楼主: 幻生幻灭
703N刷机必备网站 openwrt.org
发表于 2012-9-13 16:08:14 | 显示全部楼层 |阅读模式
我就是个打酱油的,看到新版到此一游{:soso_e113:}
简介翻译粗陋,敬请谅解
https://openwrt.org/
简介:
OpenWrt是用于嵌入式设备的一个Linux分支。
OpenWrt提供了一套完全可修改的封包管理文件系统,而不是一套固定的固件。这样大家就可以灵活的从供应商选择硬件或者自定义设备,并进行应用程序的选择和配置,从而实现各种应用。
对于开发者而言,只需用OpenWrt的框架来构建应用程序,而无需建立一个完整的固件
对于用户来说,这意味着完全定制的能力,以全新的方式使用该设备。
OpenWrt is described as a Linux distribution for embedded devices.
Instead of trying to create a single, static firmware, OpenWrt provides a fully writable filesystem with package management. This frees you from the application selection and configuration provided by the vendor and allows you to customize the device through the use of packages to suit any application. For developer, OpenWrt is the framework to build an application without having to build a complete firmware around it; for users this means the ability for full customization, to use the device in ways never envisioned.
TP家的产品支持很多,例如最经典的703N
更多支持厂家清单,参考链接:http://wiki.openwrt.org/toh/start
关于703N
http://wiki.openwrt.org/toh/tp-link/tl-wr703n
TP-Link TL-WR703N
The TL-WR703N is marketed as a "3G travel router". It does not include a 3G modem - it simply means that the OEM firmware supports USB 3G modems, and that the oem firmware contains drivers for USB modems! Ridiculous, since with OpenWrt ANY router with USB supports 3G hardware…
The device was released in August 2011 in China.
Features
Atheros AR7240 CPU (400Mhz)
Atheros AR9331 Chipset (integrated wireless)
802.11 b/g/n 150Mbps (130Mbps real)
wireless power output 20dBm - 100mW
4 MB flash memory
32 MB RAM
USB 2.0 port
Powered via micro-USB socket
Tiny form factor: 5.7cm x 5.7cm
 楼主| 发表于 2012-9-13 16:32:18 | 显示全部楼层
大概看了下,貌似
GPIO9  TP_IN  is RX
GPIO10 TP_OUT is TX
发表于 2012-9-13 23:24:47 | 显示全部楼层
又开了一个新板块,谁来主持的呢?
 楼主| 发表于 2012-9-13 23:27:05 | 显示全部楼层
Randy 发表于 2012-9-13 23:24
又开了一个新板块,谁来主持的呢?
呵呵,下午群里讨论703N来着,然后就开新版了,据说有高手哈
发表于 2012-9-13 23:36:09 | 显示全部楼层
我OUT了,最近自己在恶补模电,没时间和你们一起吹牛了,伤心啊!!!!!!啊啊啊啊啊啊!!
 楼主| 发表于 2012-9-19 19:27:16 | 显示全部楼层
冷场了...
更新下资源,计划年底等703泛滥了在开始玩,嘎嘎
http://www.kean.com.au/oshw/WR703N/
http://hackaday.com/2012/06/24/i ... -cheap-wifi-router/
发表于 2012-9-29 14:03:36 | 显示全部楼层
求加群~最近也在研究703n刷机!
发表于 2012-10-8 16:37:06 | 显示全部楼层
这版好冷清
703n 官方固件链接 404 了,谁有备份?
发表于 2012-10-8 18:34:25 | 显示全部楼层
额。。。我的703N还没开始刷。。。没舍得拆
发表于 2012-10-21 13:32:22 | 显示全部楼层
图上的第一个路由已经被我刷过openwrt,换bios芯片的时候估计被我焊断线了。重新再买了第二个路由,准备再来过,有点担心,焊工不怎么样,哈哈。
发表于 2012-10-21 22:08:22 | 显示全部楼层
今天下午重新刷了一下带UBOOT的固件,发现8M的OPENWRT可以用了。原来自己之前编程器刷的是不带uboot,换了个固件就复活了,真开心。现在有两个703N可以折腾,而且这样换固件芯片也方便,呵呵。
发表于 2012-10-23 22:16:46 | 显示全部楼层
新发现的站点,原来703n真的是到处DIY,呵呵,我店内出售改好的703机器,欢迎大家来骚扰
淘宝地址http://jjwifi.taobao.com
发表于 2012-11-13 11:11:40 | 显示全部楼层
我有改好的,改进了 8M 64M sam天线 miniUSB供电+串口一线通,保留外壳,改机十分美观。
发表于 2012-11-16 08:38:01 | 显示全部楼层
下周买个来玩玩
发表于 2014-1-17 10:46:30 | 显示全部楼层
703到手没两天  不知道那短路了 直接废了
GMT+8, 2024-3-29 19:19 , Processed in 0.044485 second(s), 27 queries .
