Digispark tiny85板子上电后延时5S才开始工作,官方说法:If you unplug the Digispark and plug it back in or attach it to another power source there will be a delay of 5 seconds before the code you programmed will run. This 5 second delay is the Digispark Pro checking to see if you are trying to program it.
如何才能去掉这个上电后延时的过程?
