- This sketch is a complete radio head for FSX
- It needs to be used with Link2fs_Multi
- It was compiled with Arduino version 1.1
- Full project info at http://www.jimspage.co.nz/intro.htm
- This example code is in the public domain.
- Once you get this going you can experiment with removing the DELAY lines.???
- #include <LiquidCrystal.h>
- #include "math.h"
- #include "Quadrature.h"
- Quadrature quad1(8, 9);
- LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
- int CodeIn;// used on all serial reads
- int X;// a rotary variable
- int Xold;// the old reading
- int Xdif;// the difference since last loop
- int active; // the mode thats active
- int activeold;
- int mark; // shows where the cursor is in the likes of ADF etc
- String oldpinStateSTR, pinStateSTR, pinStateString, APsp, APspold, stringnewstate,stringoldstate, com1, com1old, com1sb, com1sbold,com2, com2old, com2sb,com2sbold, airsp, airspold, altit, altitold;
- String nav1, nav1old, nav1sb, nav1sbold, nav2, nav2old, nav2sb, nav2sbold;
- String adf, adfold, xpdr, xpdrold, dme1, dme1old, dme2, dme2old, pitot, pitotold;
- char blank = 255;
- void setup()
- lcd.begin(16, 2); // set up the LCD's number of columns and rows:
- stringoldstate = "111111111111111111111111111111111111111111111111111111111111111111111";
- Serial.begin(115200);
- for (int doutPin = 10; doutPin <= 19; doutPin++) // setup the input pins
- pinMode(doutPin, INPUT);
- digitalWrite(doutPin, HIGH);
- mark = 10;
- lcd.clear();
- void loop() {
- {INPUTPINS();} //Check the "button pressed" section
- {LCDMODE();} // Sets up the LCD for the mode it's in (From the rotary switch)
- {ROTARYS();} // go and check the rotary encoder
- if (Serial.available()) { // now lets check the serial buffer for any input data
- CodeIn = getChar();
- if (CodeIn == '=') {EQUALS();}// The first identifier is "="
- } // end of serial available
- }// edn of void loop
- char getChar()// Get a character from the serial buffer
- while(Serial.available() == 0);// wait for data
- return((char)Serial.read());// Thanks Doug
- }//end of getchar
- void LCDMODE(){
- if (active != activeold)
- activeold = active;
- if (digitalRead(12)==0 and active != 12) { // Sets up the LCD when switching to Com1)
- lcd.setCursor(0, 0);
- delay (11);
- lcd.print("Com.1 ");
- lcd.setCursor(9, 0);
- delay (11);
- lcd.print(com1);
- lcd.setCursor(0, 1);
- delay (11);
- lcd.print(" s/b ");
- lcd.setCursor(9, 1);
- delay (11);
- lcd.print(com1sb);
- active = 12;
- if (digitalRead(14)==0 and active != 14) { // Sets up the LCD when switching to Com2)
- delay (11);
- lcd.print("Com.2 ");
- delay (11);
- lcd.print(com2);
- delay (11);
- lcd.print(com2sb);
- active = 14;
- if (digitalRead(15)==0 and active != 15) { // Sets up the LCD when switching to Nav1)
- delay (11);
- lcd.print("Nav.1 ");
- delay (11);
- lcd.print(nav1);
- delay (11);
- lcd.print(nav1sb);
- active = 15;
- if (digitalRead(16)==0 and active != 16) { // Sets up the LCD when switching to Nav2)
- delay (11);
- lcd.print("Nav.2 ");
- delay (11);
- lcd.print(nav2);
- delay (11);
- lcd.print(nav2sb);
- active = 16;
- if (digitalRead(17)==0 and active != 17) { // Sets up the LCD when switching to ADF)
- delay (11);
- lcd.print("ADF ");
- delay (11);
- lcd.print(adf);
- lcd.print(" ");
- lcd.print(" ");
- if (mark == 9 ){mark = 10;}
- lcd.setCursor(mark, 1);
- lcd.print("-");
- active = 17;
- if (digitalRead(18)==0 and active != 18) { // Sets up the LCD when switching to DME)
- delay (11);
- lcd.print("DME1 ");
- delay (11);
- lcd.print(dme1);
- lcd.print(" ");
- lcd.print("DME2 ");
- delay (11);
- lcd.print(dme2);
- active = 18;
- if (digitalRead(19)==0 and active != 19) { // Sets up the LCD when switching to XPDR)
- delay (11);
- lcd.print("XPonder ");
- delay (11);
- lcd.print(xpdr);
- //lcd.print(" ");
- lcd.print(" ");
- lcd.print("-");
- active = 19;
- } // end of LCDmode
- void EQUALS(){ // The first identifier was "="
- delay (11);
- CodeIn = getChar(); // Get another character
- switch(CodeIn) {// Now lets find what to do with it
- case 'A'://Found the second identifier "Com1"
- com1 = "";
- com1 += getChar();
- if (com1 != com1old && digitalRead(12) == LOW) {
- delay (11);
- delay (11);
- lcd.print(com1);
- com1old = com1;
- break;
- case 'B': // Found the reading "Com1 s/b"
- com1sb = "";
- com1sb += getChar();
- if (com1sb != com1sbold && digitalRead(12) == LOW ){
- delay (11);
- delay (11);
- com1sbold = com1sb;
- break;
- case 'C': // Found the reading "Com2"
- com2 = "";
- com2 += getChar();
- if (com2 != com2old && digitalRead(14) == LOW) {
- delay (11);
- lcd.print(com2);
- com2old = com2;
- break;
- case 'D': // Found the reading "Com2 s/b"
- com2sb = "";
- com2sb += getChar();
- if (com2sb != com2sbold && digitalRead(14) == LOW) {
- delay (11);
- com2sbold = com2sb;
- break;
- case 'E': // Found the reading "Nav1"
- delay (11);
- nav1 = "";
- nav1 += getChar();
- nav1 += (" "); //pads it up to 8 caracters
- if (nav1 != nav1old && digitalRead(15) == LOW) {
- delay (11);
- lcd.print(nav1);
- nav1old = nav1;
- break;
- case 'F': // Found the reading "Nav1 s/b"
- nav1sb = "";
- nav1sb += getChar();
- nav1sb += (" "); //pads it up to 8 caracters
- if (nav1sb != nav1sbold && digitalRead(15) == LOW) {
- delay (11);
- nav1sbold = nav1sb;
- break;
- case 'G': // Found the reading "Nav2"
- delay (11);
- nav2 = "";
- nav2 += getChar();
- nav2 += (" "); //pads it up to 8 caracters
- if (nav2 != nav2old && digitalRead(16) == LOW) {
- delay (11);
- lcd.print(nav2);
- nav2old = nav2;
- break;
- case 'H': // Found the reading "Nav2 s/b"
- nav2sb = "";
- nav2sb += getChar();
- nav2sb += (" "); //pads it up to 8 caracters
- if (nav2sb != nav2sbold && digitalRead(16) == LOW) {
- delay (11);
- nav2sbold = nav2sb;
- break;
- case 'I': // Found the reading "ADF"
- adf = "";
- adf += getChar();
- adf += getChar();
- adf += getChar();
- adf += getChar();
- adf += getChar();
- adf += getChar();
- adf += (" "); //pads it up to 8 caracters
- if (adf != adfold && digitalRead(17) == LOW) {
- delay (11);
- lcd.print(adf);
- adfold = adf;
- break;
- case 'J': // Found the reading "XPDR"
- delay (11);
- xpdr = "";
- xpdr += getChar();
- xpdr += (" "); //pads it up to 8 caracters
- if (xpdr != xpdrold && digitalRead(19) == LOW) {
- delay (11);
- lcd.print(xpdr);
- xpdrold = xpdr;
- break;
- case 'K': // Found the reading "DME1"
- delay (11);
- dme1 = "";
- dme1 += getChar();
- dme1 += (" "); //pads it up to 8 caracters
- if (dme1 != dme1old && digitalRead(18) == LOW) {
- delay (11);
- lcd.print(dme1);
- dme1old = dme1;
- break;
- case 'L': // Found the reading "DME2"
- delay (11);
- dme2 = "";
- dme2 += getChar();
- dme2 += (" "); //pads it up to 8 caracters
- if (dme2 != dme2old && digitalRead(18) == LOW) {
- delay (11);
- lcd.print(dme2);
- dme2old = dme2;
- break;
- void ROTARYS() {//now the bit for the rotary encoder input
- X =(quad1.position()/2);
- if (X != Xold) { // checks to see if it different
- (Xdif = (X-Xold));// finds out the difference
- //lcd.setCursor(0, 0);
- if (active == 12){// Com1 rotary encoder output
- if (Xdif == 1) {
- if (digitalRead(10)==0 ) {
- Serial.println("A01");
- else Serial.println("A03");
- if (Xdif == -1) {
- Serial.println("A02");
- else Serial.println("A04");
- if (active == 14){// Com2 rotary encoder output
- if (Xdif == 1) {
- Serial.println("A07");
- else Serial.println("A09");
- if (Xdif == -1) {
- Serial.println("A08");
- else Serial.println("A10");
- if (active == 15){// Nav1 rotary encoder output
- if (Xdif == 1) {
- Serial.println("A13");
- else Serial.println("A15");
- if (Xdif == -1) {
- Serial.println("A14");
- else Serial.println("A16");
- if (active == 16){// Nav2 rotary encoder output
- if (Xdif == 1) {
- Serial.println("A19");
- else Serial.println("A21");
- if (Xdif == -1) {
- Serial.println("A20");
- else Serial.println("A22");
- if (active == 17){// ADF rotary encoder output
- if (Xdif == 1) {
- mark = (mark - 1);
- active = 2;
- if (mark == 13) mark =12;
- if (Xdif == -1){
- mark = (mark + 1);
- active = 2;
- if (mark == 13) mark =14;
- if (mark > 14) mark = 14;
- if (mark < 10) mark = 10;
- else{
- if (Xdif == 1) {
- if (mark == 10) {
- Serial.println("A29");
- if (mark == 11) {
- Serial.println("A30");
- if (mark == 12) {
- Serial.println("A31");
- if (mark == 14) {
- Serial.println("A32");
- if (Xdif == -1){
- if (mark == 10){
- Serial.println("A25");
- if (mark == 11){
- Serial.println("A26");
- if (mark == 12){
- Serial.println("A27");
- if (mark == 14){
- Serial.println("A28");
- if (active == 19){// Xponder rotary encoder output
- if (Xdif == 1) {
- active = 2;
- if (Xdif == -1){
- active = 2;
- if (mark > 12) mark = 12;
- if (mark < 9) mark = 9;
- else{
- if (Xdif == 1) {
- if (mark == 9) {
- Serial.println("A38");
- if (mark == 10) {
- Serial.println("A39");
- if (mark == 11) {
- Serial.println("A40");
- if (mark == 12) {
- Serial.println("A41");
- if (Xdif == -1){
- if (mark == 9){
- Serial.println("A34");
- if (mark == 10){
- Serial.println("A35");
- if (mark == 11){
- Serial.println("A36");
- if (mark == 12){
- Serial.println("A37");
- if (quad1.position() > 100){ // zero the rotary encoder count if too high or low
- quad1.position(0);
- if (quad1.position() < -100){
- Xold = X; // overwrites the old reading with the new one.
- }// end of rotarys
- void INPUTPINS(){
- stringnewstate = "";
- for (int pinNo = 10; pinNo <= 19; pinNo++){
- pinStateSTR = String(digitalRead(pinNo));
- oldpinStateSTR = "";
- oldpinStateSTR += String(stringoldstate.charAt(pinNo - 10));
- if (pinStateSTR != oldpinStateSTR) {
- if (pinNo == 11 and pinStateSTR == "0") { //Change-over button pressed
- if (active == 12) Serial.println("A06");
- if (active == 14) Serial.println("A12");
- if (active == 15) Serial.println("A18");
- if (active == 16) Serial.println("A24");
- if ( active == 17){
- if (mark == 13){
- mark = 14;
- }// sort out for piont in ADF
- active = 1;
- if (mark > 14)mark = 10;
- if (mark == 13){
- mark = 9;
- }// sort out for length Xponder
- active = 1;
- if (mark > 12)mark = 12;
- } // end of "if it's pin ??" do something
- }// end of "yes it's different"
- stringnewstate += pinStateSTR;
- stringoldstate = stringnewstate;
- delay(11);
- }// end of inputpins
Arduino:1.8.1 (Windows 7), 开发板:"Arduino/Genuino Uno"
D:\Documents\Arduino\libraries\Multi_Radiohead_Uno\Multi_Radiohead_Uno.ino:15:24: fatal error: Quadrature.h: No such file or directory
compilation terminated.
exit status 1
为开发板 Arduino/Genuino Uno 编译时出错。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
