查看: 10319|回复: 1
物联网数据和开关控制延迟厉害,求助
发表于 2016-10-21 20:55:29 | 显示全部楼层 |阅读模式
最近接触了物联网,就找yeelink编了代码测试,目的是想让yeelink能够获取温度数据,同时接了一个LED开关,希望能够上传温度数据的过程中,也能够随时控制LED开关。现在功能能够实现,但是数据经常好几分钟传一个,而且没什么规律。开关点击后很长时间才能够看到设备效果。
有哪位大神指点下,看看哪里错了?
#include <SPI.h>
#include <Ethernet.h>
#define ledpin 3
#define APIKEY         "0683c31991703ace433e551e9443233"
#define DEVICEID       35104
#define SENSORID      39511
#define SENSORID2       39430
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
EthernetClient client;
char server[] = "api.yeelink.net";
unsigned long lastConnectionTime = 0;
boolean lastConnected = false;
const unsigned long postingInterval = 3*1000;
String returnValue = "";
boolean ResponseBegin = false;
  pinMode(ledpin, OUTPUT);
  if (Ethernet.begin(mac) == 0)
         for(;;)
          Serial.println("Ethernet configuration OK");
   while(client.available())
  char c = client.read();
  if (c == '{')
           ResponseBegin = true;
      else if (c == '}')
      if (ResponseBegin)
          returnValue += c;
      if (returnValue.length() !=0 && (ResponseBegin == false))
          Serial.println(returnValue);
          if (returnValue.charAt(returnValue.length() - 1) == '1')
                Serial.println("turn on the LED");
                digitalWrite(ledpin, HIGH);
           else if(returnValue.charAt(returnValue.length() - 1) == '0')
                Serial.println("turn off the LED");
                digitalWrite(ledpin, LOW);
           returnValue = "";
  if (!client.connected() && lastConnected) {
    Serial.println();
    client.stop();
   if(!client.connected() && (millis() - lastConnectionTime > postingInterval))
      {Serial.print("yeelink:");
           getData();
       int sensorReading = analogRead(0);//读取传感器数据并发送到yeelink服务。
       Serial.println(sensorReading);
       sendData(sensorReading);
  lastConnected = client.connected();
void getData(void) {
  if (client.connect(server, 80))
    client.print("GET /v1.0/device/");
    client.print(DEVICEID);
    client.print("/sensor/");
    client.print(SENSORID2);
    client.print("/datapoints");
    client.println(" HTTP/1.1");
    client.println("Host: api.yeelink.net");
    client.print("Accept: *");
    client.print("/");
    client.println("*");
    client.print("U-ApiKey: ");
    client.println(APIKEY);
    client.println("Content-Length: 0");
    client.println("Connection: close");
    client.println();
    Serial.println("print get done.");
  else {
    Serial.println();
    client.stop();
void sendData(int thisData)
             client.print("POST /v1.0/device/");
             client.print(SENSORID);
             client.print("/");
             client.print("Content-Length: ");
             int thisLength = 10 + getLength(thisData);
             client.println(thisLength);
             client.println("Content-Type: application/x-www-form-urlencoded");
             client.println();
             client.print("{\"value\":");
             client.print(thisData);
             client.println("}");
            Serial.println();
            client.stop();
int getLength(int someValue)
     int digits = 1;
     int dividend = someValue /10;
     while (dividend > 0)
          dividend = dividend /10;
          digits++;
      return digits;
发表于 2016-10-22 23:06:32 | 显示全部楼层
如果是无线的建议检查下网速
GMT+8, 2024-4-20 06:04 , Processed in 0.043506 second(s), 19 queries .
