查看: 9866|回复: 0
认识AWG标准
发表于 2012-9-24 21:13:47 | 显示全部楼层 |阅读模式
美国线规(英文是American wire gauge,缩写为AWG),是一种区分导线直径的标准,又被称为 Brown & Sharpe线规。这种标准化线规系统于1857年起在美国开始使用。
导线的直径与导线承载电流的能力有很大关系。线规数字越小,表示线材直径越粗,所能承载的电流就越大;反之,线规数字越大,表示线材直径越细,所能承载的电流就越小。
AWG表适用于单根、实心、圆形的导线。双绞线的AWG值由所有导线的总横截面积决定,并且由于双绞线之间总是有一些空隙,导致相同的AWG值双绞线的直径总是略大于单根导线的直径。
AWG数值应作为基本数值标注于数据线上。例如,组网使用的五类非屏蔽双绞线一般使用AWG 24的线材,而SATA线一般是AWG 26线材。
表格中的数据包括各种导线的阻抗和允许电流大小(安培)。表中的直径数值适用于实心电线。双绞线应当根据铜线横截面面积进行计算。下面的表格适用于直流情况,或者频率小于等于60赫兹的情况,也没有考虑集肤效应。
AWG直径面积阻抗
(inch)(mm)(kcmil)(mm2)(Ω/km)(Ω/kFT)
0000 (4/0)0.4611.6842121070.16080.04901
000 (3/0)0.409610.404168850.20280.0618
00 (2/0)0.36489.26613367.40.25570.07793
0 (1/0)0.32498.25210653.50.32240.09827
10.28937.34883.742.40.40660.1239
20.25766.54466.433.60.51270.1563
30.22945.82752.626.70.64650.197
40.20435.18941.721.20.81520.2485
50.18194.62133.116.81.0280.3133
60.1624.11526.313.31.2960.3951
70.14433.66520.810.51.6340.4982
80.12853.26416.58.372.0610.6282
90.11442.90613.16.632.5990.7921
100.10192.58810.45.263.2770.9989
110.09072.3058.234.174.1321.26
120.08082.0536.533.315.2111.588
130.0721.8285.182.626.5712.003
140.06411.6284.112.088.2862.525
150.05711.453.261.6510.453.184
160.05081.2912.581.3113.174.016
170.04531.152.051.0416.615.064
180.04031.0241.620.82320.956.385
190.03590.9121.290.65326.428.051
200.0320.8121.020.51833.3110.15
210.02850.7230.810.414212.8
220.02530.6440.6420.32652.9616.14
230.02260.5730.5090.25866.7920.36
240.02010.5110.4040.20584.2225.67
250.01790.4550.320.162106.232.37
260.01590.4050.2540.129133.940.81
270.01420.3610.2020.102168.951.47
280.01260.3210.160.081212.964.9
290.01130.2860.1270.0642268.581.84
300.010.2550.1010.0509338.6103.2
310.008930.2270.07970.0404426.9130.1
320.007950.2020.06320.032538.3164.1
330.007080.180.05010.0254678.8206.9
340.00630.160.03980.0201856260.9
350.005610.1430.03150.0161079329
360.0050.1270.0250.01271361414.8
370.004450.1130.01980.011716523.1
380.003970.1010.01570.007972164659.6
390.003530.08970.01250.006322729831.8
400.003140.07990.009890.0050134411049
GMT+8, 2024-4-17 07:05 , Processed in 0.039012 second(s), 17 queries .
