Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems:
The import com.ardublock.translator.block.dfrobot.DfrobotAnalogOuptutBlock cannot be resolved
The import com.ardublock.translator.block.dfrobot.DfrobotPushButtonBlock cannot be resolved
DfrobotPushButtonBlock cannot be resolved to a type
DfrobotAnalogOuptutBlock cannot be resolved to a type
at com.ardublock.translator.block.TranslatorBlockFactory.<init>(TranslatorBlockFactory.java:5)
at com.ardublock.translator.adaptor.OpenBlocksAdaptor.<init>(OpenBlocksAdaptor.java:15)
at com.ardublock.translator.Translator.buildOpenBlocksAdaptor(Translator.java:124)
at com.ardublock.translator.Translator.reset(Translator.java:117)
at com.ardublock.translator.Translator.<init>(Translator.java:38)
at com.ardublock.ui.listener.GenerateCodeButtonListener.actionPerformed(GenerateCodeButtonListener.java:37)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
