查阅了资料了,控制电调使用SERVO库就行,
所以我使用这个
#include <Servo.h>//Using servo library to control ESC
Servo esc; //Creating a servo class with name as esc
esc.attach(8); //Specify the esc signal pin,Here as D8
esc.writeMicroseconds(1000); //initialize the signal to 1000
int val; //Creating a variable val
val= analogRead(A0); //Read input from analog pin a0 and store in val
val= map(val, 0, 1023,1000,2000); //mapping val to minimum and maximum(Change if needed)
esc.writeMicroseconds(val); //using val as the signal to esc
但是这个代码要使用读度电位器值来控制电机
那请问,如果我不用电位器控制电机正反的话,
修改那个代码可以让电机自动正反和刹车呢?
