查看: 28947|回复: 0
OpenCV学习笔记之——图像变换
发表于 2011-10-3 21:16:45 | 显示全部楼层 |阅读模式
#include "stdafx.h"
#include "cv.h"
#include <cxcore.h>
#include <highgui.h>
void example2_4( IplImage* image )
    // Create some windows to show the inpu
    // and output images in.
    cvNamedWindow( "Example2_4-in", CV_WINDOW_AUTOSIZE );
    cvNamedWindow( "Example2_4-out", CV_WINDOW_AUTOSIZE );
    // Create a window to show our input image
    cvShowImage( "Example2_4-in", image );
    // Create an image to hold the smoothed output
    IplImage* out = cvCreateImage(
       cvGetSize(image),
        IPL_DEPTH_8U,
        3
    // Do the smoothing
    cvSmooth( image, out, CV_GAUSSIAN, 5,5 );
    cvSmooth( out, out, CV_GAUSSIAN, 5, 5);
    // Show the smoothed image in the output window
    cvShowImage( "Example2_4-out", out );
    // Be tidy
    cvReleaseImage( &out );
    // Wait for the user to hit a key, then clean up the windows
    cvWaitKey( 0 );
    cvDestroyWindow("Example2_4-in" );
    cvDestroyWindow("Example2_4-out" );
int main( int argc, char** argv )
  argv[1]="E:\lena.jpg";
  IplImage* img = cvLoadImage( argv[1] );
  cvNamedWindow("Example1", CV_WINDOW_AUTOSIZE );
  cvShowImage("Example1", img );
  example2_4( img );
  cvWaitKey(0);
  cvReleaseImage( &img );
  cvDestroyWindow("Example1");
cvShowImage()和学习笔记之初试中无异,cvCreateImage()来为新的帧分配空间且只分配一帧图像的空间,再次调用时覆盖前一次的数据(这样每次调用返回的指针是一样的)。
cvGetsize(image)获得CvSize结构,第一个参数说明里当前图像的结构大学结构,第二个参数告诉了我们各通道每个像素点的数据类型,最后一个参数说明了通道的总数。程序中图像通道是3个(每个通道为8位)。图像大小同image。
该例程为平滑处理函数,通过使用每个像素周围3*3区域进行高斯平滑处理。
#include "stdafx.h"
#include "cv.h"
#include <cxcore.h>
IplImage* doPyrDown(
  IplImage* in,
  int       filter = IPL_GAUSSIAN_5x5)
   // Best to make sure input image is divisible by two.
    assert( in->width%2 == 0 && in->height%2 == 0 );
        cvSize( in->width/2, in->height/2 ),
        in->depth,
        in->nChannels
    cvPyrDown( in, out );
    return( out );
  IplImage* img2 = cvCreateImage(
cvSize( img->width/2,img->height/2 ),
img->depth, img->nChannels);
  cvNamedWindow("Example2", CV_WINDOW_AUTOSIZE );
  img2 = doPyrDown( img );
  cvShowImage("Example2", img2 );
  cvWaitKey(0);
  cvReleaseImage( &img2 );
  cvDestroyWindow("Example2");
#include "stdafx.h"
#include "cv.h"
#include <cxcore.h>
IplImage* doCanny(
    IplImage* in,
    double    lowThresh,
    double    highThresh,
    double    aperture)
    if (in->nChannels != 1)
        return(0);
// Canny only handles gray scale images
        cvGetSize( in ),
        in->depth,
//        IPL_DEPTH_8U,
        1);
    cvCanny( in, out, lowThresh, highThresh, aperture );
        return( out );
  IplImage* img_rgb = cvLoadImage( argv[1] );
  IplImage* img_gry = cvCreateImage(
cvSize( img_rgb->width,img_rgb->height ),
img_rgb->depth,
1);
  cvCvtColor(img_rgb, img_gry ,CV_BGR2GRAY);
  cvNamedWindow("Example Gray", CV_WINDOW_AUTOSIZE );
  cvNamedWindow("Example Canny", CV_WINDOW_AUTOSIZE );
  cvShowImage("Example Gray", img_gry );
  IplImage* img_cny = doCanny( img_gry, 10, 100, 3 );
  cvShowImage("Example Canny", img_cny );
  cvWaitKey(0);
  cvReleaseImage( &img_rgb);
  cvReleaseImage( &img_gry);
  cvReleaseImage( &img_cny);
  cvDestroyWindow("Example Gray");
  cvDestroyWindow("Example Canny");
#include "stdafx.h"
#include "cv.h"
#include <cxcore.h>
IplImage* doCanny(
    IplImage* in,
    double    lowThresh,
    double    highThresh,
    double    aperture)
        cvGetSize( in ),
        in->depth,
        //IPL_DEPTH_8U,
        1);
    return( out );
  IplImage* in,
    //  assert( in->width%2 == 0 && in->height%2 == 0 );
        in->depth,
        in->nChannels
    return( out );
  IplImage* img_rgb  = cvLoadImage("E:\\lena.jpg");
  IplImage* img_gry  = cvCreateImage( cvSize( img_rgb->width,img_rgb->height ), img_rgb->depth, 1);
  IplImage* img_pyr  = doPyrDown( img_gry, IPL_GAUSSIAN_5x5 );
  IplImage* img_pyr2 = doPyrDown( img_pyr, IPL_GAUSSIAN_5x5 );
  IplImage* img_cny  = doCanny( img_pyr2, 10, 100, 3 );
  cvNamedWindow("Example Pyr", CV_WINDOW_AUTOSIZE );
  cvShowImage("Example Pyr", img_pyr2 );
  cvWaitKey(0);
  cvReleaseImage( &img_pyr);
  cvReleaseImage( &img_pyr2);
  cvDestroyWindow("Example Pyr");
评分
参与人数 1 +3 收起 理由
弘毅 + 3 赞一个!
查看全部评分
GMT+8, 2024-4-18 10:22 , Processed in 0.037910 second(s), 20 queries .
