下面我们开始学习Processing自带库-----PDF。
这个库实际上是用来导出生成PDF的,导出的可以是文件,也可以是图片甚至可以是连续动画的每一帧。
下面我们看一个官方自动的例程。 - import processing.pdf.*;
- void setup() {
- size(400, 400, PDF, "filename.pdf");
- void draw() {
- // Draw something good here
- line(0, 0, width/2, height);
- // Exit the program
- println("Finished.");
- exit();
这个就是成生产的PDF
- * PDF Complex
- * by Marius Watz (workshop.evolutionzone.com).
- * Example using PDF to output complex 3D geometry for print.
- * Press "s" to save a PDF.
- import processing.opengl.*;
- // Trig lookup tables borrowed from Toxi. Cryptic but effective
- float sinLUT[];
- float cosLUT[];
- float SINCOS_PRECISION=1.0;
- int SINCOS_LENGTH= int((360.0/SINCOS_PRECISION));
- // System data
- boolean dosave=false;
- int num;
- float pt[];
- int style[];
- void setup() {
- size(600, 600, OPENGL);
- frameRate(24);
- background(255);
- // Fill the tables
- sinLUT=new float[SINCOS_LENGTH];
- cosLUT=new float[SINCOS_LENGTH];
- for (int i = 0; i < SINCOS_LENGTH; i++) {
- sinLUT[i]= (float)Math.sin(i*DEG_TO_RAD*SINCOS_PRECISION);
- cosLUT[i]= (float)Math.cos(i*DEG_TO_RAD*SINCOS_PRECISION);
- num = 150;
- pt = new float[6*num]; // rotx, roty, deg, rad, w, speed
- style = new int[2*num]; // color, render style
- // Set up arc shapes
- int index=0;
- float prob;
- for (int i=0; i<num; i++) {
- pt[index++] = random(PI*2); // Random X axis rotation
- pt[index++] = random(PI*2); // Random Y axis rotation
- pt[index++] = random(60,80); // Short to quarter-circle arcs
- if(random(100)>90) pt[index]=(int)random(8,27)*10;
- pt[index++] = int(random(2,50)*5); // Radius. Space them out nicely
- pt[index++] = random(4,32); // Width of band
- if(random(100)>90) pt[index]=random(40,60); // Width of band
- pt[index++] = radians(random(5,30))/5; // Speed of rotation
- // get colors
- prob = random(100);
- if(prob<30) style[i*2]=colorBlended(random(1), 255,0,100, 255,0,0, 210);
- else if(prob<70) style[i*2]=colorBlended(random(1), 0,153,255, 170,225,255, 210);
- else if(prob<90) style[i*2]=colorBlended(random(1), 200,255,0, 150,255,0, 210);
- else style[i*2]=color(255,255,255, 220);
- if(prob<50) style[i*2]=colorBlended(random(1), 200,255,0, 50,120,0, 210);
- else if(prob<90) style[i*2]=colorBlended(random(1), 255,100,0, 255,255,0, 210);
- style[i*2+1]=(int)(random(100))%3;
- void draw() {
- if(dosave) {
- // set up PGraphicsPDF for use with beginRaw()
- PGraphicsPDF pdf = (PGraphicsPDF)beginRaw(PDF, "pdf_complex_out.pdf");
- // set default Illustrator stroke styles and paint background rect.
- pdf.strokeJoin(MITER);
- pdf.strokeCap(SQUARE);
- pdf.fill(0);
- pdf.noStroke();
- pdf.rect(0,0, width,height);
- background(0);
- int index=0;
- translate(width/2,height/2,0);
- rotateX(PI/6);
- rotateY(PI/6);
- pushMatrix();
- rotateX(pt[index++]);
- rotateY(pt[index++]);
- if(style[i*2+1]==0) {
- stroke(style[i*2]);
- noFill();
- strokeWeight(1);
- arcLine(0,0, pt[index++],pt[index++],pt[index++]);
- else if(style[i*2+1]==1) {
- fill(style[i*2]);
- noStroke();
- arcLineBars(0,0, pt[index++],pt[index++],pt[index++]);
- else {
- fill(style[i*2]);
- noStroke();
- arc(0,0, pt[index++],pt[index++],pt[index++]);
- // increase rotation
- pt[index-5]+=pt[index]/10;
- pt[index-4]+=pt[index++]/20;
- popMatrix();
- if(dosave) {
- endRaw();
- dosave=false;
- // Get blend of two colors
- public int colorBlended(float fract,
- float r, float g, float b,
- float r2, float g2, float b2, float a) {
- r2 = (r2 - r);
- g2 = (g2 - g);
- b2 = (b2 - b);
- return color(r + r2 * fract, g + g2 * fract, b + b2 * fract, a);
- // Draw arc line
- public void arcLine(float x,float y,float deg,float rad,float w) {
- int a=(int)(min (deg/SINCOS_PRECISION,SINCOS_LENGTH-1));
- int numlines=(int)(w/2);
- for (int j=0; j<numlines; j++) {
- beginShape();
- for (int i=0; i<a; i++) {
- vertex(cosLUT[i]*rad+x,sinLUT[i]*rad+y);
- endShape();
- rad += 2;
- // Draw arc line with bars
- public void arcLineBars(float x,float y,float deg,float rad,float w) {
- int a = int((min (deg/SINCOS_PRECISION,SINCOS_LENGTH-1)));
- a /= 4;
- beginShape(QUADS);
- for (int i=0; i<a; i+=4) {
- vertex(cosLUT[i]*(rad)+x,sinLUT[i]*(rad)+y);
- vertex(cosLUT[i]*(rad+w)+x,sinLUT[i]*(rad+w)+y);
- vertex(cosLUT[i+2]*(rad+w)+x,sinLUT[i+2]*(rad+w)+y);
- vertex(cosLUT[i+2]*(rad)+x,sinLUT[i+2]*(rad)+y);
- endShape();
- // Draw solid arc
- public void arc(float x,float y,float deg,float rad,float w) {
- int a = int(min (deg/SINCOS_PRECISION,SINCOS_LENGTH-1));
- beginShape(QUAD_STRIP);
- for (int i = 0; i < a; i++) {
- endShape();
- void keyPressed() {
- if (key == 's') {
- dosave=true;
- void mouseReleased() {
- background(255);
上面是官方自带的PDF程序中比较COOL的一个
