发表于 2013-12-29 23:47:13
显示全部楼层
slave code:
// Written by Nick Gammon
// April 2011
#include "pins_arduino.h"
// what to do with incoming data
byte command = 0;
// start of transaction, no command yet
void ss_falling ()
command = 0;
} // end of interrupt service routine (ISR) ss_falling
void setup (void)
// have to send on master in, *slave out*
pinMode(MISO, OUTPUT);
// turn on SPI in slave mode
SPCR |= _BV(SPE);
// turn on interrupts
SPCR |= _BV(SPIE);
// interrupt for SS falling edge
attachInterrupt (0, ss_falling, FALLING);
} // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR;
switch (command)
// no command? then this is the command
case 0:
command = c;
SPDR = 0;
// add to incoming byte, return result
case 'a':
SPDR = c + 15; // add 15
// subtract from incoming byte, return result
case 's':
SPDR = c - 8; // subtract 8
} // end of switch
} // end of interrupt service routine (ISR) SPI_STC_vect
void loop (void)
// all done with interrupts
} // end of loop
Master (example)
// April 2011
#include <SPI.h>
void setup (void)
Serial.begin (115200);
Serial.println ();
digitalWrite(SS, HIGH); // ensure SS stays high for now
// Put SCK, MOSI, SS pins into output mode
// also put SCK, MOSI into LOW state, and SS into HIGH state.
// Then put SPI hardware into Master mode and turn SPI on
SPI.begin ();
// Slow down the master a bit
SPI.setClockDivider(SPI_CLOCK_DIV8);
} // end of setup
byte transferAndWait (const byte what)
byte a = SPI.transfer (what);
delayMicroseconds (20);
return a;
} // end of transferAndWait
void loop (void)
byte a, b, c, d;
// enable Slave Select
digitalWrite(SS, LOW);
transferAndWait ('a'); // add command
transferAndWait (10);
a = transferAndWait (17);
b = transferAndWait (33);
c = transferAndWait (42);
d = transferAndWait (0);
// disable Slave Select
Serial.println ("Adding results:");
Serial.println (a, DEC);
Serial.println (b, DEC);
Serial.println (c, DEC);
Serial.println (d, DEC);
transferAndWait ('s'); // subtract command
Serial.println ("Subtracting results:");
delay (1000); // 1 second delay
} // end of loop
