查看: 12516|回复: 2
关于Arduino的EthernetShield和Processing的问题
发表于 2015-4-18 22:06:27 | 显示全部楼层 |阅读模式
最近买了一块EthernetShield盾板,然后直接参考例程UDPSendReceive.pde:
其中有一段与Processing互动的代码如下(在processing中编译):
  Processing sketch to run with this example
// Processing UDP example to send and receive string data from Arduino
// press any key to send the "Hello Arduino" message
// import hypermedia.net.*;
UDP udp;  // define the UDP object
udp = new UDP( this, 6000 );  // create a new datagram connection on port 6000
//udp.log( true );         // <-- printout the connection activity
udp.listen( true );           // and wait for incoming message
void draw()
void keyPressed() {
String ip       = "192.168.1.177"; // the remote IP address
int port        = 8888;        // the destination port
udp.send("Hello World", ip, port );   // the message to send
void receive( byte[] data ) {          // <-- default handler
//void receive( byte[] data, String ip, int port ) {   // <-- extended handler
for(int i=0; i < data.length; i++)
print(char(data));
println();
在processing中编译通不过,No library found for hypermedia.net
Libraries must be installed in a folder named 'libraries' inside the 'sketchbook' folder.
哪位朋友知道hypermedia.net怎么获取啊?
在Processing自动获取的lib管理器里面没有找到这个hypermedia的东东
发表于 2015-4-19 06:51:25 | 显示全部楼层
bing 中搜一下“hypermedia.net”
得到“www.ubaa.net/shared/processing/u ... java/hypermedia/...
发表于 2016-5-19 09:04:17 | 显示全部楼层
你好 请问你那个库找到了吗 能不能分享一下 我最近打不开那个连接
GMT+8, 2024-4-25 17:55 , Processed in 0.046660 second(s), 19 queries .
