发表于 2015-12-8 13:41:22
显示全部楼层
关于空调解码的问题,国外的analys大神给出了一个解码方案,同时解码的长度达到800位,上面两位朋友可以参考一下
analyse大声空调长解码解决方案
网页链接http://www.analysir.com/blog/2014/03/19/air-conditioners-problems-recording-long-infrared-remote-control-signals-arduino/
附上代码- /*
- Author: AnalysIR
- Revision: 1.0
- This code is provided to overcome an issue with Arduino IR libraries
- It allows you to capture raw timings for signals longer than 255 marks & spaces.
- Typical use case is for long Air conditioner signals.
- You can use the output to plug back into IRremote, to resend the signal.
- This Software was written by AnalysIR.
- Usage: Free to use, subject to conditions posted on blog below.
- Please credit AnalysIR and provide a link to our website/blog, where possible.
- Copyright AnalysIR 2014
- Please refer to the blog posting for conditions associated with use.
- http://www.analysir.com/blog/2014/03/19/air-conditioners-problems-recording-long-infrared-remote-control-signals-arduino/
- Connections:
- IR Receiver Arduino
- V+ -> +5v
- GND -> GND
- Signal Out -> Digital Pin 2
- (If using a 3V Arduino, you may connect V+ to +3V)
- #define LEDPIN 13
- //you may increase this value on Arduinos with greater than 2k SRAM
- #define maxLen 800
- volatile unsigned int irBuffer[maxLen]; //stores timings - volatile because changed by ISR
- volatile unsigned int x = 0; //Pointer thru irBuffer - volatile because changed by ISR
- void setup() {
- Serial.begin(9600); //change BAUD rate as required
- attachInterrupt(0, rxIR_Interrupt_Handler, CHANGE);//set up ISR for receiving IR signal
- void loop() {
- // put your main code here, to run repeatedly:
- //Serial.println(F("Press the button on the remote now - once only"));
- delay(5000); // pause 5 secs
- if (x) { //if a signal is captured
- digitalWrite(LEDPIN, HIGH);//visual indicator that signal received
- Serial.println();
- Serial.print(F("Raw: (")); //dump raw header format - for library
- Serial.print((x - 1));
- Serial.print(F(") "));
- detachInterrupt(0);//stop interrupts & capture until finshed here
- for (int i = 1; i < x; i++) { //now dump the times
- //if (!(i & 0x1)) Serial.print(F("-"));
- Serial.print(irBuffer[i] - irBuffer[i - 1]);
- Serial.print(F(","));
- x = 0;
- Serial.println();
- Serial.println();
- digitalWrite(LEDPIN, LOW);//end of visual indicator, for this time
- attachInterrupt(0, rxIR_Interrupt_Handler, CHANGE);//re-enable ISR for receiving IR signal
- void rxIR_Interrupt_Handler() {
- if (x > maxLen) return; //ignore if irBuffer is already full
- irBuffer[x++] = micros(); //just continually record the time-stamp of signal transitions
复制代码 但这样的话,解码的还是会有些不稳定,希望可以一起探讨一下,这种方案 就是直接利用外部中断,感知红外接收管电平变化 |
