这是BMP180模块,四个引脚
以Arduino Uno为例:VCC 接3.3v,GND接GND,SCL接A5,SDA接A4
库:
- #include <SFE_BMP180.h>
- #include <Wire.h>
- SFE_BMP180 pressure;// 创建一个气压计对象
- double baseline; // 基准气压
- void setup()
- Serial.begin(9600);
- Serial.println("REBOOT");
- // 初始化传感器
- if (pressure.begin())
- Serial.println("BMP180 init success");
- else
- // 糟糕,气压计出问题了,多半是连线有问题
- Serial.println("BMP180 init fail (disconnected?)\n\n");
- while(1); // 暂停
- //获得基准气压
- baseline = getP();
- Serial.print("baseline pressure: ");
- Serial.print(baseline);
- Serial.println(" hPa");
- void loop()
- double a,p,t;
- p = getP();// 获得一个气压值
- a = pressure.altitude(p,baseline);//获得基于基准气压的高度值
- Serial.print("relative altitude: ");
- if (a >= 0.0) Serial.print(" "); // 调整正数显示格式
- Serial.print(a,1);
- Serial.print(" meters ");
- t = getT();// 获得一个温度值
- Serial.print("temperature: ");
- Serial.print(t,1);
- Serial.println(" degrees");
- delay(500);//刷新率
- double getP()
- char status;
- double T,P,p0,a;
- // You must first get a temperature measurement to perform a pressure reading.
- // Start a temperature measurement:
- // If request is successful, the number of ms to wait is returned.
- // If request is unsuccessful, 0 is returned.
- status = pressure.startTemperature();
- if (status != 0)
- // Wait for the measurement to complete:
- delay(status);
- // Retrieve the completed temperature measurement:
- // Note that the measurement is stored in the variable T.
- // Use '&T' to provide the address of T to the function.
- // Function returns 1 if successful, 0 if failure.
- status = pressure.getTemperature(T);
- if (status != 0)
- // Start a pressure measurement:
- // The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
- status = pressure.startPressure(3);
- if (status != 0)
- delay(status);
- // Retrieve the completed pressure measurement:
- // Note that the measurement is stored in the variable P.
- // Use '&P' to provide the address of P.
- // Note also that the function requires the previous temperature measurement (T).
- // (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
- status = pressure.getPressure(P,T);
- if (status != 0)
- return P;
- else Serial.println("error retrieving pressure measurement\n");
- else Serial.println("error starting pressure measurement\n");
- else Serial.println("error retrieving temperature measurement\n");
- else Serial.println("error starting temperature measurement\n");
- double getT()
- char status;
- double T,p0;
- if (status != 0)
- delay(status);
- if (status != 0)
- return T;
效果:
参考资料:https://learn.sparkfun.com/tutorials/bmp180-barometric-pressure-sensor-hookup- |
