另外帮你补充一点,事实上引脚是可以定义的,在1.0以上版本的boards.txt文件里每种板子有类似atmega8.build.variant=standard的参数根据这个参数你可以在variants文件夹中找到对应的文件夹下的
pins_arduino.h文件这个文件就定义了引脚的对应功能,如果你愿意,你可以用多数AVR芯片(99%)来做Arduino兼容.以1.0为例我做一下简单注释(1.0以前的此文件在\hardware\arduino\cores\arduino文件夹下,不需要variant参数指定,但还要和pins_arduino.c配合设置)
- pins_arduino.h - Pin definition functions for Arduino
- Part of Arduino - [url]http://www.arduino.cc/[/url]
- Copyright (c) 2007 David A. Mellis
- This library is free software; you can redistribute it and/or
- modify it under the terms of the GNU Lesser General Public
- License as published by the Free Software Foundation; either
- version 2.1 of the License, or (at your option) any later version.
- This library is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- Lesser General Public License for more details.
- You should have received a copy of the GNU Lesser General
- Public License along with this library; if not, write to the
- Free Software Foundation, Inc., 59 Temple Place, Suite 330,
- Boston, MA 02111-1307 USA
- $Id: wiring.h 249 2007-02-03 16:52:51Z mellis $
- #ifndef Pins_Arduino_h
- #define Pins_Arduino_h
- #include <avr/pgmspace.h>
- #define NUM_DIGITAL_PINS 20 //定义20个数字脚
- #define NUM_ANALOG_INPUTS 6//定义6个模拟
- #define analogInputToDigitalPin(p) ((p < 6) ? (p) + 14 : -1)
- //下面几行是PWM
- #if defined(__AVR_ATmega8__)
- #define digitalPinHasPWM(p) ((p) == 9 || (p) == 10 || (p) == 11)
- #else
- #define digitalPinHasPWM(p) ((p) == 3 || (p) == 5 || (p) == 6 || (p) == 9 || (p) == 10 || (p) == 11)
- #endif
- //下面是一些特殊复用功能的定义
- static const uint8_t SS = 10;
- static const uint8_t MOSI = 11;
- static const uint8_t MISO = 12;
- static const uint8_t SCK = 13;
- static const uint8_t SDA = 18;
- static const uint8_t SCL = 19;
- static const uint8_t LED_BUILTIN = 13;
- static const uint8_t A0 = 14;
- static const uint8_t A1 = 15;
- static const uint8_t A2 = 16;
- static const uint8_t A3 = 17;
- static const uint8_t A4 = 18;
- static const uint8_t A5 = 19;
- static const uint8_t A6 = 20;
- static const uint8_t A7 = 21;
- #define digitalPinToPCICR(p) (((p) >= 0 && (p) <= 21) ? (&PCICR) : ((uint8_t *)0))
- #define digitalPinToPCICRbit(p) (((p) <= 7) ? 2 : (((p) <= 13) ? 0 : 1))
- #define digitalPinToPCMSK(p) (((p) <= 7) ? (&PCMSK2) : (((p) <= 13) ? (&PCMSK0) : (((p) <= 21) ? (&PCMSK1) : ((uint8_t *)0))))
- #define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 13) ? ((p) - 8) : ((p) - 14)))
- #ifdef ARDUINO_MAIN
- // On the Arduino board, digital pins are also used
- // for the analog output (software PWM). Analog input
- // pins are a separate set.
- // ATMEL ATMEGA8 & 168 / ARDUINO
- // PC6 1| |28 PC5 (AI 5)
- // (D 0) PD0 2| |27 PC4 (AI 4)
- // (D 1) PD1 3| |26 PC3 (AI 3)
- // (D 2) PD2 4| |25 PC2 (AI 2)
- // PWM+ (D 3) PD3 5| |24 PC1 (AI 1)
- // (D 4) PD4 6| |23 PC0 (AI 0)
- // VCC 7| |22 GND
- // GND 8| |21 AREF
- // PB6 9| |20 AVCC
- // PB7 10| |19 PB5 (D 13)
- // PWM+ (D 5) PD5 11| |18 PB4 (D 12)
- // PWM+ (D 6) PD6 12| |17 PB3 (D 11) PWM
- // (D 7) PD7 13| |16 PB2 (D 10) PWM
- // (D 8) PB0 14| |15 PB1 (D 9) PWM
- // (PWM+ indicates the additional PWM pins on the ATmega168.)
- // ATMEL ATMEGA1280 / ARDUINO
- // 0-7 PE0-PE7 works
- // 8-13 PB0-PB5 works
- // 14-21 PA0-PA7 works
- // 22-29 PH0-PH7 works
- // 30-35 PG5-PG0 works
- // 36-43 PC7-PC0 works
- // 44-51 PJ7-PJ0 works
- // 52-59 PL7-PL0 works
- // 60-67 PD7-PD0 works
- // A0-A7 PF0-PF7
- // A8-A15 PK0-PK7
- // these arrays map port names (e.g. port B) to the
- // appropriate addresses for various functions (e.g. reading
- // and writing)
- //模式定义
- const uint16_t PROGMEM port_to_mode_PGM[] = {
- NOT_A_PORT,
- NOT_A_PORT,
- (uint16_t) &DDRB,
- (uint16_t) &DDRC,
- (uint16_t) &DDRD,
- //输出定义
- const uint16_t PROGMEM port_to_output_PGM[] = {
- NOT_A_PORT,
- NOT_A_PORT,
- (uint16_t) &PORTB,
- (uint16_t) &PORTC,
- (uint16_t) &PORTD,
- //输入定义
- const uint16_t PROGMEM port_to_input_PGM[] = {
- NOT_A_PORT,
- NOT_A_PORT,
- (uint16_t) &PINB,
- (uint16_t) &PINC,
- (uint16_t) &PIND,
- //下面这两组数组定义要匹配对应来定义引脚,按0到最大定义引脚上限数顺序,现在是0~20
- //举例说明:下面的0脚被定义为PD0(PD _BV(0))
- const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
- PD, /* 0 */
- PD,
- PD,
- PD,
- PD,
- PD,
- PD,
- PD,
- PB, /* 8 */
- PB,
- PB,
- PB,
- PB,
- PB,
- PC, /* 14 */
- PC,
- PC,
- PC,
- PC,
- PC,
- const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
- _BV(0), /* 0, port D */
- _BV(1),
- _BV(2),
- _BV(3),
- _BV(4),
- _BV(5),
- _BV(6),
- _BV(7),
- _BV(0), /* 8, port B */
- _BV(1),
- _BV(2),
- _BV(3),
- _BV(4),
- _BV(5),
- _BV(0), /* 14, port C */
- _BV(1),
- _BV(2),
- _BV(3),
- _BV(4),
- _BV(5),
- //下面是TIMER的设置
- const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
- NOT_ON_TIMER, /* 0 - port D */
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- // on the ATmega168, digital pin 3 has hardware pwm
- NOT_ON_TIMER,
- #else
- TIMER2B,
- #endif
- NOT_ON_TIMER,
- // on the ATmega168, digital pins 5 and 6 have hardware pwm
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- #else
- TIMER0B,
- TIMER0A,
- #endif
- NOT_ON_TIMER,
- NOT_ON_TIMER, /* 8 - port B */
- TIMER1A,
- TIMER1B,
- TIMER2,
- #else
- TIMER2A,
- #endif
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- NOT_ON_TIMER, /* 14 - port C */
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- NOT_ON_TIMER,
- #endif
- #endif
我说的不一定准确,也是瞎搞,仅供参考。更复杂的芯片你需要参考MEGA的参数设定,如果是xmega的话核心库也要改动
