发表于 2013-3-9 22:59:28
显示全部楼层
研究的比较透彻。借花献佛。
传一份arduion控制LEGO红外接收器的avr代码,有助于真正了解红外编码协议。- #include <avr/io.h>
- #include <avr/delay.h>
- #define PININ (_BV(1)|_BV(2)|_BV(3)|_BV(4))
- #define LEFT _BV(1)
- #define FORW _BV(2)
- #define BACK _BV(3)
- #define RIGHT _BV(4)
- void setup(void)
- // PB0 is outout
- DDRB = _BV(0);
- // Pull-up input pins
- PORTB = PININ;
- // 9600000/8 Hz / (2 * 16) = 37500 Hz
- OCR0A = 16;
- // toggle output compare A (=PB0)
- TCCR0A = (1 << COM0A0)|(1<<WGM01);
- void on(void)
- // start timer; divide by 8
- TCCR0B = (1 << CS01);
- void off(void)
- // stop timer
- TCCR0B = 0;
- // clear PB0
- PORTB = PININ;
- void xmit( uint16_t ontime, uint16_t offtime ) {
- on();
- _delay_loop_2(ontime); // 4 * ontime clocks
- off();
- _delay_loop_2(offtime);
- #define ONTIME (2500/4)
- #define HITIME (4583/4)
- #define LOTIME (1666/4)
- #define BTIME (9200/4)
- #define ETIME (625000/4)
- void xmitcode(uint16_t code) {
- xmit(ONTIME,BTIME);
- for( int i = 0; i < 16; i++ ) {
- xmit(ONTIME, (code & 0x8000) ? HITIME : LOTIME );
- code = code << 1;
- xmit(ONTIME,0);
- // calling _delay_loop_2 with ETIME causes an overflow
- for( int i = 0; i < 256; i++ )
- _delay_loop_2(ETIME/256);
- #define CH1RFORBFOR 0x015b
- #define CH1RFORBREV 0x0197
- #define CH1RREVBFOR 0x0168
- #define CH1RREVBREV 0x01a4
- #define CH1RFOR 0x8117
- #define CH1RREV 0x8124
- #define CH1BFOR 0x8142
- #define CH1BREV 0x818e
- #define CH1NONE 0x010e
- int main(void)
- setup();
- for(;;) {
- uint8_t pin = ~(PINB & PININ);
- if( pin & FORW )
- xmitcode(CH1RFORBREV);
- else if( pin & BACK )
- xmitcode(CH1RREVBFOR);
- else if( pin & LEFT )
- xmitcode(CH1RREVBREV);
- else if( pin & RIGHT )
- xmitcode(CH1RFORBFOR);
- else
- xmitcode(CH1NONE);
复制代码 |
评分
查看全部评分
