查看: 14159|回复: 3
SimpleSDAudio 库播放音乐声音怎么放大
发表于 2017-7-25 15:25:01 | 显示全部楼层 |阅读模式
如果是三极管 的话 请给个电路    改代码的话
在下面
[kenrobot_code]
#include <SimpleSDAudio.h>
// Callback target, prints output to serial
void DirCallback(char *buf)
        Serial.println(buf);
char AudioFileName[16];
// Create static buffer
#define BIGBUFSIZE (2*512)      // bigger than 2*512 is often only possible on Arduino megas!
uint8_t bigbuf[BIGBUFSIZE];
// helper function to determine free ram at runtime
int freeRam ()
        extern int __heap_start, *__brkval;
        int v;
        return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
// Open serial communications and wait for port to open:
        while (!Serial)
                ; // wait for serial port to connect. Needed for Leonardo only
        Serial.print(F("Free Ram: "));
        Serial.println(freeRam());
        // Setting the buffer manually for more flexibility
        SdPlay.setWorkBuffer(bigbuf, BIGBUFSIZE);
        Serial.print(F("\nInitializing SimpleSDAudio V" SSDA_VERSIONSTRING " ..."));
        // If your SD card CS-Pin is not at Pin 4, enable and adapt the following line:
        //SdPlay.setSDCSPin(10);
        // Select between SSDA_MODE_FULLRATE or SSDA_MODE_HALFRATE (62.5kHz or 31.25kHz)
        // and the output modes SSDA_MODE_MONO_BRIDGE, SSDA_MODE_MONO or SSDA_MODE_STEREO
        if (!SdPlay.init(SSDA_MODE_FULLRATE | SSDA_MODE_MONO | SSDA_MODE_AUTOWORKER))
                Serial.println(F("initialization failed. Things to check:"));
                Serial.println(F("* is a card is inserted?"));
                Serial.println(F("* Is your wiring correct?"));
                Serial.println(F("* maybe you need to change the chipSelect pin to match your shield or module?"));
                Serial.print(F("Error code: "));
                Serial.println(SdPlay.getLastError());
                while(1);
                Serial.println(F("Wiring is correct and a card is present."));
void loop(void)
        uint8_t count = 0, c, flag;
        Serial.println(F("Files on card:"));
        SdPlay.dir(&DirCallback);
ReEnter:
        count = 0;
        Serial.println(F("\r\nEnter filename (send newline after input):"));
        do
                while(!Serial.available()) ;
                c = Serial.read();
                if(c > ' ') AudioFileName[count++] = c;
        while((c != 0x0d) && (c != 0x0a) && (count < 14));
        AudioFileName[count++] = 0;
        Serial.print(F("Looking for file... "));
        if(!SdPlay.setFile(AudioFileName))
                Serial.println(F(" not found on card! Error code: "));
                goto ReEnter;
                Serial.println(F("found."));
        Serial.println(F("Press s for stop, p for play, h for pause, f to select new file, d for deinit, v to view status."));
        flag = 1;
        while(flag)
                SdPlay.worker();  // You can remove this line if you like - worker is not necessary
                if(Serial.available())
                        c = Serial.read();
                        switch(c)
                                case 's':
                                        SdPlay.stop();
                                        Serial.println(F("Stopped."));
                                case 'p':
                                        SdPlay.play();
                                        Serial.println(F("Play."));
                                case 'h':
                                        SdPlay.pause();
                                        Serial.println(F("Pause."));
                                case 'd':
                                        SdPlay.deInit();
                                        Serial.println(F("SdPlay deinitialized. You can now safely remove card. System halted."));
                                        while(1) ;
                                case 'f':
                                        flag = 0;
                                case 'v':
                                        Serial.print(F("Status: isStopped="));
                                        Serial.print(SdPlay.isStopped());
                                        Serial.print(F(", isPlaying="));
                                        Serial.print(SdPlay.isPlaying());
                                        Serial.print(F(", isPaused="));
                                        Serial.print(SdPlay.isPaused());
                                        Serial.print(F(", isUnderrunOccured="));
                                        Serial.print(SdPlay.isUnderrunOccured());
                                        Serial.print(F(", getLastError="));
                                        Serial.print(F("Free RAM: "));
[/kenrobot_code]
发表于 2017-7-25 19:01:15 | 显示全部楼层
用功放板算解决方案吗
发表于 2017-7-26 21:34:03 | 显示全部楼层
播放和放大是两件事,我理解你已经解决播放的事了,现在想放大音量。音频放大和功放板子多的事,只是不知道你播放用什么板子,输出信号的规格,是否有音量控制?了解了这些才可能去找合适的放大器。
发表于 2017-7-28 21:02:08 | 显示全部楼层
这个库,是利用PWM输出驱动喇叭发音的。在输出那边用一个较小的电容,比如103P~4.7uf隔离后,可以接比如说LM2822,8002等功率放大电路。参数需要你自己调整。但是,这有意义吗?这个库,解码能力很差,还不如找一个专门的Mp3/WAV解码芯片,外挂进行控制。
GMT+8, 2024-4-19 00:55 , Processed in 0.054668 second(s), 20 queries .
