作者:邓帅哥——大人
不要崇拜哥,哥为人民服务,哥已不在社区,但社区的每一个角落都流传着哥的传说。
Now,镜头转入正题,mega2560 USB第二季KEYBOARD HID
首先,你必须有一片arduino主板,而且主板上必须有一片atmega8U2/atmega16U2/支持usb的芯片+mega主芯片(mega328,128,1280,2560.......),操作前请导入附件的USB库
step1:
将下列arduino代码通过arduion下载到arduino板子上,它的功能是,当你按键NumLock三次的时候,它会模拟按键输入一排信息,改变Keyboard.print内的操作即可以改变你想要的按键。- /* Arduino USB Business Card
- 1. Upload this program to Arduino
- 2. Upgrade atmega8u2 with firmware/Arduino-keyboard-0.3.hex
- 3. Re-plug Arduino to usb port, and pressed Num Lock button 3 times in 2 seconds
- Arduino will type your contact text information into the text editor
- #include <USBKeyboard.h>
- const uint8_t KEYBOARD_LED = LED_NUMLOCK; // Num Lock LED
- const int ledPin = 13;
- uint8_t lastState = 0, currentState = 0;
- void setup()
- pinMode(ledPin, OUTPUT);
- Keyboard.init();
- // return true if KEYBOARD_LED (Num Lock button) is pressed
- boolean buttonPressed()
- uint8_t ledStatus;
- ledStatus = Keyboard.readLedStatus();
- // Arduino Led pin as an indicator
- // If Num Lock led is on, the led indicator will be on
- if (ledStatus & KEYBOARD_LED) {
- digitalWrite(ledPin, HIGH);
- } else {
- digitalWrite(ledPin, LOW);
- lastState = currentState;
- currentState = ledStatus & KEYBOARD_LED;
- return (currentState != lastState);
- void sendContactInfo()
- Keyboard.print("dengshuaige");
- Keyboard.sendKeyStroke(KEY_ENTER);
- Keyboard.print("Email: [email][email protected][/email]");
- Keyboard.print("dengshuaige.com");
- void loop()
- int counter;
- delay(100);
- // Check whether KEYBOARD_LED is pressed 3 times in 2 seconds
- if (buttonPressed()) {
- counter = 1;
- for (int i = 0; i < 20; i++) {
- delay(100);
- if (buttonPressed()) counter = counter + 1;
- // Send my information to computer
- if (counter >= 3) {
- sendContactInfo();
- break;
- counter = 0; // reset counter
复制代码 下载到mega2560后,板子还是不能工作的,请继续往下看,
step2:将Arduino-keyboard-0.3-mega2560.hex通过烧录器烧到mega8U2上面
哥用的是USBasp,淘宝15——20元一个。
OK,将mega8u2烧好之后,
连接arduino的USB线,你可以看见在键盘下方多了一个HID keyboard device(不需要安装任何驱动),哈哈,这时,你可以用你自已做的键盘了。
测试一下,新建一个文本,打开,光标输入到文本,按三次NumLock键,得到如下:
USB第三季预告(AVR篇)用mega8单独打造USB键盘...掌声~~~~ |
