发表于 2016-9-9 11:05:43
显示全部楼层
楼主你好,用了你的方法装好了驱动,能搜到网络了,但是连不上是什么原因?- pi@raspberrypi:~ $ hwinfo --netcard
- 01: USB 00.0: 0200 Ethernet controller
- [Created at usb.122]
- Unique ID: lfzD.Sed3PcmdZ23
- Parent ID: ADDn.IKhPgutgmvF
- SysFS ID: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0
- SysFS BusID: 1-1.1:1.0
- Hardware Class: network
- Model: "Standard Microsystems Ethernet controller"
- Hotplug: USB
- Vendor: usb 0x0424 "Standard Microsystems Corp."
- Device: usb 0xec00
- Revision: "2.00"
- Driver: "smsc95xx"
- Driver Modules: "smsc95xx"
- Device File: eth0
- Speed: 480 Mbps
- HW Address: b8:27:eb:7b:38:06
- Link detected: yes
- Module Alias: "usb:v0424pEC00d0200dcFFdsc00dp01icFFisc00ipFFin00"
- Config Status: cfg=new, avail=yes, need=no, active=unknown
- Attached to: #8 (Hub)
- 02: USB 00.0: 0282 WLAN controller
- Unique ID: BobO.eL1gmsHjN_0
- SysFS ID: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0
- SysFS BusID: 1-1.2:1.0
- Model: "Realtek 802.11n NIC"
- Hotplug: USB
- Vendor: usb 0x0bda "Realtek Semiconductor Corp."
- Device: usb 0x818b "802.11n NIC"
- Revision: "2.00"
- Serial ID: "00e04c000001"
- Driver: "rtl8192eu"
- Driver Modules: "8192eu"
- Device File: wlan0
- Features: WLAN
- Speed: 480 Mbps
- HW Address: 3c:46:d8:db:e0:4c
- Link detected: no
- WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13
- WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472
- WLAN bitrates: 1 2 5.5 11
- WLAN encryption modes: TKIP CCMP
- WLAN authentication modes: open wpa-psk wpa-eap
- Module Alias: "usb:v0BDAp818Bd0200dc00dsc00dp00icFFiscFFipFFin00"
- Driver Info #0:
- Driver Status: 8192eu is active
- Driver Activation Cmd: "modprobe 8192eu"
- pi@raspberrypi:~ $ iwconfig
- wlan0 unassociated Nickname:"<WIFI@REALTEK>"
- Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
- Sensitivity:0/0
- Retry:off RTS thr:off Fragment thr:off
- Power Management:off
- Link Quality:0 Signal level:0 Noise level:0
- Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
- Tx excessive retries:0 Invalid misc:0 Missed beacon:0
- lo no wireless extensions.
- eth0 no wireless extensions.
- pi@raspberrypi:~ $ sudo iw dev wlan0 connect ChinaNet
- command failed: No such device (-19)
报错command failed: No such device (-19) |
