楼主: davidce
自制基于arduino的GPS地图导航系统3.0
发表于 2018-1-22 11:25:31 | 显示全部楼层
波特率我设置9600,出现如下乱码,而且每次关闭串口再打开串口数据才发生变化:
)?姠瞓b姎b姫b偑抌毆R簜j
$GPGSV,3,2,10,15,43,037,42,18,46,327,45瑐R?5
$GPTXT,01,01,01,ANTENNA OK*35
b姫b娐b姎b挗b拪b拏b妭bbbbbb抮俠妑抌妑睷?5
$BDGSA,A,3,09,06,13,,,鼔墘墘墘Ir俠妑抌妑睷捖j
$GPGSV,3,1,10,05,10,116,,10,15,314,18,12,??uMY?,2,10,15,43,037,42,18,46,327,44,20,61,089,25,21,56,263,25b?b姎b?b拻?拏R?5
$GNRMC,024220.000,A,2605.1085,N,11913.9380,E$GNGGA,024222.000,2605?蕣歳蕷聤b*?24230.000,A,A*49
$GPGSA,A,3,15,18,13,24,21,20,10,,?,2018,00,00*44
覕J??24232.000,A,2605.1085,N,11913.9380,E,0.19,182.90,220118,,?GNGGA,024235.000,2605.1081,N,11913.9380,E,1,10,1.2,17.6,M,0??.00,182.90,220118,,,A*7A
$GNVTG,182.90,T,,M,0.00,N,0.00,K,A*2
回复 支持 1 反对 0
 楼主| 发表于 2018-1-22 20:02:49 | 显示全部楼层
)?姠瞓b姎b姫b偑抌毆R簜j ...
可能是你的gps库有问题
发表于 2018-1-23 23:46:20 | 显示全部楼层
GPS库我是直接使用您提供的库
发表于 2018-1-24 10:09:24 | 显示全部楼层
davidce 发表于 2018-1-22 20:02
可能是你的gps库有问题
楼主能把GPS的链接分享一下吗?做到这里没做出来觉得好难受啊
 楼主| 发表于 2018-1-24 23:04:39 | 显示全部楼层
楼顶有下载
发表于 2018-1-28 13:16:25 | 显示全部楼层
不同的GPS,TinyGPS库要哪里修改啊?
发表于 2018-1-30 20:04:21 | 显示全部楼层
楼主我想问一下,下载地图时,显示下载1失败,下载13失败,表示是1级和13级失败吗,怎么解决?
回复 支持 1 反对 0
发表于 2018-7-14 23:28:25 | 显示全部楼层
楼主,下载地图的算法哪里来,能发源码不
发表于 2018-11-2 18:46:41 | 显示全部楼层
你们还玩出了新花样,佩服!
发表于 2019-11-4 10:52:24 | 显示全部楼层
Hello,
I get ever "no MAP" message, The softwre map downloader is in chinese language, What values ​​do I need to enter in the software fields to get a map that works?
min 1---------max 17   ?
-999           -999    ?
GPS works fine but no map load to screen  ...
Thanks for helps!!!
发表于 2019-11-6 15:22:37 | 显示全部楼层
分享一个免费打样活动给大家。10*15的可以领免费打样券打出来,顺丰包邮哦。搜捷配注册可以领取哦,注册码G633
发表于 2019-11-9 09:31:32 | 显示全部楼层
Hello,
I used "15" as max zoom level and still maptile.exe does not generate .png tiles ... After 5 days of crazyng understanding how it worked, I discovered that the application works only for maps in Chinese territory ... Useless software .. .in the trash ....
 楼主| 发表于 2020-2-20 21:57:55 | 显示全部楼层
plore90 发表于 2019-11-9 09:31
Hello,
I used "15" as max zoom level and still maptile.exe does not generate .png tiles ... After 5  ...
I'm sorry about that, the applicaton of 'maptile.exe' used microsoft Bingmap javascript V7 map API to get map images, Bingmap has updated the map API many year ago, so the applicaton is useless in chinese too, I'll try to fix it, thanks for your feedback.
发表于 2020-9-29 09:16:37 | 显示全部楼层
那么早就能做出这东西了,自愧不如
发表于 2022-11-30 18:52:56 | 显示全部楼层
davidce 发表于 2020-2-20 21:57
I'm sorry about that, the applicaton of 'maptile.exe' used microsoft Bingmap javascript V7 map API ...
Have you fixed the map application? Or how to deal with the NO MAP problem. Thank you. This is a classic sketch of the ARDUINO GPS MAP NAV, and we look forward to its continued existence.
GMT+8, 2024-3-29 05:24 , Processed in 0.045426 second(s), 24 queries .
