设备代码:- /* Audio camera trigger by Matt Richardson
- This is a basic sound-detecting camera & flash trigger for Arduino.
- Use a piezo element for the sensor (see http://www.arduino.cc/en/Tutorial/KnockSensor)
- Use opto isolators (aka optocouplers) for the flash and camera triggers
- Camera must be in BULB mode for shutter release to work
- #define BUTTON_PIN 5
- #define CAM_TRIGGER_PIN 11
- #define FLASH_TRIGGER_PIN 12
- #define SENSOR_PIN 0
- #define LED_PIN 10
- #define STANDBY 0
- #define ACTIVE 1
- #define WORKLIGHT_RELAY 9
- #define SENSOR_THRESHOLD 0
- int mode = STANDBY;
- // For best results, set flashDelayMS according to what type
- // of shot you're doing. 0 seems best for balloon burst while
- // 10 seems best for shattering glass. YMMV.
- long flashDelayMS = 10;
- void setup() {
- pinMode(BUTTON_PIN, INPUT);
- pinMode(CAM_TRIGGER_PIN, OUTPUT);
- pinMode(FLASH_TRIGGER_PIN, OUTPUT);
- pinMode(LED_PIN, OUTPUT);
- pinMode(WORKLIGHT_RELAY, OUTPUT);
- digitalWrite(LED_PIN, HIGH);
- digitalWrite(WORKLIGHT_RELAY, HIGH); //turn the lights on
- void loop() {
- if (digitalRead(BUTTON_PIN) == HIGH)
- mode = ACTIVE;
- digitalWrite(WORKLIGHT_RELAY, LOW); // turn the lights off
- delay(2000); // to give time for light to go down and settle after button push
- digitalWrite(LED_PIN, LOW); // show we're ready
- digitalWrite(CAM_TRIGGER_PIN, HIGH); // open the camera shutter
- if ((mode == ACTIVE) && (analogRead(SENSOR_PIN) > SENSOR_THRESHOLD)) //
- { //If we're in ACTIVE mode and we sense a pop:
- delay(flashDelayMS);
- digitalWrite(FLASH_TRIGGER_PIN, HIGH); // fire flash
- delay(50);
- digitalWrite(FLASH_TRIGGER_PIN, LOW);
- digitalWrite(CAM_TRIGGER_PIN, LOW); // close camera shutter
- mode = STANDBY;
- digitalWrite(WORKLIGHT_RELAY, HIGH); // turn lights back on
复制代码 作者BLOG:http://mattrichardson.com/blog/arduino-flash-trigger-parts-list/
里面有详细的材料介绍 |
