很简单事!就是我用的MEGA2560自带SCL和SDA口不用接A4A5哈哈哈!太他么操蛋了!
只是时间设置的不太对小小改下就好!感谢各位积极解惑的朋友
请忽略第一张图!传错了!用DS3231时钟写入示例程序后串口显示都不正常弄不明白了!
我用的EGA2560+DS3231
示例代码
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
byte year, month, date, DoW, hour, minute, second;
// Start the I2C interface
Wire.begin();
Clock.setSecond(50);//Set the second
Clock.setMinute(59);//Set the minute
Clock.setHour(11); //Set the hour
Clock.setDoW(5); //Set the day of the week
Clock.setDate(31); //Set the date of the month
Clock.setMonth(5); //Set the month of the year
Clock.setYear(13); //Set the year (Last two digits of the year)
// Start the serial interface
Serial.begin(115200);
void ReadDS3231()
int second,minute,hour,date,month,year,temperature;
second=Clock.getSecond();
minute=Clock.getMinute();
hour=Clock.getHour(h12, PM);
date=Clock.getDate();
month=Clock.getMonth(Century);
year=Clock.getYear();
temperature=Clock.getTemperature();
Serial.print("20");
Serial.print(year,DEC);
Serial.print('-');
Serial.print(month,DEC);
Serial.print('-');
Serial.print(date,DEC);
Serial.print(' ');
Serial.print(hour,DEC);
Serial.print(':');
Serial.print(minute,DEC);
Serial.print(':');
Serial.print(second,DEC);
Serial.print('\n');
Serial.print("Temperature=");
Serial.print(temperature);
Serial.print('\n');
void loop() {ReadDS3231();delay(1000);}
发上库文件和CPP文件!高手们给看看!
针脚接线
vcc---5v
GND--GND
SCL--A5
SDA--A4
32K还有SQW没用!
CPP文件如下!
DS3231.cpp: DS3231 Real-Time Clock library
original code by
Eric Ayars
4/1/11
updated to Arduino 1.0
John Hubert
Feb 7, 2012
Released into the public domain.
#include <DS3231.h>
#define CLOCK_ADDRESS 0x68
// Constructor
DS3231:S3231() {
// nothing to do for this constructor.
Public Functions
void DS3231::getTime(byte& year, byte& month, byte& date, byte& DoW, byte& hour, byte& minute, byte& second) {
byte tempBuffer;
bool PM;
bool h12;
Wire.beginTransmission(CLOCK_ADDRESS);
Wire.write(uint8_t(0x00));
Wire.endTransmission();
Wire.requestFrom(CLOCK_ADDRESS, 7);
second = bcdToDec(Wire.read());
minute = bcdToDec(Wire.read());
tempBuffer = bcdToDec(Wire.read());
h12 = tempBuffer & 0b01000000;
if (h12) {
PM = tempBuffer & 0b00100000;
hour = bcdToDec(tempBuffer & 0b00011111);
} else {
hour = bcdToDec(tempBuffer & 0b00111111);
DoW = bcdToDec(Wire.read());
date = bcdToDec(Wire.read());
month = bcdToDec(Wire.read() & 0b01111111);
year = bcdToDec(Wire.read());
byte DS3231::getSecond() {
Wire.requestFrom(CLOCK_ADDRESS, 1);
return bcdToDec(Wire.read());
byte DS3231::getMinute() {
Wire.write(0x01);
byte DS3231::getHour(bool& h12, bool& PM) {
byte temp_buffer;
byte hour;
Wire.write(0x02);
temp_buffer = Wire.read();
h12 = temp_buffer & 0b01000000;
if (h12) {
PM = temp_buffer & 0b00100000;
hour = bcdToDec(temp_buffer & 0b00011111);
} else {
hour = bcdToDec(temp_buffer & 0b00111111);
return hour;
byte DS3231::getDoW() {
Wire.write(uint8_t(0x03));
byte DS3231::getDate() {
Wire.write(uint8_t(0x04));
byte DS3231::getMonth(bool& Century) {
byte temp_buffer;
byte hour;
Wire.write(uint8_t(0x05));
Century = temp_buffer & 0b10000000;
return (bcdToDec(temp_buffer & 0b01111111)) ;
byte DS3231::getYear() {
Wire.write(uint8_t(0x06));
void DS3231::setSecond(byte Second) {
// Sets the seconds
// This function also resets the Oscillator Stop Flag, which is set
// whenever power is interrupted.
Wire.write(decToBcd(Second));
// Clear OSF flag
byte temp_buffer = readControlByte(1);
writeControlByte((temp_buffer & 0b01111111), 1);
void DS3231::setMinute(byte Minute) {
// Sets the minutes
Wire.write(uint8_t(0x01));
Wire.write(decToBcd(Minute));
void DS3231::setHour(byte Hour) {
// Sets the hour, without changing 12/24h mode.
// The hour must be in 24h format.
bool h12;
// Start by figuring out what the 12/24 mode is
Wire.write(uint8_t(0x02));
h12 = (Wire.read() & 0b01000000);
// if h12 is true, it's 12h mode; false is 24h.
if (h12) {
// 12 hour
if (Hour > 12) {
Hour = decToBcd(Hour-12) | 0b01100000;
} else {
Hour = decToBcd(Hour) & 0b11011111;
} else {
// 24 hour
Hour = decToBcd(Hour) & 0b10111111;
Wire.write(Hour);
void DS3231::setDoW(byte DoW) {
// Sets the Day of Week
Wire.write(decToBcd(DoW));
void DS3231::setDate(byte Date) {
// Sets the Date
Wire.write(decToBcd(Date));
void DS3231::setMonth(byte Month) {
// Sets the month
Wire.write(decToBcd(Month));
void DS3231::setYear(byte Year) {
// Sets the year
Wire.write(decToBcd(Year));
void DS3231::setClockMode(bool h12) {
// sets the mode to 12-hour (true) or 24-hour (false).
// One thing that bothers me about how I've written this is that
// if the read and right happen at the right hourly millisecnd,
// the clock will be set back an hour. Not sure how to do it better,
// though, and as long as one doesn't set the mode frequently it's
// a very minimal risk.
// It's zero risk if you call this BEFORE setting the hour, since
// the setHour() function doesn't change this mode.
byte temp_buffer;
// Start by reading byte 0x02.
// Set the flag to the requested value:
if (h12) {
temp_buffer = temp_buffer | 0b01000000;
} else {
temp_buffer = temp_buffer & 0b10111111;
// Write the byte
Wire.write(temp_buffer);
float DS3231::getTemperature() {
// Checks the internal thermometer on the DS3231 and returns the
// temperature as a floating-point value.
byte temp;
Wire.write(uint8_t(0x11));
Wire.requestFrom(CLOCK_ADDRESS, 2);
temp = Wire.read(); // Here's the MSB
return float(temp) + 0.25*(Wire.read()>>6);
void DS3231::getA1Time(byte& A1Day, byte& A1Hour, byte& A1Minute, byte& A1Second, byte& AlarmBits, bool& A1Dy, bool& A1h12, bool& A1PM) {
byte temp_buffer;
Wire.write(uint8_t(0x07));
Wire.requestFrom(CLOCK_ADDRESS, 4);
temp_buffer = Wire.read(); // Get A1M1 and A1 Seconds
A1Second = bcdToDec(temp_buffer & 0b01111111);
// put A1M1 bit in position 0 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>7;
temp_buffer = Wire.read(); // Get A1M2 and A1 minutes
A1Minute = bcdToDec(temp_buffer & 0b01111111);
// put A1M2 bit in position 1 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>6;
temp_buffer = Wire.read(); // Get A1M3 and A1 Hour
// put A1M3 bit in position 2 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>5;
// determine A1 12/24 mode
A1h12 = temp_buffer & 0b01000000;
if (A1h12) {
A1PM = temp_buffer & 0b00100000; // determine am/pm
A1Hour = bcdToDec(temp_buffer & 0b00011111); // 12-hour
} else {
A1Hour = bcdToDec(temp_buffer & 0b00111111); // 24-hour
temp_buffer = Wire.read(); // Get A1M4 and A1 Day/Date
// put A1M3 bit in position 3 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>4;
// determine A1 day or date flag
A1Dy = (temp_buffer & 0b01000000)>>6;
if (A1Dy) {
// alarm is by day of week, not date.
A1Day = bcdToDec(temp_buffer & 0b00001111);
} else {
// alarm is by date, not day of week.
A1Day = bcdToDec(temp_buffer & 0b00111111);
void DS3231::getA2Time(byte& A2Day, byte& A2Hour, byte& A2Minute, byte& AlarmBits, bool& A2Dy, bool& A2h12, bool& A2PM) {
byte temp_buffer;
Wire.write(uint8_t(0x0b));
Wire.requestFrom(CLOCK_ADDRESS, 3);
temp_buffer = Wire.read(); // Get A2M2 and A2 Minutes
A2Minute = bcdToDec(temp_buffer & 0b01111111);
// put A2M2 bit in position 4 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>3;
temp_buffer = Wire.read(); // Get A2M3 and A2 Hour
// put A2M3 bit in position 5 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>2;
// determine A2 12/24 mode
A2h12 = temp_buffer & 0b01000000;
if (A2h12) {
A2PM = temp_buffer & 0b00100000; // determine am/pm
A2Hour = bcdToDec(temp_buffer & 0b00011111); // 12-hour
} else {
A2Hour = bcdToDec(temp_buffer & 0b00111111); // 24-hour
temp_buffer = Wire.read(); // Get A2M4 and A1 Day/Date
// put A2M4 bit in position 6 of DS3231_AlarmBits.
AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>1;
// determine A2 day or date flag
A2Dy = (temp_buffer & 0b01000000)>>6;
if (A2Dy) {
A2Day = bcdToDec(temp_buffer & 0b00001111);
} else {
A2Day = bcdToDec(temp_buffer & 0b00111111);
void DS3231::setA1Time(byte A1Day, byte A1Hour, byte A1Minute, byte A1Second, byte AlarmBits, bool A1Dy, bool A1h12, bool A1PM) {
// Sets the alarm-1 date and time on the DS3231, using A1* information
byte temp_buffer;
Wire.write(uint8_t(0x07)); // A1 starts at 07h
// Send A1 second and A1M1
Wire.write(decToBcd(A1Second) | ((AlarmBits & 0b00000001) << 7));
// Send A1 Minute and A1M2
Wire.write(decToBcd(A1Minute) | ((AlarmBits & 0b00000010) << 6));
// Figure out A1 hour
if (A1h12) {
// Start by converting existing time to h12 if it was given in 24h.
if (A1Hour > 12) {
// well, then, this obviously isn't a h12 time, is it?
A1Hour = A1Hour - 12;
A1PM = true;
if (A1PM) {
// Afternoon
// Convert the hour to BCD and add appropriate flags.
temp_buffer = decToBcd(A1Hour) | 0b01100000;
} else {
// Morning
temp_buffer = decToBcd(A1Hour) | 0b01000000;
} else {
// Now for 24h
temp_buffer = decToBcd(A1Hour);
temp_buffer = temp_buffer | ((AlarmBits & 0b00000100)<<5);
// A1 hour is figured out, send it
// Figure out A1 day/date and A1M4
temp_buffer = ((AlarmBits & 0b00001000)<<4) | decToBcd(A1Day);
if (A1Dy) {
// Set A1 Day/Date flag (Otherwise it's zero)
// All done!
void DS3231::setA2Time(byte A2Day, byte A2Hour, byte A2Minute, byte AlarmBits, bool A2Dy, bool A2h12, bool A2PM) {
// Sets the alarm-2 date and time on the DS3231, using A2* information
byte temp_buffer;
Wire.write(uint8_t(0x0b)); // A1 starts at 0bh
// Send A2 Minute and A2M2
Wire.write(decToBcd(A2Minute) | ((AlarmBits & 0b00010000) << 3));
// Figure out A2 hour
if (A2h12) {
if (A2Hour > 12) {
A2Hour = A2Hour - 12;
A2PM = true;
if (A2PM) {
// Afternoon
temp_buffer = decToBcd(A2Hour) | 0b01100000;
} else {
// Morning
temp_buffer = decToBcd(A2Hour) | 0b01000000;
} else {
// Now for 24h
temp_buffer = decToBcd(A2Hour);
// add in A2M3 bit
temp_buffer = temp_buffer | ((AlarmBits & 0b00100000)<<2);
// A2 hour is figured out, send it
// Figure out A2 day/date and A2M4
temp_buffer = ((AlarmBits & 0b01000000)<<1) | decToBcd(A2Day);
if (A2Dy) {
// Set A2 Day/Date flag (Otherwise it's zero)
// All done!
void DS3231::turnOnAlarm(byte Alarm) {
// turns on alarm number "Alarm". Defaults to 2 if Alarm is not 1.
byte temp_buffer = readControlByte(0);
// modify control byte
if (Alarm == 1) {
temp_buffer = temp_buffer | 0b00000101;
} else {
temp_buffer = temp_buffer | 0b00000110;
writeControlByte(temp_buffer, 0);
void DS3231::turnOffAlarm(byte Alarm) {
// turns off alarm number "Alarm". Defaults to 2 if Alarm is not 1.
// Leaves interrupt pin alone.
if (Alarm == 1) {
temp_buffer = temp_buffer & 0b11111110;
} else {
temp_buffer = temp_buffer & 0b11111101;
bool DS3231::checkAlarmEnabled(byte Alarm) {
// Checks whether the given alarm is enabled.
byte result = 0x0;
if (Alarm == 1) {
result = temp_buffer & 0b00000001;
} else {
result = temp_buffer & 0b00000010;
return result;
bool DS3231::checkIfAlarm(byte Alarm) {
// Checks whether alarm 1 or alarm 2 flag is on, returns T/F accordingly.
// Turns flag off, also.
// defaults to checking alarm 2, unless Alarm == 1.
byte result;
if (Alarm == 1) {
// Did alarm 1 go off?
// clear flag
} else {
// Did alarm 2 go off?
// clear flag
writeControlByte(temp_buffer, 1);
return result;
void DS3231::enableOscillator(bool TF, bool battery, byte frequency) {
// turns oscillator on or off. True is on, false is off.
// if battery is true, turns on even for battery-only operation,
// otherwise turns off if Vcc is off.
// frequency must be 0, 1, 2, or 3.
// 0 = 1 Hz
// 1 = 1.024 kHz
// 2 = 4.096 kHz
// 3 = 8.192 kHz (Default if frequency byte is out of range)
if (frequency > 3) frequency = 3;
// read control byte in, but zero out current state of RS2 and RS1.
byte temp_buffer = readControlByte(0) & 0b11100111;
if (battery) {
// turn on BBSQW flag
} else {
// turn off BBSQW flag
if (TF) {
// set ~EOSC to 0 and INTCN to zero.
temp_buffer = temp_buffer & 0b01111011;
} else {
// set ~EOSC to 1, leave INTCN as is.
temp_buffer = temp_buffer | 0b10000100;
// shift frequency into bits 3 and 4 and set.
frequency = frequency << 3;
temp_buffer = temp_buffer | frequency;
// And write the control bits
void DS3231::enable32kHz(bool TF) {
// turn 32kHz pin on or off
if (TF) {
// turn on 32kHz pin
temp_buffer = temp_buffer | 0b00001000;
} else {
// turn off 32kHz pin
temp_buffer = temp_buffer & 0b11110111;
bool DS3231:scillatorCheck() {
// Returns false if the oscillator has been off for some reason.
// If this is the case, the time is probably not correct.
bool result = true;
if (temp_buffer & 0b10000000) {
// Oscillator Stop Flag (OSF) is set, so return false.
result = false;
return result;
Private Functions
byte DS3231::decToBcd(byte val) {
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte DS3231::bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
byte DS3231::readControlByte(bool which) {
// Read selected control byte
// first byte (0) is 0x0e, second (1) is 0x0f
if (which) {
// second control byte
Wire.write(uint8_t(0x0f));
} else {
// first control byte
Wire.write(uint8_t(0x0e));
return Wire.read();
void DS3231::writeControlByte(byte control, bool which) {
// Write the selected control byte.
// which=false -> 0x0e, true->0x0f.
if (which) {
} else {
Wire.write(control);
3231库文件如下
* DS3231.h
* Arduino Library for the DS3231 Real-Time Clock chip
* (c) Eric Ayars
* 4/1/11
* Updated to Arduino 1.0 By john Hubert
* Feb 7 2012
* released into the public domain. If you use this, please let me know
* (just out of pure curiosity!) by sending me an email:
* [email protected]
#ifndef DS3231_h
#define DS3231_h
#include <Arduino.h>
#include <Wire.h>
class DS3231 {
public:
//Constructor
DS3231();
// Time-retrieval functions
// the get*() functions retrieve current values of the registers.
// If you only need one element, use that one for simplicity; but
// if you need the whole passel then use getTime() to avoid
// the chance of rollover between reads of the different components.
void getTime(byte& year, byte& month, byte& date, byte& DoW, byte& hour, byte& minute, byte& second);
byte getSecond();
byte getMinute();
byte getHour(bool& h12, bool& PM);
// In addition to returning the hour register, this function
// returns the values of the 12/24-hour flag and the AM/PM flag.
byte getDoW();
byte getDate();
byte getMonth(bool& Century);
// Also sets the flag indicating century roll-over.
byte getYear();
// Last 2 digits only
// Time-setting functions
// Note that none of these check for sensibility: You can set the
// date to July 42nd and strange things will probably result.
void setSecond(byte Second);
// In addition to setting the seconds, this clears the
// "Oscillator Stop Flag".
void setMinute(byte Minute);
// Sets the minute
void setHour(byte Hour);
// Sets the hour
void setDoW(byte DoW);
// Sets the Day of the Week (1-7);
void setDate(byte Date);
// Sets the Date of the Month
void setMonth(byte Month);
// Sets the Month of the year
void setYear(byte Year);
// Last two digits of the year
void setClockMode(bool h12);
// Set 12/24h mode. True is 12-h, false is 24-hour.
// Temperature function
float getTemperature();
// Alarm functions
void getA1Time(byte& A1Day, byte& A1Hour, byte& A1Minute, byte& A1Second, byte& AlarmBits, bool& A1Dy, bool& A1h12, bool& A1PM);
/* Retrieves everything you could want to know about alarm
* one.
* A1Dy true makes the alarm go on A1Day = Day of Week,
* A1Dy false makes the alarm go on A1Day = Date of month.
* byte AlarmBits sets the behavior of the alarms:
* Dy A1M4 A1M3 A1M2 A1M1 Rate
* X 1 1 1 1 Once per second
* X 1 1 1 0 Alarm when seconds match
* X 1 1 0 0 Alarm when min, sec match
* X 1 0 0 0 Alarm when hour, min, sec match
* 0 0 0 0 0 Alarm when date, h, m, s match
* 1 0 0 0 0 Alarm when DoW, h, m, s match
* Dy A2M4 A2M3 A2M2 Rate
* X 1 1 1 Once per minute (at seconds = 00)
* X 1 1 0 Alarm when minutes match
* X 1 0 0 Alarm when hours and minutes match
* 0 0 0 0 Alarm when date, hour, min match
* 1 0 0 0 Alarm when DoW, hour, min match
void getA2Time(byte& A2Day, byte& A2Hour, byte& A2Minute, byte& AlarmBits, bool& A2Dy, bool& A2h12, bool& A2PM);
// Same as getA1Time();, but A2 only goes on seconds == 00.
void setA1Time(byte A1Day, byte A1Hour, byte A1Minute, byte A1Second, byte AlarmBits, bool A1Dy, bool A1h12, bool A1PM);
// Set the details for Alarm 1
void setA2Time(byte A2Day, byte A2Hour, byte A2Minute, byte AlarmBits, bool A2Dy, bool A2h12, bool A2PM);
// Set the details for Alarm 2
void turnOnAlarm(byte Alarm);
// Enables alarm 1 or 2 and the external interrupt pin.
// If Alarm != 1, it assumes Alarm == 2.
void turnOffAlarm(byte Alarm);
// Disables alarm 1 or 2 (default is 2 if Alarm != 1);
// and leaves the interrupt pin alone.
bool checkAlarmEnabled(byte Alarm);
// Returns T/F to indicate whether the requested alarm is
// enabled. Defaults to 2 if Alarm != 1.
bool checkIfAlarm(byte Alarm);
// Checks whether the indicated alarm (1 or 2, 2 default);
// has been activated.
// Oscillator functions
void enableOscillator(bool TF, bool battery, byte frequency);
// 0 = 1 Hz
// 1 = 1.024 kHz
// 2 = 4.096 kHz
// 3 = 8.192 kHz (Default if frequency byte is out of range);
void enable32kHz(bool TF);
// Turns the 32kHz output pin on (true); or off (false).
bool oscillatorCheck();
// Checks the status of the OSF (Oscillator Stop Flag);.
// If this returns false, then the clock is probably not
// giving you the correct time.
// The OSF is cleared by function setSecond();.
private:
byte decToBcd(byte val);
byte bcdToDec(byte val);
byte readControlByte(bool which);
// Read selected control byte: (0); reads 0x0e, (1) reads 0x0f
void writeControlByte(byte control, bool which);
// which == false -> 0x0e, true->0x0f.
#endif
