查看: 15976|回复: 3
ArduBlock无法编译
发表于 2017-7-6 12:39:15 | 显示全部楼层 |阅读模式
    求助大家:我使用的arduinoIDE版本是1.8.1,Windows10 32位操作系统。
现在正确安装了ardublock,但是无法生成C代码。
点击“下载到arduino”后IDE没有反应,下面出现如下信息:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Editor.setText(Ljava/lang/String;)
        at com.ardublock.ArduBlockTool.didGenerate(ArduBlockTool.java:45)
        at com.ardublock.core.Context.didGenerate(Context.java:173)
        at com.ardublock.ui.listener.GenerateCodeButtonListener.actionPerformed(GenerateCodeButtonListener.java:122)
        at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
        at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
        at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
        at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
        at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
        at java.awt.Component.processMouseEvent(Component.java:6533)
        at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
        at java.awt.Component.processEvent(Component.java:6298)
        at java.awt.Container.processEvent(Container.java:2236)
        at java.awt.Component.dispatchEventImpl(Component.java:4889)
        at java.awt.Container.dispatchEventImpl(Container.java:2294)
        at java.awt.Component.dispatchEvent(Component.java:4711)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
        at java.awt.Container.dispatchEventImpl(Container.java:2280)
        at java.awt.Window.dispatchEventImpl(Window.java:2746)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
        at java.awt.EventQueue.access$500(EventQueue.java:97)
        at java.awt.EventQueue$3.run(EventQueue.java:709)
        at java.awt.EventQueue$3.run(EventQueue.java:703)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
        at java.awt.EventQueue$4.run(EventQueue.java:731)
        at java.awt.EventQueue$4.run(EventQueue.java:729)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
但把IDE降级到1.6.11(低一些的版本)就可以正常使用。请大家帮忙解决一下,谢谢。
发表于 2017-9-29 17:32:04 | 显示全部楼层
我目前也遇到这个问题了,ArduBlock无法在arduinoIDE 1.8.1中获取C代码,出现的故障原因,与楼主粘贴的一样,不知楼主最后解决了吗?谢谢。
 楼主| 发表于 2018-2-10 12:00:15 | 显示全部楼层
碌碌无为 发表于 2017-9-29 17:32
我目前也遇到这个问题了,ArduBlock无法在arduinoIDE 1.8.1中获取C代码,出现的故障原因,与楼主粘贴的一样 ...
没有。我换了个低版本的。其实我不怎么用这个东西。
发表于 2018-4-8 18:15:00 | 显示全部楼层
感谢楼主回复。
GMT+8, 2024-4-25 16:08 , Processed in 0.038740 second(s), 19 queries .
