发表于 2014-8-28 23:49:40
显示全部楼层
// matrixclock0828.ino
int pbIn = 0; // 定义中断引脚为0,也就是D2引脚
int ledOut = 13; // 定义输出指示灯引脚
volatile int state = LOW; // 定义默认输入状态
// 置ledOut引脚为输出状态
pinMode(ledOut, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
// 监视中断输入引脚的变化
attachInterrupt(pbIn, stateChange, LOW);
byte counter=0;
switch (counter) {
case 1:
digitalWrite(8, HIGH);
case 2:
digitalWrite(9, HIGH);
case 3:
digitalWrite(13, HIGH);
default:
counter=0;
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(13, LOW);
/*digitalWrite(ledOut, HIGH);
delay(counter*1000);
digitalWrite(ledOut, LOW);
delay(counter*1000); */
void stateChange()
pinMode(2, INPUT);
if(digitalRead(2)==LOW){
counter++;
while(digitalRead(2)==LOW);
