(channel, rx_data);//中断模式下读取数据,参数:通道,接收数据
- Serial.print("Channel: ");
- Serial.print("rx_data[0]=");
库文件版本v1.1
