查看: 16419|回复: 2
求教如何用Arduino UNO R3为ATtiny85烧写程序
发表于 2017-6-13 10:02:42 | 显示全部楼层 |阅读模式
请教各位大神,如何使用Arduino UNO R3为ATtiny85烧写程序小弟根据如下资料提示进行操作仍然错误
https://create.arduino.cc/projecthub/arjun/programming-attiny85-with-arduino-uno-afb829
接线图如下:
IDE返回错误如下:
  1. avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
  2.          Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
  3.          Copyright (c) 2007-2014 Joerg Wunsch
  4.          System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
  5.          Using Port                    : COM4
  6.          Using Programmer              : stk500v1
  7.          Overriding Baud Rate          : 19200
  8. avrdude: Send: 0 [30]   [20]
  9. avrdude: Send: 0 [30]   [20]
  10. avrdude: Send: 0 [30]   [20]
  11. avrdude: ser_recv(): programmer is not responding
  12. avrdude: stk500_recv(): programmer is not responding
  13. avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
  14. avrdude: Send: 0 [30]   [20]
  15. avrdude: ser_recv(): programmer is not responding
  16. avrdude: stk500_recv(): programmer is not responding
  17. avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
  18. avrdude: Send: 0 [30]   [20]
  19. avrdude: ser_recv(): programmer is not responding
  20. avrdude: stk500_recv(): programmer is not responding
  21. avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
  22. avrdude: Send: 0 [30]   [20]
  23. avrdude: ser_recv(): programmer is not responding
  24. avrdude: stk500_recv(): programmer is not responding
  25. avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
  26. avrdude: Send: 0 [30]   [20]
  27. avrdude: ser_recv(): programmer is not responding
  28. avrdude: stk500_recv(): programmer is not responding
  29. avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
  30. avrdude: Send: 0 [30]   [20]
  31. avrdude: ser_recv(): programmer is not responding
  32. avrdude: stk500_recv(): programmer is not responding
  33. avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
  34. avrdude: Send: 0 [30]   [20]
  35. avrdude: ser_recv(): programmer is not responding
  36. avrdude: stk500_recv(): programmer is not responding
  37. avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
  38. avrdude: Send: 0 [30]   [20]
  39. avrdude: ser_recv(): programmer is not responding
  40. avrdude: stk500_recv(): programmer is not responding
  41. avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
  42. avrdude: Send: 0 [30]   [20]
  43. avrdude: ser_recv(): programmer is not responding
  44. avrdude: stk500_recv(): programmer is not responding
  45. avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
  46. avrdude: Send: 0 [30]   [20]
  47. avrdude: ser_recv(): programmer is not responding
  48. avrdude: stk500_recv(): programmer is not responding
  49. avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
  50. avrdude done.  Thank you.
  51. 烧录引导程序出错。
发表于 2017-6-13 10:34:15 | 显示全部楼层
 楼主| 发表于 2017-6-13 13:28:58 | 显示全部楼层
已在论坛找到解决方法,谢谢楼上
GMT+8, 2024-4-25 09:56 , Processed in 0.071517 second(s), 19 queries .
