可以正常使用的APC220收发程序。多次测试没有问题。。。
但是将接收程序与mpu6050的滤波程序结合起来以后就得不到发送的值。大家帮忙看看,找找原因。 - /* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics. All rights reserved.
- This software may be distributed and modified under the terms of the GNU
- General Public License version 2 (GPL2) as published by the Free Software
- Foundation and appearing in the file GPL2.TXT included in the packaging of
- this file. Please note that GPL2 Section 2[b] requires that all works based
- on this software must also be made publicly available under the terms of
- the GPL2 ("Copyleft").
- Contact information
- Kristian Lauszus, TKJ Electronics
- Web : http://www.tkjelectronics.com
- e-mail : [email][email protected][/email]
- #include <Wire.h> //mpu6050和arduino通过I2C通信,所以要包含这个库
- #include <Kalman.h> //卡尔曼滤波函数
- #define RESTRICT_PITCH
- Kalman kalmanX; // 对X,Y轴创建卡尔曼实例
- Kalman kalmanY;
- double val,Val=0;
- /* IMU Data */
- double accX, accY, accZ;
- double gyroX, gyroY, gyroZ;//从mpu6050读出的六个数据
- double gyroXangle, gyroYangle; // Angle calculate using the gyro only
- double compAngleX, compAngleY; // Calculated angle using a complementary filter
- double kalAngleX, kalAngleY; // Calculated angle using a Kalman filter
- double angleX, angleY, angle, angleZ; //finall angle
- uint32_t timer;
- uint8_t i2cData[14]; // Buffer for I2C data
- // TODO: Make calibration routine
- void setup() {
- Serial.begin(9600);
- //if (Serial.available() > 0)
- //val = Serial.read();
- Wire.begin();
- #if ARDUINO >= 157
- Wire.setClock(400000UL); // Set I2C frequency to 400kHz
- #else
- TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz
- #endif
- i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
- i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
- i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
- i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
- while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once
- while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
- while (i2cRead(0x75, i2cData, 1));
- if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register
- Serial.print(F("Error reading sensor"));
- while (1);
- delay(100); // Wait for sensor to stabilize
- /* Set kalman and gyro starting angle */
- while (i2cRead(0x3B, i2cData, 6));
- accX = (i2cData[0] << 8) | i2cData[1];
- accY = (i2cData[2] << 8) | i2cData[3];
- accZ = (i2cData[4] << 8) | i2cData[5];
- // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26
- // atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
- // It is then converted from radians to degrees
- #ifdef RESTRICT_PITCH // Eq. 25 and 26
- double roll = atan2(accY, accZ) * RAD_TO_DEG;
- double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
- #else // Eq. 28 and 29
- double roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
- double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
- #endif
- kalmanX.setAngle(roll); // Set starting angle
- kalmanY.setAngle(pitch);
- gyroXangle = roll;
- gyroYangle = pitch;
- compAngleX = roll;
- compAngleY = pitch;
- //Calibration();
- timer = micros();
- void loop() {
- // val = Serial.read();
- double ret(double x);
- /* Update all the values */
- while (i2cRead(0x3B, i2cData, 14));
- accX = ((i2cData[0] << 8) | i2cData[1]);
- accY = ((i2cData[2] << 8) | i2cData[3]);
- accZ = ((i2cData[4] << 8) | i2cData[5]);
- //tempRaw = (i2cData[6] << 8) | i2cData[7];
- gyroX = (i2cData[8] << 8) | i2cData[9];
- gyroY = (i2cData[10] << 8) | i2cData[11];
- gyroZ = (i2cData[12] << 8) | i2cData[13];
- double dt = (double)(micros() - timer) / 1000000; // Calculate delta time
- timer = micros();
- #endif
- double gyroXrate = gyroX / 131.0; // Convert to deg/s
- double gyroYrate = gyroY / 131.0; // Convert to deg/s
- // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
- if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
- kalAngleX = roll;
- } else
- kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
- if (abs(kalAngleX) > 90)
- gyroYrate = -gyroYrate; // Invert rate, so it fits the restriced accelerometer reading
- kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);
- #else
- if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
- kalAngleY = pitch;
- } else
- kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
- if (abs(kalAngleY) > 90)
- gyroXrate = -gyroXrate; // Invert rate, so it fits the restriced accelerometer reading
- #endif
- gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
- gyroYangle += gyroYrate * dt;
- angle += gyroZ * dt / 131.0;
- gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate
- gyroYangle += kalmanY.getRate() * dt;
- compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
- compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
- // Reset the gyro angle when it has drifted too much
- if (gyroXangle < -180 || gyroXangle > 180)
- gyroXangle = kalAngleX;
- if (gyroYangle < -180 || gyroYangle > 180)
- gyroYangle = kalAngleY;
- angleX = kalAngleX - 2.32;
- angleY = kalAngleY + 0.38;
- angleZ = angle + 5;
- Val = ret(val);
- /* Print Data */
- #if 0 // Set to 1 to activate
- Serial.print(accX); Serial.print(",");
- Serial.print(accY); Serial.print(",");
- Serial.print(accZ); Serial.print(",");
- //Serial.print(tempRaw); Serial.print(",");
- Serial.print(gyroX / 131.0); Serial.print(",");
- Serial.print(gyroY / 131.0); Serial.print(",");
- Serial.print(gyroZ / 131.0); Serial.print(",");
- Serial.print("\t");
- #endif
- Serial.println(Val);// Serial.print(",");
- //Serial.print(roll); Serial.print("\t");
- //Serial.print(gyroXangle); Serial.print("\t");
- //Serial.print(compAngleX); Serial.print("\t");
- //Serial.print(angleX); Serial.print(",");
- //Serial.print("\t");
- //Serial.print(pitch); Serial.print("\t");
- //Serial.print(gyroYangle); Serial.print("\t");
- //Serial.print(compAngleY); Serial.print("\t");
- //Serial.print(angleY); Serial.print(",");
- //Serial.print(angleZ); Serial.println(",");
- if(Serial.available()>0){
- x=Serial.read();
- return(x);
复制代码 还有一个I2C的文件
const uint8_t IMUAddress = 0x68; // AD0 is logic low on the PCB
const uint16_t I2C_TIMEOUT = 1000; // Used to check for errors in I2C communication
uint8_t i2cWrite(uint8_t registerAddress, uint8_t data, bool sendStop) {
return i2cWrite(registerAddress, &data, 1, sendStop); // Returns 0 on success
uint8_t i2cWrite(uint8_t registerAddress, uint8_t *data, uint8_t length, bool sendStop) {
Wire.beginTransmission(IMUAddress);
Wire.write(registerAddress);
Wire.write(data, length);
uint8_t rcode = Wire.endTransmission(sendStop); // Returns 0 on success
if (rcode) {
Serial.print(F("i2cWrite failed: "));
Serial.println(rcode);
return rcode; // See: http://arduino.cc/en/Reference/WireEndTransmission
uint8_t i2cRead(uint8_t registerAddress, uint8_t *data, uint8_t nbytes) {
uint32_t timeOutTimer;
uint8_t rcode = Wire.endTransmission(false); // Don't release the bus
if (rcode) {
Serial.print(F("i2cRead failed: "));
Wire.requestFrom(IMUAddress, nbytes, (uint8_t)true); // Send a repeated start and then release the bus after reading
for (uint8_t i = 0; i < nbytes; i++) {
if (Wire.available())
data = Wire.read();
else {
timeOutTimer = micros();
while (((micros() - timeOutTimer) < I2C_TIMEOUT) && !Wire.available());
data = Wire.read();
else {
Serial.println(F("i2cRead timeout"));
return 5; // This error value is not already taken by endTransmission
return 0; // Success
还有两个.h和.cpp文件,以及上面的程序我都做个打包压缩。 |
