用于读取旋转编码器模块
[pre lang="arduino" line="1" file="encoder4.ino"]//非阻塞编码器模块读取,通过编码器按键使能编码器事件,当编码器使能时分别增减计数值。
//未用到中断,通过轮询读取编码器,周期5ms,编码器旋钮模块用,更高线数的编码器需要中断读。
#include "key.h" //按键检测宏
#include "edge.h" //边沿检测宏
#include "encoder.h" //编码器检测宏
#define pinA 2 //编码器A相
#define pinB 3 //编码器B相
#define pinK 4 //编码器按键
int count = 0; //编码器计数值
bool en = true; //编码器使能标志
pinMode(pinK, INPUT_PULLUP); //编码器按键设为内部上拉
Serial.println("Ready");
/*readKey(enable,cycleTime,x,no,onTrigger,onPop) (使能,扫描周期,端口,信号是否反向,上升沿执行动作,下降沿执行动作)
按键使能,20ms扫描一次,4号端口,不反向,每次按下时把编码器使能标志反向,弹起时不动作*/
readKey(true, 20, pinK, false, if (en ^= true) {
Serial.println("Encoder enable");
} else {
Serial.println("Encoder unable");
}, void());
/*readEncoder(enable,cycleTime,pinA,pinB,incEvent,dincEvent (使能,扫描周期,A相端口,B相端口,计数增执行动作,计数减沿执行动作)
编码器根据使能信号en启动,5ms扫描一次,2、3端口,分别增减计数值*/
readEncoder(en, 5, pinA, pinB, Serial.println(++count), Serial.println(--count));
}[/code]
[pre lang="arduino" line="1" file="edge.h"]#ifndef __EDGE_H__
#define __EDGE_H__
//逻辑量的四种状态:低,上升,高,低
enum edgeSta {low, trg, high, pop};
//宏名:edge。 返回值:逻辑量状态。输入参数:bool值 用途:检测逻辑量的边沿。
#define edge(ReadData) ({\
static bool Trg = false;\
static bool Cont = false;\
static bool Pop = false;\
Trg = ReadData & (ReadData ^ Cont); \
Pop = Cont != ReadData & !Trg; \
Cont = ReadData; \
enum edgeSta sta = low;\
if (Cont) {\
sta = high;\
} else {\
sta = low;\
if (Trg) {\
sta = trg;\
if (Pop) {\
sta = pop;\
sta;\
#endif[/code]
[pre lang="arduino" line="1" file="encoder.h"]#ifndef __ENCODER_H__
#define __ENCODER_H__
#include "edge.h"
#include "key.h"
//readEncoder(enable,cycleTime,pinA,pinB,incEvent,dincEvent (使能,扫描周期,A相端口,B相端口,计数增执行动作,计数减沿执行动作)
#define readEncoder(enable,cycleTime,pinA,pinB,incEvent,dincEvent)({\
static bool no=false;\
if(edge(enable)==trg){\
pinMode(pinA, INPUT);\
pinMode(pinB, INPUT);\
no = !digitalRead(pinA);\
readKey(enable,cycleTime,pinA, no, if (digitalRead(pinB)^no) {incEvent;} else {dincEvent;}, if (digitalRead(pinB)^no) {dincEvent;} else {incEvent;});\
#endif[/code]
[pre lang="arduino" line="1" file="key.h"]#ifndef __KEY_H__
#define __KEY_H__
#include "edge.h"
//readKey(enable,cycleTime,x,no,onTrigger,onPop) (使能,扫描周期,端口,信号是否反向,上升沿执行动作,下降沿执行动作)
#define readKey(enable,cycleTime,x,no,onTrigger,onPop) do{\
static unsigned long timdel = millis();\
switch(edge(enable)){\
case trg:\
Trg = false;\
Cont = false;\
Pop = false;\
timdel = millis();\
break;\
case high:\
if (millis() - timdel >= cycleTime) {\
bool ReadData = !digitalRead(x)^no;\
Cont = ReadData; \
if (Trg) {\
onTrigger;\
if (Pop) {\
onPop; \
timdel = millis(); \
break;\
default:\
break;\
} while (0)
#define keyReadInit(x) do{\
pinMode(x, INPUT_PULLUP);\
} while (0)
#endif[/code]
