arduino从1.6.2开始支持将float、int、字符串写入、读出EEPROM。
其中eepom——put实例如下
- eeprom_put example.
- This shows how to use the EEPROM.put() method.
- Also, this sketch will pre-set the EEPROM data for the
- example sketch eeprom_get.
- Note, unlike the single byte version EEPROM.write(),
- the put method will use update semantics. As in a byte
- will only be written to the EEPROM if the data is actually
- different.
- Written by Christopher Andrews 2015
- Released under MIT licence.
- #include <EEPROM.h>
- struct MyObject{
- float field1;
- byte field2;
- char name[10];
- void setup(){
- Serial.begin(9600);
- while (!Serial) {
- ; // wait for serial port to connect. Needed for Leonardo only
- float f = 123.456f; //Variable to store in EEPROM.
- int eeAddress = 0; //Location we want the data to be put.
- //One simple call, with the address first and the object second.
- EEPROM.put( eeAddress, f );
- Serial.println("Written float data type!");
- /** Put is designed for use with custom structures also. **/
- //Data to store.
- MyObject customVar = {
- 3.14f,
- 65,
- "Working!"
- eeAddress += sizeof(float); //Move address to the next byte after float 'f'.
- EEPROM.put( eeAddress, customVar );
- Serial.print( "Written custom data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!" );
- void loop(){ /* Empty loop */ }
eeprom-get 实例
- eeprom_get example.
- This shows how to use the EEPROM.get() method.
- To pre-set the EEPROM data, run the example sketch eeprom_put.
- This sketch will run without it, however, the values shown
- will be shown from what ever is already on the EEPROM.
- This may cause the serial object to print out a large string
- of garbage if there is no null character inside one of the strings
- loaded.
- void setup(){
- float f = 0.00f; //Variable to store data read from EEPROM.
- int eeAddress = 0; //EEPROM address to start reading from
- Serial.begin( 9600 );
- while (!Serial) {
- Serial.print( "Read float from EEPROM: " );
- //Get the float data from the EEPROM at position 'eeAddress'
- EEPROM.get( eeAddress, f );
- Serial.println( f, 3 ); //This may print 'ovf, nan' if the data inside the EEPROM is not a valid float.
- As get also returns a reference to 'f', you can use it inline.
- E.g: Serial.print( EEPROM.get( eeAddress, f ) );
- Get can be used with custom structures too.
- I have separated this into an extra function.
- secondTest(); //Run the next test.
- struct MyObject{
- float field1;
- byte field2;
- char name[10];
- void secondTest(){
- int eeAddress = sizeof(float); //Move address to the next byte after float 'f'.
- MyObject customVar; //Variable to store custom object read from EEPROM.
- EEPROM.get( eeAddress, customVar );
- Serial.println( "Read custom object from EEPROM: " );
- Serial.println( customVar.field1 );
- Serial.println( customVar.field2 );
- Serial.println( customVar.name );
复制代码 |
