发表于 2012-4-12 18:18:58
显示全部楼层
找到一个tt的 - /*
- * Arduino ENC28J60 Ethernet shield twitter client
- #include "etherShield.h"
- // A pin to use as input to trigger tweets
- #define INPUT_PIN 0
- // Note: This software implements a web server and a web browser.
- // The web server is at "myip"
- // Please modify the following lines. mac and ip have to be unique
- // in your local area network. You can not have the same numbers in
- // two devices:
- // how did I get the mac addr? Translate the first 3 numbers into ascii is: TUX
- static uint8_t mymac[6] = {
- 0x54,0x55,0x58,0x10,0x00,0x25};
- static uint8_t myip[4] = {
- 10,0,0,25};
- // IP address of the twitter server to contact (IP of the first portion of the URL):
- // DNS look-up is a feature which we still need to add.
- static uint8_t websrvip[4] = {
- 128,121,146,228};
- // The name of the virtual host which you want to contact at websrvip (hostname of the first portion of the URL):
- #define WEBSERVER_VHOST "twitter.com"
- // The BLOGGACCOUNT Authorization code can be generated from
- // username and password of your twitter account
- // by using this encoder: [url]http://tuxgraphics.org/~guido/javascript/base64-javascript.html[/url]
- #define BLOGGACCOUNT "Authorization: Basic xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
- // Default gateway. The ip address of your DSL router. It can be set to the same as
- // websrvip the case where there is no default GW to access the
- // web server (=web server is on the same lan as this host)
- static uint8_t gwip[4] = {
- 10,0,0,1};
- // global string buffer for twitter message:
- static char statusstr[150];
- // listen port for tcp/www:
- #define MYWWWPORT 80
- // the password string, (only a-z,0-9,_ characters):
- static char password[]="secret";
- static volatile uint8_t start_web_client=0; // 0=off but enabled, 1=send tweet, 2=sending initiated, 3=twitter was sent OK, 4=diable twitter notify
- static uint8_t contact_onoff_cnt=0;
- static uint8_t web_client_attempts=0;
- static uint8_t web_client_sendok=0;
- static uint8_t resend=0;
- int buttonState; // the current reading from the input pin
- int lastButtonState = LOW; // the previous reading from the input pin
- // the follow variables are longs because the time, measured in milliseconds,
- // will quickly become a bigger number than can be stored in an int.
- long lastDebounceTime = 0; // the last time the output pin was toggled
- long debounceDelay = 200; // the debounce time, increase if the output flickers
- #define BUFFER_SIZE 650
- #define DATE_BUFFER_SIZE 30
- static char datebuf[DATE_BUFFER_SIZE]="none";
- static uint8_t buf[BUFFER_SIZE+1];
- EtherShield es=EtherShield();
- uint8_t verify_password(char *str)
- // the first characters of the received string are
- // a simple password/cookie:
- if (strncmp(password,str,strlen(password))==0){
- return(1);
- return(0);
- // analyse the url given
- // return values: -1 invalid password
- // -2 no command given
- // 0 switch off
- // 1 switch on
- // The string passed to this function will look like this:
- // /?mn=1&pw=secret HTTP/1.....
- // / HTTP/1.....
- int8_t analyse_get_url(char *str)
- uint8_t mn=0;
- char kvalstrbuf[10];
- // the first slash:
- if (str[0] == '/' && str[1] == ' '){
- // end of url, display just the web page
- return(2);
- // str is now something like ?pw=secret&mn=0 or just end of url
- if (es.ES_find_key_val(str,kvalstrbuf,10,"mn")){
- if (kvalstrbuf[0]=='1'){
- mn=1;
- // to change the mail notification one needs also a valid passw:
- if (es.ES_find_key_val(str,kvalstrbuf,10,"pw")){
- if (verify_password(kvalstrbuf)){
- return(mn);
- else{
- return(-1);
- // browsers looking for /favion.ico, non existing pages etc...
- return(-1);
- uint16_t http200ok(void)
- return(es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n")));
- // prepare the webpage by writing the data to the tcp send buffer
- uint16_t print_webpage(uint8_t *buf)
- uint16_t plen;
- char vstr[5];
- plen=http200ok();
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h2>Twitter notification status</h2>\n<pre>\n"));
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("Number of INPUT_PIN to GND connections: "));
- // convert number to string:
- itoa(contact_onoff_cnt,vstr,10);
- plen=es.ES_fill_tcp_data(buf,plen,vstr);
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\nNumber of twitter attempts: "));
- itoa(web_client_attempts,vstr,10);
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\nNumber successful twitter: "));
- itoa(web_client_sendok,vstr,10);
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\nDate of last twitter: "));
- plen=es.ES_fill_tcp_data(buf,plen,datebuf);
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\nTwitter notify is: "));
- if (start_web_client==4){
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("OFF"));
- else{
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("ON"));
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\n<form action=/ method=get>\npassw: <input type=password size=8 name=pw><input type=hidden name=mn "));
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("value=1><input type=submit value="enable twitter msg">"));
- else{
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("value=0><input type=submit value="disable twitter msg">"));
- plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</form>\n</pre><br><hr>tuxgraphics.org/blog.thiseldo.co.uk"));
- return(plen);
- void store_date_if_found(char *str)
- uint8_t i=100; // search the first 100 char
- uint8_t j=0;
- char datekeyword[]="Date: "; // not any repeating characters, search does not need to resume at partial match
- while(i && *str){
- if (j && datekeyword[j]=='\0'){
- // found date
- i=0;
- while(*str && *str!='\r' && *str!='\n' && i< DATE_BUFFER_SIZE-1){
- datebuf[i]=*str;
- str++;
- i++;
- datebuf[i]='\0';
- return;
- if (*str==datekeyword[j]){
- j++;
- else{
- j=0;
- str++;
- i--;
- void browserresult_callback(uint8_t statuscode,uint16_t datapos){
- if (statuscode==0){
- web_client_sendok++;
- // LEDOFF;
- // copy the "Date: ...." as returned by the server
- store_date_if_found((char *)&(buf[datapos]));
- // clear pending state at sucessful contact with the
- // web server even if account is expired:
- if (start_web_client==2) start_web_client=3;
- void setup(){
- // pinMode( LED_PIN, OUTPUT );
- pinMode( INPUT_PIN, INPUT );
- digitalWrite( INPUT_PIN, HIGH ); // Set internal pullup
- /*initialize enc28j60*/
- es.ES_enc28j60Init(mymac);
- //init the ethernet/ip layer:
- es.ES_init_ip_arp_udp_tcp(mymac,myip, MYWWWPORT);
- // init the web client:
- es.ES_client_set_gwip(gwip); // e.g internal IP of dsl router
- es.ES_client_set_wwwip(websrvip);
- void loop(){
- uint16_t dat_p;
- int8_t cmd;
- start_web_client=1;
- while(1){
- // handle ping and wait for a tcp packet
- dat_p=es.ES_packetloop_icmp_tcp(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
- if(dat_p==0){
- if (start_web_client==1){
- start_web_client=2;
- web_client_attempts++;
- // the twitter line is status=Url_encoded_string
- strcat(statusstr,"status=");
- // the text to send to twitter (append after status=):
- //urlencode("Meals are ready",&(statusstr[7]));
- es.ES_urlencode("Test of Arduino and ENC28J60 Ethernet Shield twitter client 1234567890",&(statusstr[7]));
- es.ES_client_http_post(PSTR("/statuses/update.xml"),PSTR(WEBSERVER_VHOST),PSTR(BLOGGACCOUNT),NULL,statusstr,&browserresult_callback);
- buttonState = digitalRead(INPUT_PIN);
- // check to see if you just pressed the button
- // (i.e. the input went from HIGH to LOW), and you've waited
- // long enough since the last press to ignore any noise:
- if ((buttonState == LOW) &&
- (lastButtonState == HIGH) &&
- (millis() - lastDebounceTime) > debounceDelay) {
- contact_onoff_cnt++;
- // ... and store the time of the last button press
- // in a variable:
- lastDebounceTime = millis();
- // Trigger a tweet
- resend=1; // resend once if it failed
- // save the buttonState. Next time through the loop,
- // it'll be the lastButtonState:
- lastButtonState = buttonState;
- continue;
- if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
- // head, post and other methods:
- // for possible status codes see:
- // [url]http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html[/url]
- dat_p=http200ok();
- dat_p=es.ES_fill_tcp_data_p(buf,dat_p,PSTR("<h1>200 OK</h1>"));
- goto SENDTCP;
- cmd=analyse_get_url((char *)&(buf[dat_p+4]));
- if (cmd==-1){
- dat_p=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 401 Unauthorized\r\nContent-Type: text/html\r\n\r\n<h1>401 Unauthorized</h1>"));
- goto SENDTCP;
- if (cmd==1 && start_web_client==4){
- // twitter was off, switch on
- start_web_client=0;
- if (cmd==0 ){
- start_web_client=4; // twitter off
- dat_p=print_webpage(buf);
- SENDTCP:
- es.ES_www_server_reply(buf,dat_p); // send data
复制代码 |
