查看: 28099|回复: 10
OLED显示BMP05大气压强
发表于 2014-5-27 18:26:46 | 显示全部楼层 |阅读模式
用OLED显示大气压强中遇到个问题,单独的OLED可以,单独的大气压强也可以,两个组合就没有显示了。他们都用到了Write这个库。请问有好的办法解决吗?
This is an example for our Monochrome OLEDs based on SSD1306 drivers
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/category/63_98
This example is for a 128x64 size display using SPI to communicate
4 or 5 pins are required to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_DC 2
#define OLED_CS -1
#define OLED_CLK 5
#define OLED_MOSI 4
#define OLED_RESET 3
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
#define BMP085_ADDRESS 0x77  // BMP085的I2C地址
const unsigned char OSS = 0;  // 采样设置
// 校准值
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5用于计算bmp085GetTemperature(...),它也同时用于bmp085GetPressure(...)
// 所以Temperature(...)必须在Pressure(...)之前声明
long b5;
short temperature;
long pressure;
void setup()   {
  display.begin(SSD1306_SWITCHCAPVCC);
  display.clearDisplay();   // clears the screen and buffer
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(8,0);
  display.println("Pressure:");
  //Wire.begin();
// bmp085Calibration();
pressure = bmp085GetPressure(bmp085ReadUP());
// text display tests
  display.setCursor(16,32);
  display.setTextColor(WHITE); // 'inverted' text
  display.println((pressure/100.0));
  display.setCursor(90,32);
  display.print("hPa");
  display.display();
//  Serial.print((pressure/100.0), DEC);
//  Serial.println(" hPa");
//  Serial.println();
//  delay(1000);
void bmp085Calibration()
  ac1 = bmp085ReadInt(0xAA);
  ac2 = bmp085ReadInt(0xAC);
  ac3 = bmp085ReadInt(0xAE);
  ac4 = bmp085ReadInt(0xB0);
  ac5 = bmp085ReadInt(0xB2);
  ac6 = bmp085ReadInt(0xB4);
  b1 = bmp085ReadInt(0xB6);
  b2 = bmp085ReadInt(0xB8);
  mb = bmp085ReadInt(0xBA);
  mc = bmp085ReadInt(0xBC);
  md = bmp085ReadInt(0xBE);
// 计算压力
// 校准值必须是已知的
// B5在bmp085GetTemperature(...)需要使用,所以必须先调用。
// 返回值以Pa为单位
long bmp085GetPressure(unsigned long up)
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // 计算B3
  x1 = (b2 * (b6 * b6)>>12)>>11;
  x2 = (ac2 * b6)>>11;
  x3 = x1 + x2;
  b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  // 计算B4
  x1 = (ac3 * b6)>>13;
  x2 = (b1 * ((b6 * b6)>>12))>>16;
  x3 = ((x1 + x2) + 2)>>2;
  b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  if (b7 < 0x80000000)
    p = (b7<<1)/b4;
    p = (b7/b4)<<1;
  x1 = (p>>8) * (p>>8);
  x1 = (x1 * 3038)>>16;
  x2 = (-7357 * p)>>16;
  p += (x1 + x2 + 3791)>>4;
  return p;
// 在BMP085的'address'中读取一个字节
char bmp085Read(unsigned char address)
  unsigned char data;
  Wire.beginTransmission(BMP085_ADDRESS);
  Wire.write(address);
  Wire.endTransmission();
  Wire.requestFrom(BMP085_ADDRESS, 1);
  while(!Wire.available())  ;
  return Wire.read();
// 从BMP085读取两个字节
// 第一个字节是从'address'
// 第二个字节是从'address'+1
int bmp085ReadInt(unsigned char address)
  unsigned char msb, lsb;
  Wire.requestFrom(BMP085_ADDRESS, 2);
  while(Wire.available()<2);
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb<<8 | lsb;
// 读取未补偿的温度值
unsigned int bmp085ReadUT()
  unsigned int ut;
  // 在寄存器0xF4写入0x2E
  // 这个用来请求进行温度读取
  Wire.write(0xF4);
  Wire.write(0x2E);
  // 至少等待4.5ms
  delay(5);
  // 从寄存器0xF6与0xF7读取两个字节
  ut = bmp085ReadInt(0xF6);
  return ut;
// 读取未补偿的压力值
unsigned long bmp085ReadUP()
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  // 写入0x34+(OSS<<6)到寄存器0xF4
  // 请求气压数据读取
  Wire.write(0xF4);
  Wire.write(0x34 + (OSS<<6));
  // 等待转换,延迟时间依赖于OSS
  delay(2 + (3<<OSS));
  // 读取寄存器0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  Wire.write(0xF6);
  Wire.requestFrom(BMP085_ADDRESS, 3);
  // 等待数据变为可用
  while(Wire.available() < 3);
  msb = Wire.read();
  lsb = Wire.read();
  xlsb = Wire.read();
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  return up;
发表于 2014-5-27 18:46:07 来自手机 | 显示全部楼层
是不是端口冲突了?
 楼主| 发表于 2014-5-27 19:08:17 | 显示全部楼层
maxims 发表于 2014-5-27 18:46
是不是端口冲突了?
端口也没有冲突啊
发表于 2014-5-27 19:38:53 | 显示全部楼层
跟硬體有關的問題, 不是人人有同樣的硬體可以試的, 最好學習自己 debug.
你說獨立沒問題, 是指同時接上 OLED 及 BMP05 獨立行各自的程式, 還是獨立接上一個硬件, 行該硬件的程式?
既然你說 没有显示, 就先把問題簡單化,刪去 loop 的內容, 只在 setup 中測試 OLED 顯示.  可以先確認硬件是否有沖突.
发表于 2015-4-15 01:18:07 | 显示全部楼层
可惜我无法得到 Adafruit_SSD1306.h 文件,谢谢你能给一份
发表于 2015-5-3 17:09:21 | 显示全部楼层
你有没有u8glin库文件,我这里有SSD1306的库,求一份u8glib库文件
发表于 2015-5-3 18:27:02 | 显示全部楼层
我也没有u8glin库文件,只因不能上谷歌
发表于 2015-5-26 14:29:14 | 显示全部楼层
附件包括 Adafruit_SSD1306的两个库
Adafruit_SSD1306-master.zip
Adafruit-GFX-Library-master.zip
以及u8glib_arduino_v1.17.zip 最新的V1.17版本的库
发表于 2015-7-16 23:36:14 | 显示全部楼层
I2C的OLED能直接用你这个程序吗?
发表于 2017-7-28 12:49:31 | 显示全部楼层
直接打开Arduino IDE 项目-加载库-管理库右边搜索就好了可以直接下载
发表于 2017-8-9 18:54:43 | 显示全部楼层
有可能是中断冲突。
GMT+8, 2024-4-24 01:33 , Processed in 0.047765 second(s), 26 queries .
