发表于 2017-2-20 14:51:15
显示全部楼层
- // 必需用 1.0 版才能過
- #include "U8glib.h"
- // setup u8g object, please remove comment from one of the following constructor calls
- // IMPORTANT NOTE: The complete list of supported devices is here: http://code.google.com/p/u8glib/wiki/device
- //U8GLIB_NHD27OLED_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD27OLED_2X_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD27OLED_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD27OLED_2X_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD31OLED_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD31OLED_2X_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD31OLED_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_NHD31OLED_2X_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGS102 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGM132 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGM128 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_ST7920_128X64 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, U8G_PIN_NONE, U8G_PIN_NONE, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
- //U8GLIB_ST7920_128X64 u8g(18, 16, 17, U8G_PIN_NONE); // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
- //U8GLIB_ST7920_192X32 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, U8G_PIN_NONE, U8G_PIN_NONE, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
- //U8GLIB_ST7920_192X32 u8g(18, 16, 17, U8G_PIN_NONE); // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
- //U8GLIB_ST7920_192X32 u8g(13, 11, 10, U8G_PIN_NONE); // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 10
- //U8GLIB_ST7920_192X32 u8g(10, U8G_PIN_NONE); // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 10, HW SPI
- //U8GLIB_LM6059 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_LM6063 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGXL160_BW u8g(10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGXL160_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGXL160_2X_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_DOGXL160_2X_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_PCD8544 u8g(13, 11, 10, 9, 8); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, Reset = 8
- //U8GLIB_PCF8812 u8g(13, 11, 10, 9, 8); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, Reset = 8
- //U8GLIB_KS0108_128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 14, 15, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs1=14, cs2=15,di=17,rw=16
- //U8GLIB_T6963_240X128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 17, 14, 15, U8G_PIN_NONE, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 wr=en=17, cs=14, a0=di=15,rd=U8G_PIN_NONE,reset=16
- //U8GLIB_LC7981_160X80 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 14, 15, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
- //U8GLIB_LC7981_240X64 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 14, 15, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
- //U8GLIB_LC7981_240X128 u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 14, 15, 17, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs=14 ,di=15,rw=17, reset = 16
- //U8GLIB_ILI9325D_320x240 u8g(18,17,19,U8G_PIN_NONE,16 ); // 8Bit Com: D0..D7: 0,1,2,3,4,5,6,7 en=wr=18, cs=17, rs=19, rd=U8G_PIN_NONE, reset = 16
- //U8GLIB_SBN1661_122X32 u8g(8,9,10,11,4,5,6,7,14,15, 17, U8G_PIN_NONE, 16); ; // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 cs1=14, cs2=15,di=17,rw=16,reset = 16
- //U8GLIB_SSD1306_128X64 u8g(13, 11, 10, 9); // SW SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_SSD1306_128X64 u8g(10, 9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
- //U8GLIB_SSD1309_128X64 u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
- //U8GLIB_SSD1327_96X96_GR u8g(U8G_I2C_OPT_NONE); // I2C
- //U8GLIB_SSD1327_96X96_2X_GR u8g(U8G_I2C_OPT_NONE); // I2C
- //U8GLIB_NHD_C12864 u8g(13, 11, 10, 9, 8); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, RST = 8
- //U8GLIB_NHD_C12832 u8g(13, 11, 10, 9, 8); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, RST = 8
- U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE); //這一行就是定義 SSD1306 的介面方式
- void draw(void) {
- // graphic commands to redraw the complete screen should be placed here
- // assign default font
- u8g.setFont(u8g_font_unifont);
- // pointer to strings in flash memory can be stored in a special type
- const __FlashStringHelper *flash_ptr;
- // the result of the F() macro can be assigned to this pointer
- flash_ptr = F("Hello World!");
- // this pointer can be used as argument to the draw procedures
- u8g.drawStr( 0+1, 20+1, flash_ptr);
- u8g.drawStr( 0, 20, flash_ptr);
- // of course, the F() macro can be used directly
- u8g.drawStr( 0, 40, F("PROGMEM"));
- void setup(void) {
- // flip screen, if required
- // u8g.setRot180();
- void loop(void) {
- // picture loop
- u8g.firstPage();
- do {
- draw();
- } while( u8g.nextPage() );
- // rebuild the picture after some delay
- delay(500);
這是 u8g 庫裡面的範例,我試過可以用 (iic 的 SSD1306 可以正常顯示) |
