- //MIDI jianpan.ino
- 模拟launchpad打击垫
- 1.矩阵按键为9列8行
- 2.矩阵键盘列线解码芯片74LS138两片或74LS164一片
- 或串入并出芯片还可以矩阵键盘专用管理芯片*/
- /*RGBled为8列8行主要是用来装的,与midi键盘无关*/
- #include <MsTimer2.h> //定时器库的头文件
- #include <frequencyToNote.h>
- #include <MIDIUSB.h> //midi库
- #include <pitchToNote.h>
- #include <Adafruit_NeoPixel.h> //RGBled库
- #ifdef __AVR__
- #include <avr/power.h>
- #endif
- const byte column_num=9;//column,9列按键,第9列100-103为场景切换
- const byte row_num=8;//row,每列8个按键,也可称之为8行。
- const byte key_input_pin[]={2,3,4,5,6,7,8,9,10};//按键读取数据端
- const byte key_output_pin[]={14,16,10,15}; //四根列线,解码可得到16列,用0-9,10列。
- const unsigned char midi_key_num[]=
- {//按键输出音高数组,不了解查midi资料。
- 64,60,56,52,48,44,40,36,
- 65,61,57,53,49,45,41,37,
- 66,62,58,54,50,46,42,38,
- 67,63,59,55,51,47,43,39,
- 96,92,88,84,80,76,72,68,
- 97,93,89,85,81,77,73,69,
- 98,94,90,86,82,78,74,70,
- 99,95,91,87,83,79,75,71,
- 108,109,110,111,112,113,114,115,
- 100,101,102,103,104,105,106,107
- const unsigned char LED_num[]=
- {//RGB_led位置地址数组
- 0, 1, 2, 3,17,16,15,14,
- 18,19,20,21,35,34,33,32,
- 36,37,38,39,53,52,51,50,
- 54,55,56,57,71,70,69,68,
- 4, 5, 6, 7,13,12,11,10,
- 22,23,24,25,31,30,29,28,
- 40,41,42,43,49,48,47,46,
- 58,59,60,61,67,66,65,64,
- 63,62,45,44,27,26, 9, 8,
- 72,73,74,75,76,77,78,79,
- unsigned char ROWS_numr1,ROWS_numr2,ROWS_numr3,ROWS_numr4,ROWS_numr5,ROWS_numr6,ROWS_numr7,ROWS_numr8,ROWS_numr9;
- unsigned char ROW_num1,ROW_num2,ROW_num3,ROW_num4,ROW_num5,ROW_num6,ROW_num7,ROW_num8,ROW_num9;
- unsigned char ROWS_num[]={ROWS_numr1=0,ROWS_numr2=0,ROWS_numr3=0,ROWS_numr4=0,ROWS_numr5=0,ROWS_numr6=0,ROWS_numr7=0,ROWS_numr8=0,ROWS_numr9=0};
- unsigned char ROW_num[]={ROW_num1=0,ROW_num2=0,ROW_num3=0,ROW_num4=0,ROW_num5=0,ROW_num6=0,ROW_num7=0,ROW_num8=0,ROW_num9=0};
- unsigned char variable_a=0;
- unsigned char key_address;
- unsigned char j;
- unsigned char header_num=0;
- unsigned char header_num11=0;
- unsigned char byte_num1=0;
- unsigned char byte_num2=0;
- unsigned char byte_num3=0;
- #define NUMPIXELS 80//有80个LED连接
- #define LED_RGB_PIN 18//arduino连接端口18
- //int delayval = 500; // delay for half a second
- //#define control_pin 1//控制按键引脚
- Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, LED_RGB_PIN, NEO_GRB + NEO_KHZ800);
- //unsigned int LED_color_num[]={(R_n,G_n,B_n)};
- unsigned char r_n,g_n,b_n;
- const unsigned int LED_color_num1 [][3]=
- {//RGB_led颜色库数组。
- {0,0,0},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//7
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//15
- {0,0,0},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//23
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//31
- {0,0,0},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//39
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//47
- {0,0,0},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//55
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//63
- {15,10,10},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//71
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//79
- {15,10,10},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//87
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//95
- {20,20,20},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//103
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//111
- {10,20,10},{10,10,10},{20,20,20},{50,50,50},{75,50,50},{50,20,20},{20,10,10},{15,10,10},//119
- {50,75,50},{20,50,20},{10,20,10},{10,15,10},{50,50,75},{20,20,50},{10,10,20},{10,10,15},//127
- /***写事件函数***/
- void controlChange(byte channel, byte control, byte value) {
- midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
- MidiUSB.sendMIDI(event);
- /***开音符函数***/
- void noteOn(byte channel,byte pitch,byte velocity)
- midiEventPacket_t noteOn={0x09,0x90|channel,pitch,127};
- MidiUSB.sendMIDI(noteOn);
- /***关音符函数***/
- void noteOff(byte channel,byte pitch,byte velocity)
- midiEventPacket_t noteOff={0x08,0x80|channel,pitch,0};
- MidiUSB.sendMIDI(noteOff);
- /*RGBled刷新函数*/
- /*Fill the dots one after the other with a color*/
- void colorWipe_num(uint32_t c,uint8_t a)
- strip.setPixelColor(a, c);
- strip.show();
- /*读取midi数据和RGBled颜色读取*/
- void midi_led_date(void)
- midiEventPacket_t rx;
- do
- rx = MidiUSB.read();
- if (rx.header != 0)
- header_num=rx.header;
- byte_num1=rx.byte1;
- byte_num2=rx.byte2;
- byte_num3=rx.byte3;
- Serial.print("input:");
- Serial.println(byte_num2);
- if(header_num==9)
- r_n = LED_color_num1 [byte_num3][0];
- g_n = LED_color_num1 [byte_num3][1];
- b_n = LED_color_num1 [byte_num3][2];
- colorWipe_num(strip.Color (r_n,g_n,b_n), LED_num[byte_num2-36]); // Red
- if(header_num==8)
- colorWipe_num(strip.Color(0, 0, 0), LED_num[byte_num2-36]); // Red
- header_num11=header_num;
- while (rx.header != 0);
- void setup()
- // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
- #if defined (__AVR_ATtiny85__)
- if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
- #endif
- MsTimer2::set(40, midi_led_date); //中断设置函数,每10ms进入一次中断,刷新RGBled
- MsTimer2::start(); //定时中断开始计时
- Serial1.end(); //初始化串口
- pinMode(LED_RGB_PIN,OUTPUT);
- for(unsigned char i=0;i<4;i++)
- pinMode(key_output_pin[i],OUTPUT);//矩阵按键4列输出线,解码后为16条列线。
- for(unsigned char i=0;i<8;i++)
- pinMode(key_input_pin[i],INPUT_PULLUP);//每行8个按键读取数据线初始化(上拉输入模式)
- strip.begin();
- strip.show(); // Initialize all pixels to 'off'
- Serial.begin(250000);//初始化串口
- void loop()
- for(j=0;j<=11;j++)
- variable_a=0;
- digitalWrite(key_output_pin[0], bitRead(j, 0));//列线解码,输出
- digitalWrite(key_output_pin[1], bitRead(j, 1));
- digitalWrite(key_output_pin[2], bitRead(j, 2));
- digitalWrite(key_output_pin[3], bitRead(j, 3));
- bitWrite(ROW_num[j],i,digitalRead(key_input_pin[i]));//读取按键状态数据
- variable_a=ROW_num[j]^ROWS_num[j];//按键状态数据是否有变化
- if(variable_a!=0)
- delay(10);
- {//如果按键有变化延时20毫秒再次读取,消抖。
- variable_a=ROW_num[j]^ROWS_num[j];//按键有变化异或后不等于0
- if(variable_a!=0)
- ROWS_num[j]=ROW_num[j];
- else
- variable_a=0;
- if(variable_a!=0)
- key_address=1;//键值地址
- for(unsigned char a=0;a<8;a++)//作8次循环, 判断具体产生变化的键
- if((variable_a&key_address)!= 0)//用指针选择被测的键
- if((ROWS_num[j]&key_address)!=0)//判断变化位,以确定是被压下还是释放
- noteOff(0,(midi_key_num[j*8+a]),0);
- Serial.print("output:");
- Serial.println(midi_key_num[j*8+a]);
- MidiUSB.flush();
- }//关闭声音,键值=i*8+j+addition
- else
- noteOn(0,(midi_key_num[j*8+a]),127);
- MidiUSB.flush();
- }//开始发声,键值=i*8+j+addition
- key_address=key_address<<1;
- variable_a=0;
复制代码 |
