楼主 |
发表于 2015-12-10 18:02:54
显示全部楼层
林定祥 发表于 2015-11-28 23:18
int V=analogRead(V0)*20;
非常感谢答疑
现在又有个问题
原帖地址http://www.arduino.cn/thread-5615-1-1.html
* PID RelayOutput Example
* Same as basic example, except that this time, the output
* is going to a digital pin which (we presume) is controlling
* a relay. the pid is designed to Output an analog value,
* but the relay can only be On/Off.
* to connect them together we use "time proportioning
* control" it's essentially a really slow version of PWM.
* first we decide on a window size (5000mS say.) we then
* set the pid to adjust its output between 0 and that window
* size. lastly, we add some logic that translates the PID
* output into "Relay On Time" with the remainder of the
* window being "Relay Off Time"
PID继电器输出范例
与基本范例相同,这一次输出是一个数字引脚控制的继电器。PID被设计成
输出一个模拟值,但是继电器只有开关状态。
为了联系上两者,我们使用时间比例控制,它本质上是一个很慢的PWM。
首先我们决定一个窗口时间(比如5000ms)。
然后设置PID适应它的输出在0到窗口时间的范围。
最后我们添加一些逻辑,把PID输出转换成“继电器接通时间”和剩余的
“继电器断开时间”
#include <PID_v1.h>
#define RelayPin 8
// 定义我们将要使用的变量
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//指定链接和最初的调优参数
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
int WindowSize = 2000;
unsigned long windowStartTime;
windowStartTime = millis();
//初始化变量
//initialize the variables we're linked to
Setpoint = 100;
//告诉PID在从0到窗口大小的范围内取值
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
//开启PID
//turn the PID on
myPID.SetMode(AUTOMATIC);
Input = analogRead(0);
myPID.Compute();
* turn the output pin on/off based on pid output 基于PID输出,打开或关闭端口输出
if(millis() - windowStartTime>WindowSize)
{ //time to shift the Relay Window 继电器窗口时间
windowStartTime += WindowSize;
if(Output < millis() - windowStartTime) digitalWrite(RelayPin,HIGH);
else digitalWrite(RelayPin,LOW);
新人感到不解的是。此代码。前面已经定义了windowsStartTime=millis了。后面怎么还能用windowsStartTimes-millis呢?(贴中红字和绿字部分)
