查看: 12574|回复: 4
max7219LED假唱机器人程序
发表于 2016-8-19 01:35:13 | 显示全部楼层 |阅读模式
最近在一个创客群里发现有人做了个假唱机器人,用的是DFrobot的8*8点阵LED,我又在instructables上发现有这个项目,估计群里的那个也是看这个做出来的,instructables上的是直接焊,我有一块Max7219的点阵LED,想把它程序改成Max7219的,可是instructables上的程序有点看不懂,请教一下怎么改,http://www.instructables.com/id/Lip-Synching-Robot/
[pre lang="arduino" line="1" file="Lip_Synching_Robot.ino"]/*
   @file Lip_Synching_Robot.ino
   @brief 8 x 8 LED Matrix animation using Arduino.
   @author Kei Takagi
   @date 2016.7.7
   8 x 8 Led Matrix ... 2-17 pin
   MIC Input        ... A4 pin
   Copyright (c) 2016 Kei dTakagi
   Revfleased under the MIT license
   http://opensource.org/licenses/mit-license.php
#include <MsTimer2.h>
#define FallVelocity 40
// 8 x 8 matrix LED
// ROW side cathode , COLOMN side of the anode
byte pins[17] = { -1, 9, 8, 7, 6, 5, 4, 3, 2, 17, 16, 15, 14, 13, 12, 11, 10};
const static byte cols[8] = {pins[13], pins[ 3], pins[ 4], pins[10], pins[ 6], pins[11], pins[15], pins[16]};
const static byte rows[8] = {pins[ 9], pins[14], pins[ 8], pins[12], pins[ 1], pins[ 7], pins[ 2], pins[ 5]};
int anime_frame = 0;
int cat = 0;
int ano = 0;
int val = 0;
int max = 0;
int min = 1024;
int i = 0;
unsigned long time;
byte layer[8];
byte face[12][8] = {
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00000000,
    0b01111110,
    0b00000000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00100100,
    0b00011000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00000000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b01111110,
    0b10000001,
    0b01111110,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00111100,
    0b01000010,
    0b00111100,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00111100,
    0b01000010,
    0b01000010,
    0b01000010,
    0b00111100,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00011000,
    0b00100100,
    0b00100100,
    0b00100100,
    0b00011000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b01111110,
    0b10000001,
    0b10000001,
    0b01111110,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00111100,
    0b01000010,
    0b01000010,
    0b01000010,
    0b00111100,
    0b01100110,
    0b01100110,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
    0b01100110,
    0b01100110,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
    0b01100110,
    0b00000000,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
  for ( cat = 0; cat < 8; cat++ ) {
    pinMode( rows[cat], OUTPUT );
    digitalWrite( rows[cat], HIGH );
  for ( ano = 0; ano < 8; ano++ ) {
    pinMode( cols[ano], OUTPUT );
    digitalWrite( cols[ano], LOW );
  time = millis() +  FallVelocity;
  MsTimer2::set(1, display);
  MsTimer2::start();
  randomSeed(analogRead(4));
  val = 0.7 * val + 0.3 * analogRead(A4) ;
  if (max < val)max = val;
  if (min > val)min = val;
  if (time < millis()) {
    anime_frame = map(max, min, 1023, 0, 12);
    for ( i = 0; i < 8; i++) {
      *(layer + i) = *(face[anime_frame] + i);
    switch (random(0, 50) ) {
      case 1:
        *(layer + 0) = 0b01000100;
        *(layer + 1) = 0b01000100;
      case 2:
        *(layer + 0) = 0b00100010;
        *(layer + 1) = 0b00100010;
      case 3:
        *(layer + 0) = 0b00000000;
      case 4:
        *(layer + 1) = 0b00000000;
    min = max;
    max = 0;
void display()
  cat < 7 ? cat++ :  cat = 0;
  digitalWrite( *(rows + cat), LOW );
    digitalWrite( *(cols + ano) , (*(layer + ano) >> cat ) & 0x01 );
    delayMicroseconds(50);
    digitalWrite( *(cols + ano), LOW );
  digitalWrite( *(rows + cat), HIGH );
[/code]
以下是我根据上面改出来的,可是吐舌头那段程序看不懂
  1. for ( i = 0; i < 8; i++) {
  2.       *(layer + i) = *(face[anime_frame] + i);
  3.     }
  4.     switch (random(0, 50) ) {
  5.       case 1:
  6.         *(layer + 0) = 0b01000100;
  7.         *(layer + 1) = 0b01000100;
  8.         break;
  9.       case 2:
  10.         *(layer + 0) = 0b00100010;
  11.         *(layer + 1) = 0b00100010;
  12.         break;
  13.       case 3:
  14.         *(layer + 0) = 0b00000000;
  15.         break;
  16.       case 4:
  17.         *(layer + 1) = 0b00000000;
  18.         break;
  19.     }
[pre lang="arduino" line="1" file="max7219"]#include <LedControl.h>
const int DIN_PIN = 5;
const int CS_PIN = 6;
const int CLK_PIN = 7;
const byte IMAGES[][8] = {
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00000000,
    0b01111110,
    0b00000000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00100100,
    0b00011000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00000000,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b01111110,
    0b10000001,
    0b01111110,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00000000,
    0b00111100,
    0b01000010,
    0b00111100,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00111100,
    0b01000010,
    0b01000010,
    0b01000010,
    0b00111100,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00011000,
    0b00100100,
    0b00100100,
    0b00100100,
    0b00011000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b01111110,
    0b10000001,
    0b10000001,
    0b01111110,
    0b00000000,
    0b01100110,
    0b01100110,
    0b00000000,
    0b00111100,
    0b01000010,
    0b01000010,
    0b01000010,
    0b00111100,
    0b01100110,
    0b01100110,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
    0b01100110,
    0b01100110,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
    0b01100110,
    0b00000000,
    0b01111110,
    0b10000001,
    0b10000001,
    0b10000001,
    0b10000001,
    0b01111110,
const int IMAGES_LEN = sizeof(IMAGES)/8;
LedControl matrix_led = LedControl(DIN_PIN, CLK_PIN, CS_PIN);
  matrix_led.clearDisplay(0);
  matrix_led.shutdown(0, false);
  matrix_led.setIntensity(0, 1);//设置亮度
void displayImage(byte *image) {
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      matrix_led.setLed(0, i, j, bitRead(image, 7-j));
int i = 0;
  displayImage(IMAGES);
  if (++i >= IMAGES_LEN ) {
    i = 0;
  delay(50);
}[/code]
发表于 2016-8-19 11:23:42 | 显示全部楼层
感谢分享,学习学习
 楼主| 发表于 2016-11-10 19:43:13 | 显示全部楼层
  1. /*
  2.    @file Lip_Synching_Robot_MAX7219.ino
  3.    @brief 8 x 8 LED Matrix animation using Arduino.
  4.    @author Kei Takagi
  5.    @date 2016.10.2
  6.    8 x 8 Led Matrix Max7219 ... DIN D2
  7.                                 CS  D3
  8.                                 SLK D4
  9.    MIC Input                ... A4 pin
  10.    Copyright (c) 2016 Kei dTakagi
  11.    Revfleased under the MIT license
  12.    http://opensource.org/licenses/mit-license.php
  13. */
  14. #include <MsTimer2.h>
  15. #define FallVelocity 50
  16. int Max7219_pinDIN = 3;
  17. int Max7219_pinCS = 4;
  18. int Max7219_pinCLK = 5;
  19. int anime_frame = 0;
  20. int cat = 0;
  21. int ano = 0;
  22. int val = 0;
  23. int max = 0;
  24. int min = 1024;
  25. int i = 0;
  26. unsigned long time;
  27. byte layer[8];
  28. byte face[12][8] = {
  29.   {
  30.     0b01100110,
  31.     0b01100110,
  32.     0b00000000,
  33.     0b00000000,
  34.     0b00000000,
  35.     0b01111110,
  36.     0b00000000,
  37.     0b00000000,
  38.   }, {
  39.     0b01100110,
  40.     0b01100110,
  41.     0b00000000,
  42.     0b00000000,
  43.     0b00011000,
  44.     0b00100100,
  45.     0b00011000,
  46.     0b00000000,
  47.   }, {
  48.     0b01100110,
  49.     0b01100110,
  50.     0b00000000,
  51.     0b00000000,
  52.     0b00000000,
  53.     0b00011000,
  54.     0b00000000,
  55.     0b00000000,
  56.   }, {
  57.     0b01100110,
  58.     0b01100110,
  59.     0b00000000,
  60.     0b00000000,
  61.     0b01111110,
  62.     0b10000001,
  63.     0b01111110,
  64.     0b00000000,
  65.   }, {
  66.     0b01100110,
  67.     0b01100110,
  68.     0b00000000,
  69.     0b00000000,
  70.     0b00111100,
  71.     0b01000010,
  72.     0b00111100,
  73.     0b00000000,
  74.   }, {
  75.     0b01100110,
  76.     0b01100110,
  77.     0b00000000,
  78.     0b00111100,
  79.     0b01000010,
  80.     0b01000010,
  81.     0b01000010,
  82.     0b00111100,
  83.   }, {
  84.     0b01100110,
  85.     0b01100110,
  86.     0b00000000,
  87.     0b00011000,
  88.     0b00100100,
  89.     0b00100100,
  90.     0b00100100,
  91.     0b00011000,
  92.   }, {
  93.     0b01100110,
  94.     0b01100110,
  95.     0b00000000,
  96.     0b01111110,
  97.     0b10000001,
  98.     0b10000001,
  99.     0b01111110,
  100.     0b00000000,
  101.   }, {
  102.     0b01100110,
  103.     0b01100110,
  104.     0b00000000,
  105.     0b00111100,
  106.     0b01000010,
  107.     0b01000010,
  108.     0b01000010,
  109.     0b00111100,
  110.   }, {
  111.     0b01100110,
  112.     0b01100110,
  113.     0b01111110,
  114.     0b10000001,
  115.     0b10000001,
  116.     0b10000001,
  117.     0b10000001,
  118.     0b01111110,
  119.   }, {
  120.     0b01100110,
  121.     0b01100110,
  122.     0b01111110,
  123.     0b10000001,
  124.     0b10000001,
  125.     0b10000001,
  126.     0b10000001,
  127.     0b01111110,
  128.   }, {
  129.     0b01100110,
  130.     0b00000000,
  131.     0b01111110,
  132.     0b10000001,
  133.     0b10000001,
  134.     0b10000001,
  135.     0b10000001,
  136.     0b01111110,
  137.   }
  138. };
  139. void setup()
  140. {
  141.   // Init MAX7219
  142.   pinMode(Max7219_pinDIN, OUTPUT);
  143.   pinMode(Max7219_pinCS, OUTPUT);
  144.   pinMode(Max7219_pinCLK, OUTPUT);
  145.   delay(50);
  146.   Write_Max7219(0x09, 0x00);
  147.   Write_Max7219(0x0a, 0x03);
  148.   Write_Max7219(0x0b, 0x07);
  149.   Write_Max7219(0x0c, 0x01);
  150.   Write_Max7219(0x0f, 0x00);
  151.   // Timer
  152.   time = millis() +  FallVelocity;
  153.   MsTimer2::set(1, display);
  154.   MsTimer2::start();
  155.   randomSeed(analogRead(4));
  156. }
  157. void loop()
  158. {
  159.   val = 0.7 * val + 0.3 * analogRead(A4);
  160.   if (max < val)max = val;
  161.   if (min > val)min = val;
  162.   if (time < millis()) {
  163.     time = millis() +  FallVelocity;
  164.     anime_frame = map(max, min, 1023, 0, 12);
  165.     for ( i = 0; i < 8; i++) {
  166.       *(layer + i) = *(face[anime_frame] + i);
  167.     }
  168.     switch (random(0, 50) ) {
  169.       case 1:
  170.         *(layer + 0) = 0b01000100;
  171.         *(layer + 1) = 0b01000100;
  172.         break;
  173.       case 2:
  174.         *(layer + 0) = 0b00100010;
  175.         *(layer + 1) = 0b00100010;
  176.         break;
  177.       case 3:
  178.         *(layer + 0) = 0b00000000;
  179.         break;
  180.       case 4:
  181.         *(layer + 1) = 0b00000000;
  182.         break;
  183.     }
  184.     min = max;
  185.     max = 0;
  186.   }
  187. }
  188. void display()
  189. {
  190.   cat < 7 ? cat++ :  cat = 0;
  191.   Write_Max7219(cat + 1 , layer[cat]);
  192. }
  193. void Write_Max7219(unsigned char address, unsigned char dat)
  194. {
  195.   digitalWrite(Max7219_pinCS, LOW);
  196.   Write_Max7219_byte(address);
  197.   Write_Max7219_byte(dat);
  198.   digitalWrite(Max7219_pinCS, HIGH);
  199. }
  200. void Write_Max7219_byte(unsigned char DATA)
  201. {
  202.   digitalWrite(Max7219_pinCS, LOW);
  203.   for (unsigned char j = 0; j < 8; j++)
  204.   {
  205.     digitalWrite(Max7219_pinCLK, LOW);
  206.     digitalWrite(Max7219_pinDIN, (DATA << j) & 0x80);
  207.     digitalWrite(Max7219_pinCLK, HIGH);
  208.   }
  209. }
已解决啦
发表于 2016-11-12 22:16:55 | 显示全部楼层
楼主库文件可不可分享下,
发表于 2016-12-13 22:30:57 | 显示全部楼层
谢谢楼主分享
GMT+8, 2024-4-25 01:31 , Processed in 0.040385 second(s), 21 queries .
