下面是一个获得 USB 键盘数据的例子【参考1】。原理上说,是将键盘切换为 Boot Protocol 这样就避免了需要具体解析HID的麻烦。
- /* MAX3421E USB Host controller LCD/keyboard demonstration */
- //#include <Spi.h>
- #include "Max3421e.h"
- #include "Usb.h"
- /* keyboard data taken from configuration descriptor */
- #define KBD_ADDR 1
- #define KBD_EP 1
- #define KBD_IF 0
- #define EP_MAXPKTSIZE 8
- #define EP_POLL 0x0a
- // macros to identify special charaters(other than Digits and Alphabets)
- #define BANG (0x1E)
- #define AT (0x1F)
- #define POUND (0x20)
- #define DOLLAR (0x21)
- #define PERCENT (0x22)
- #define CAP (0x23)
- #define AND (0x24)
- #define STAR (0x25)
- #define OPENBKT (0x26)
- #define CLOSEBKT (0x27)
- #define RETURN (0x28)
- #define ESCAPE (0x29)
- #define BACKSPACE (0x2A)
- #define TAB (0x2B)
- #define SPACE (0x2C)
- #define HYPHEN (0x2D)
- #define EQUAL (0x2E)
- #define SQBKTOPEN (0x2F)
- #define SQBKTCLOSE (0x30)
- #define BACKSLASH (0x31)
- #define SEMICOLON (0x33)
- #define INVCOMMA (0x34)
- #define TILDE (0x35)
- #define COMMA (0x36)
- #define PERIOD (0x37)
- #define FRONTSLASH (0x38)
- #define DELETE (0x4c)
- /* Modifier masks. One for both modifiers */
- #define SHIFT 0x22
- #define CTRL 0x11
- #define ALT 0x44
- #define GUI 0x88
- /* "Sticky keys */
- #define CAPSLOCK (0x39)
- #define NUMLOCK (0x53)
- #define SCROLLLOCK (0x47)
- /* Sticky keys output report bitmasks */
- #define bmNUMLOCK 0x01
- #define bmCAPSLOCK 0x02
- #define bmSCROLLLOCK 0x04
- EP_RECORD ep_record[ 2 ]; //endpoint record structure for the keyboard
- char buf[ 8 ] = { 0 }; //keyboard buffer
- char old_buf[ 8 ] = { 0 }; //last poll
- /* Sticky key state */
- bool numLock = false;
- bool capsLock = false;
- bool scrollLock = false;
- bool line = false;
- void setup();
- void loop();
- MAX3421E Max;
- USB Usb;
- void setup() {
- Serial.begin( 9600 );
- Serial.println("Start");
- Max.powerOn();
- delay( 200 );
- void loop() {
- Max.Task();
- Usb.Task();
- if( Usb.getUsbTaskState() == USB_STATE_CONFIGURING ) {
- //wait for addressing state
- kbd_init();
- Usb.setUsbTaskState( USB_STATE_RUNNING );
- if( Usb.getUsbTaskState() == USB_STATE_RUNNING ) {
- //poll the keyboard
- kbd_poll();
- /* Initialize keyboard */
- void kbd_init( void )
- byte rcode = 0; //return code
- /* Initialize data structures */
- ep_record[ 0 ] = *( Usb.getDevTableEntry( 0,0 ));
- //copy endpoint 0 parameters
- ep_record[ 1 ].MaxPktSize = EP_MAXPKTSIZE;
- ep_record[ 1 ].Interval = EP_POLL;
- ep_record[ 1 ].sndToggle = bmSNDTOG0;
- ep_record[ 1 ].rcvToggle = bmRCVTOG0;
- Usb.setDevTableEntry( 1, ep_record );
- //plug kbd.endpoint parameters to devtable
- /* Configure device */
- rcode = Usb.setConf( KBD_ADDR, 0, 1 );
- if( rcode ) {
- Serial.print("Error attempting to configure keyboard. Return code :");
- Serial.println( rcode, HEX );
- while(1); //stop
- /* Set boot protocol */
- rcode = Usb.setProto( KBD_ADDR, 0, 0, 0 );
- if( rcode ) {
- Serial.print("Error attempting to configure boot protocol. Return code :");
- while( 1 ); //stop
- delay(2000);
- Serial.println("Keyboard initialized");
- /* Poll keyboard and print result */
- /* buffer starts at position 2, 0 is modifier key state and 1 is irrelevant */
- void kbd_poll( void )
- char i;
- static char leds = 0;
- /* poll keyboard */
- rcode = Usb.inTransfer( KBD_ADDR, KBD_EP, 8, buf );
- if( rcode != 0 ) {
- return;
- }//if ( rcode..
- for( i = 2; i < 8; i++ ) {
- if( buf[ i ] == 0 ) { //end of non-empty space
- break;
- if( buf_compare( buf[ i ] ) == false ) { //if new key
- switch( buf[ i ] ) {
- case CAPSLOCK:
- capsLock =! capsLock;
- leds = ( capsLock ) ? leds |= bmCAPSLOCK : leds &= ~bmCAPSLOCK;
- // set or clear bit 1 of LED report byte
- break;
- case NUMLOCK:
- numLock =! numLock;
- leds = ( numLock ) ? leds |= bmNUMLOCK : leds &= ~bmNUMLOCK;
- // set or clear bit 0 of LED report byte
- break;
- case SCROLLLOCK:
- scrollLock =! scrollLock;
- leds = ( scrollLock ) ? leds |= bmSCROLLLOCK : leds &= ~bmSCROLLLOCK;
- // set or clear bit 2 of LED report byte
- break;
- case DELETE:
- line = false;
- break;
- case RETURN:
- line =! line;
- break;
- default:
- //Serial.print(HIDtoA( buf[ i ], buf[ 0 ] ));
- break;
- }//switch( buf[ i ...
- Serial.print(buf[ i ],HEX);
- Serial.print(' ');
- Serial.println(buf[ 0 ],HEX);
- rcode = Usb.setReport( KBD_ADDR, 0, 1, KBD_IF, 0x02, 0, &leds );
- if( rcode ) {
- Serial.print("Set report error: ");
- }//if( rcode ...
- }//if( buf_compare( buf[ i ] ) == false ...
- }//for( i = 2...
- for( i = 2; i < 8; i++ ) { //copy new buffer to old
- old_buf[ i ] = buf[ i ];
- /* compare byte against bytes in old buffer */
- bool buf_compare( byte data )
- char i;
- if( old_buf[ i ] == data ) {
- return( true );
- return( false );
- /* HID to ASCII converter. Takes HID keyboard scancode, returns ASCII code */
- byte HIDtoA( byte HIDbyte, byte mod )
- /* upper row of the keyboard, numbers and special symbols */
- if( HIDbyte >= 0x1e && HIDbyte <= 0x27 ) {
- if(( mod & SHIFT ) || numLock ) { //shift key pressed
- switch( HIDbyte ) {
- case BANG: return( 0x21 );
- case AT: return( 0x40 );
- case POUND: return( 0x23 );
- case DOLLAR: return( 0x24 );
- case PERCENT: return( 0x25 );
- case CAP: return( 0x5e );
- case AND: return( 0x26 );
- case STAR: return( 0x2a );
- case OPENBKT: return( 0x28 );
- case CLOSEBKT: return( 0x29 );
- }//switch( HIDbyte...
- else { //numbers
- if( HIDbyte == 0x27 ) { //zero
- return( 0x30 );
- else {
- return( HIDbyte + 0x13 );
- }//numbers
- }//if( HIDbyte >= 0x1e && HIDbyte <= 0x27
- /* number pad. Arrows are not supported */
- if(( HIDbyte >= 0x59 && HIDbyte <= 0x61 ) &&
- ( numLock == true )) { // numbers 1-9
- return( HIDbyte - 0x28 );
- if(( HIDbyte == 0x62 ) && ( numLock == true )) { //zero
- return( 0x30 );
- /* Letters a-z */
- if( HIDbyte >= 0x04 && HIDbyte <= 0x1d ) {
- if((( capsLock == true ) && ( mod & SHIFT ) == 0 )
- || (( capsLock == false ) && ( mod & SHIFT ))) {
- //upper case
- return( HIDbyte + 0x3d );
- else { //lower case
- return( HIDbyte + 0x5d );
- }//if( HIDbyte >= 0x04 && HIDbyte <= 0x1d...
- /* Other special symbols */
- if( HIDbyte >= 0x2c && HIDbyte <= 0x38 ) {
- case SPACE: return( 0x20 );
- case HYPHEN:
- if(( mod & SHIFT ) == false ) {
- return( 0x2d );
- else {
- return( 0x5f );
- case EQUAL:
- return( 0x3d );
- else {
- return( 0x2b );
- case SQBKTOPEN:
- return( 0x5b );
- else {
- return( 0x7b );
- case SQBKTCLOSE:
- return( 0x5d );
- else {
- return( 0x7d );
- case BACKSLASH:
- return( 0x5c );
- else {
- return( 0x7c );
- case SEMICOLON:
- return( 0x3b );
- else {
- return( 0x3a );
- case INVCOMMA:
- return( 0x27 );
- else {
- return( 0x22 );
- case TILDE:
- return( 0x60 );
- else {
- return( 0x7e );
- case COMMA:
- return( 0x2c );
- else {
- return( 0x3c );
- case PERIOD:
- return( 0x2e );
- else {
- return( 0x3e );
- case FRONTSLASH:
- return( 0x2f );
- else {
- return( 0x3f );
- default:
- break;
- }//if( HIDbye >= 0x2d && HIDbyte <= 0x38..
- return( 0 );
实验依然使用上一次的USB小键盘。上面的按键分布如下:
关于键值的介绍可以在【参考2】找到
NumLock OFF的情况下,各输出键值:
*输出三次62,相当于输出3个0
NumLock ON的情况下,各输出键值:
*输出三次62外加一个53
运行结果
本文完整代码下载 LCDkbd
参考:
1. https://github.com/felis/USB_Hos ... s/descriptor_parser USB_Host_Shield/examples/LCDkbd/
2. http://www.quadibloc.com/comp/scan.htm
本文首发 http://www.lab-z.com/usbkb/ |
