这个PIN_MAP我翻了一下,
extern const stm32_pin_info PIN_MAP[BOARD_NR_GPIO_PINS] = {
{&gpioa, &timer2, &adc1, 0, 1, 0}, /* PA0 */
{&gpioa, &timer2, &adc1, 1, 2, 1}, /* PA1 */
{&gpioa, &timer2, &adc1, 2, 3, 2}, /* PA2 */
{&gpioa, &timer2, &adc1, 3, 4, 3}, /* PA3 */
{&gpioa, NULL, &adc1, 4, 0, 4}, /* PA4 */
{&gpioa, NULL, &adc1, 5, 0, 5}, /* PA5 */
{&gpioa, &timer3, &adc1, 6, 1, 6}, /* PA6 */
{&gpioa, &timer3, &adc1, 7, 2, 7}, /* PA7 */
{&gpioa, &timer1, NULL, 8, 1, ADCx}, /* PA8 */
{&gpioa, &timer1, NULL, 9, 2, ADCx}, /* PA9 */
{&gpioa, &timer1, NULL, 10, 3, ADCx}, /* PA10 */
{&gpioa, &timer1, NULL, 11, 4, ADCx}, /* PA11 */
{&gpioa, NULL, NULL, 12, 0, ADCx}, /* PA12 */
{&gpioa, NULL, NULL, 13, 0, ADCx}, /* PA13 */
{&gpioa, NULL, NULL, 14, 0, ADCx}, /* PA14 */
{&gpioa, NULL, NULL, 15, 0, ADCx}, /* PA15 */
{&gpiob, &timer3, &adc1, 0, 3, 8}, /* PB0 */
{&gpiob, &timer3, &adc1, 1, 4, 9}, /* PB1 */
{&gpiob, NULL, NULL, 2, 0, ADCx}, /* PB2 */
{&gpiob, NULL, NULL, 3, 0, ADCx}, /* PB3 */
{&gpiob, NULL, NULL, 4, 0, ADCx}, /* PB4 */
{&gpiob, NULL, NULL, 5, 0, ADCx}, /* PB5 */
{&gpiob, &timer4, NULL, 6, 1, ADCx}, /* PB6 */
{&gpiob, &timer4, NULL, 7, 2, ADCx}, /* PB7 */
{&gpiob, &timer4, NULL, 8, 3, ADCx}, /* PB8 */
{&gpiob, &timer4, NULL, 9, 4, ADCx}, /* PB9 */
{&gpiob, NULL, NULL, 10, 0, ADCx}, /* PB10 */
{&gpiob, NULL, NULL, 11, 0, ADCx}, /* PB11 */
{&gpiob, NULL, NULL, 12, 0, ADCx}, /* PB12 */
{&gpiob, NULL, NULL, 13, 0, ADCx}, /* PB13 */
{&gpiob, NULL, NULL, 14, 0, ADCx}, /* PB14 */
{&gpiob, NULL, NULL, 15, 0, ADCx}, /* PB15 */
{&gpioc, NULL, NULL, 13, 0, ADCx}, /* PC13 */
{&gpioc, NULL, NULL, 14, 0, ADCx}, /* PC14 */
{&gpioc, NULL, NULL, 15, 0, ADCx}, /* PC15 */
其实就是个小数组,它储存的是每个GPIO地址以及作用,和32的flash大小相比也不算很占空间,改动的可能性不大,毕竟牵一发而动全身。
它有一套很像标准外设库的东西,如果追求IO翻转速度的话可以直接调用,例如下面这个是digitalWrite函数:
void digitalWrite(uint8 pin, uint8 val) {
if (pin >= BOARD_NR_GPIO_PINS) {
return;
gpio_write_bit(PIN_MAP[pin].gpio_device, PIN_MAP[pin].gpio_bit, val);
可以看到一个gpio_write_bit函数,直接操作寄存器了,下面是它的原型:
static inline void gpio_write_bit(gpio_dev *dev, uint8 pin, uint8 val) {
val = !val; /* "set" bits are lower than "reset" bits */
dev->regs->BSRR = (1U << pin) << (16 * val);
如果想让PB12输出一个高电平,一般写法:
digitalWrite(PB12,HIGH);
高效一点的:
gpio_write_bit(&gpiob,12,1);
再高效一点:
(&gpiob)->regs->BSRR = (1U << 12) << (16 * 0);
51单片机听说跑C++效率很低,移植的可能性应该不大,不过听说有一个51duino,可以搜搜看。
STM8单片机还真有人搞过,这是链接:https://github.com/tenbaht/sduino |
