// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd, 0x00, 0x15, 0x83, 0x3D, 0x0A, 0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printTemperature;
boolean printAngle;
Servo myservo;
int pos = 0;
myservo.attach(9);
Serial.begin(115200);
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
Serial.print(F("\r\nPS3 Bluetooth Library Started"));
Usb.Task();
Serial.print(F("\r\nttt"));
for(pos = 0; pos < 70; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
Serial.print(F("\r\nppp"));
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 70; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
#endif
USB Usb;
boolean printAngle;
Servo myservo;
int pos = 0;
myservo.attach(9);
Usb.Task();
