我刚好有段测试程序
#include <SoftwareSerial.h>
#include <dht11.h>
//SoftwareSerial mySerial(7, 8); // RX, TX
SoftwareSerial mySerial(9, 10); // RX, TX
dht11 DHT11;
#define DHT11PIN 3 //Connect D3 to data pin of DHT11
#define httpled 13
#define pinOut 5
//请到m.znck007.com申请登陆-》家中环境-》网关,里可以看到!
//#define APIKEY "8c5b8d26a8010092" //设置apikey
#define APIKEY "734f00510f77ca88"
char server[] = "api.znck007.com";//声明API网址
//#define server "220.181.111.85" //baidu.com
unsigned long last_http;
unsigned long timer,last;
char serialbuff[129]={0};
char buffer[35];
char buff[30];
bool ishttpget=false;
bool last_send=false;
bool wsd=false;
int temperature=25;
int humdity=75;
int Count=0;
int sid=3;
int nid=1;
bool update=false;
void setup(void)
Serial.begin(115200); //设置串口波特率
mySerial.begin(9600);
//Serial.flush(); //等待超出的串行数据完成传输
pinMode(httpled,OUTPUT);
pinMode(pinOut,OUTPUT);
delay(1000);
if(close_AT_show()) mySerial.println("close_AT_show ok");
mySerial.println("wait join AP");
if(conf_JAP("sun","zw889989")) mySerial.println("join sun ok"); //登陆网络需要的ssid名称以及密码
else mySerial.println("join sun fail");
mySerial.println("setup success");
void loop(void)
if(millis() - last_http >= 5000)
//last = millis();//获取现在的时间
if(!ishttpget || millis() - last_http >= 30000)
last_http = millis();
ishttpget=true;
Count++;
mySerial.println(Count);
if(Count>=120)
Count = 0;
wsd = true;
digitalWrite(httpled,HIGH);
mySerial.println("\n>>> REQ");
static char buf[42]={0};
sprintf(buf,"{ck001000000000}"); //%s ,updateData
if(wsd)
wsd = false;
int thsid=001;
int thnid=002;
DHT11.read(DHT11PIN); //读温湿度数据
humdity = DHT11.humidity;
temperature = DHT11.temperature;
get_send_char(thsid,thnid,humdity,temperature,buff);//"{ck001001100000}"
sendData(buff);
else sendData(buf); //POST到网址,APIKEY,字符
if (Serial.available() > 0)
int index=0;
delay(100); // let the buffer fill up
int numChar = Serial.available(); //获取从串口读取有效的字节数(字符)
if (numChar>128) numChar=128;
while (numChar--)
serialbuff[index++] = Serial.read();
serial_String(serialbuff);
if (mySerial.available() > 0)
int index=0;
int numChar = mySerial.available();
if (numChar>29) numChar=29;
while (numChar--)
buffer[index++] = mySerial.read();
splitString(buffer);
void serial_String(char* data)
mySerial.println(data);
char body[30]={0};
get_znck_body(data,body);//获取只是{ckxxxxxx}的字符,因为这是我们的命令格式
mySerial.println(body);
int s=get_sid(body);
int n=get_nid(body);
int d=get_data(body);
if( s==sid && n==nid )
if( d==1 ) digitalWrite(pinOut,HIGH);
else digitalWrite(pinOut,LOW);
if(last_send)
mySerial.print("<<< reply ");
mySerial.print(millis() - timer);
mySerial.println(" ms");
mySerial.println("");
last_send = false;
//if(Serial.find("Content-Type")==true)
ishttpget=false;
digitalWrite(httpled,LOW);
// Clear the text and serial buffers
for (int x=0; x<129; x++)
serialbuff[x]='\0';
void splitString(char* data)
char* parameter;
parameter = strtok (data, " ,");
while (parameter != NULL)
mySerial.println(parameter);
//set_data(parameter);
parameter = strtok (NULL, " ,");
for (int x=0; x<30; x++)
buffer[x]='\0';
mySerial.flush(); //等待超出的串行数据完成传输
void set_data(char* data)
if ((data[0] == 'y') || (data[0] == 'Y'))
int Ans = strtol(data+1, NULL, 10);
static char buf[20]={0};
sprintf(buf,"{ck001000000000}"); //这个字符串代表获取新命令数据
if(update)
update = false;
sendData(buff);
else sendData(buf);
if ((data[0] == 'd') || (data[0] == 'D'))
int getdata = strtol(data+1, NULL, 10);
get_getdata_char(sid,nid,getdata,buff);
update = true;
if ((data[0] == 't') || (data[0] == 'T'))
temperature = Ans;
get_send_char(sid,nid,humdity,temperature,buff);//"{ck001001100000}"
update = true;
if ((data[0] == 'h') || (data[0] == 'H'))
humdity = Ans;
update = true;
if ((data[0] == 's') || (data[0] == 'S'))
sid = Ans;
update = true;
if ((data[0] == 'n') || (data[0] == 'N'))
nid = Ans;
update = true;
if ((data[0] == 'j') || (data[0] == 'J'))
//setdata = Ans;
if(Ans<10)
if(conf_JAP("860","zw889989")) mySerial.println("join 860 ok");
else mySerial.println("join 860 fail");
if(Ans>10)
//update = true;
void sendData(char* thisData) //this method makes a HTTP connection to the server:
//digitalWrite(httpled,HIGH);
if(start_Mux(1,server,80)) //if there's a successful connection:
mySerial.println("connecting...");
// send the HTTP PUT request:
String cmd;
cmd = "POST /index.php HTTP/1.0\r\n";
cmd += "Host: api.znck007.com\r\n";
cmd += "apikey:";
cmd += APIKEY;
cmd += "\r\n";
cmd += "Accept: *";
cmd += "/";
cmd += "*\r\n";
cmd += "Content-Length: ";
size_t thisLength = strlen(thisData);
cmd += String(thisLength);
cmd += "\r\n";
cmd += "Content-Type: application/x-www-form-urlencoded\r\n";
cmd += "\r\n";
cmd += String(thisData);
cmd += "\r\n";
//mySerial.println(cmd);
//Send_test(cmd);
if(Send(cmd)) mySerial.println("Send ok");
else mySerial.println("Send fail");
// if you couldn't make a connection:
mySerial.println("connection failed");
//mySerial.println("disconnecting.");
//Serial.println("AT+CIPCLOSE");
boolean Send(String str)
Serial.print("AT+CIPSEND=");
Serial.println(str.length());
unsigned long start;
start = millis();
bool found=false;
while (millis()-start<3000)
if(Serial.find(">")==true )
found = true;
if(found) Serial.print(str);
else return false;
start = millis();
while (millis()-start<8000)
if(Serial.available()>0)
if(Serial.find("SEND OK")==true)
last_send = true;
timer = millis();
return true;
return false;
//confJAP("Rookie","zw889989"); //配置登陆网络需要的ssid名称以及密码
boolean conf_JAP(String ssid , String pwd) //配置登陆网络需要的ssid名称以及密码
Serial.print("AT+CWJAP=");
Serial.print("\""); //"ssid"
Serial.print(ssid);
Serial.print("\"");
Serial.print(",");
Serial.print("\""); //"pwd"
Serial.print(pwd);
Serial.println("\"");
unsigned long start = millis();
while (millis()-start<18000)
if(Serial.find("OK")==true)
return true;
return false;
//startMux_0(1,"192.168.1.16",5000); //建立tcp链接或者注册UDP端口号(单路模式)
boolean start_Mux(byte type, String addr, int port) //建立tcp链接或者注册UDP端口号(单路模式)
String data;
Serial.print("AT+CIPSTART=");
if(type>0) Serial.print("\"TCP\"");
else Serial.print("\"UDP\"");
Serial.print(",");
Serial.print("\"");
Serial.print(addr);
Serial.print("\"");
Serial.print(",");
Serial.println(String(port));
while (millis()-start<5000) //当串口有完成数据返回时,结束语句
char a =Serial.read();
data=data+a;
if (data.indexOf("OK")!=-1 || data.indexOf("ALREAY CONNECT")!=-1 || data.indexOf("ERROR")!=-1)
//if (data.indexOf("Linked")!=-1) return true;
return true;
return false;
boolean close_AT_show()
String data;
Serial.println("ATE0");
while (millis()-start<3000) //当串口有完成数据返回时,结束语句
return true;
return false;
void get_znck_body(char *p,char *s) //获取只是{ckxxxxxx}的字符,因为这是我们的命令格式
char rechar[129]={0};
int bufi=0;
bool isend=false;
int charnum=0;
for(bufi=0;bufi<strlen(p);bufi++)
//Serial.print(p[bufi]);
if(p[bufi]=='{') isend=true;
if(p[bufi]=='}' && isend==true)
isend=false;
rechar[charnum]=p[bufi];
if(isend)
if(charnum<129)
rechar[charnum]=p[bufi];//Serial.print(rechar[charnum]);
charnum++;
//Serial.println("");
//memcpy(s,rechar,129);
sprintf(s,"%s",rechar);
int get_sid(char *buff) //获取sid
if( strstr(buff,"{ck") && strstr(buff,"}") && strlen(buff)>10)
char charsid[4]={0};
memcpy(charsid,buff+3,3);
//Serial.println(charsid);
int intsid=atoi(charsid);
mySerial.print("sid=");
mySerial.println(intsid);
return intsid;
else return 0;
int get_nid(char *buff) //获取nid
char charNid[4]={0};
memcpy(charNid,buff+6,3);
//Serial.println(charNid);
int intNid=atoi(charNid);
mySerial.print("Nid=");
mySerial.println(intNid);
return intNid;
else return 0;
int get_data(char *buff) //获取data
char charData[4]={0};
memcpy(charData,buff+9,1);
//Serial.println(charData);
int intData=atoi(charData);
mySerial.print("Data=");
mySerial.println(intData);
return intData;
else return 0;
void get_send_char(int sid,int nid,int humdity,int temperature,char *p)
sprintf(p,"{ck%.3d%.3d%d.%d}",sid,nid,humdity,temperature);
void get_getdata_char(int sid,int nid,int getdata,char *p)
sprintf(p,"{ck%.3d%.3d%d}",sid,nid,getdata);
