查看: 26224|回复: 21
yeelink+wifi双开关控制
发表于 2014-6-6 10:44:47 | 显示全部楼层 |阅读模式
求高手帮忙看看,自己是在看不出哪错了,想不出怎么改
源码地址http://www.geek-workshop.com/thread-4194-1-1.html,供大家参考
我的,已经改好了,有兴趣的可以参考
  1. boolean ResponseBegin = false;
  2. String returnValue = "";
  3. unsigned long previousMillis = 0;
  4. unsigned long interval = 900;
  5. char flag =0;  //定义开关循环控制变量
  6. String SENSORno[]={"11941","14701"}; // 把sensor ID 依次替在这里,程序定义为数组,几个开关就写几个
  7. byte ledPin[]={12,13};   //定义输出的针脚
  8. char c ;
  9. void setup()
  10. {
  11.   pinMode(12,OUTPUT);
  12.   pinMode(13,OUTPUT);
  13.   Serial.begin(115200);
  14. }
  15. void loop()
  16. {
  17.     if(Serial.available())
  18.     c = Serial.read();
  19.   if(c == '{')
  20.     ResponseBegin = true;
  21.   if(c == '}')
  22.     ResponseBegin = false;
  23.   if (ResponseBegin)
  24.     returnValue += c;
  25.   if (returnValue.length() !=0 && (ResponseBegin == false))
  26.   {
  27.     if(returnValue.charAt(returnValue.length() - 1) == '1') //2hao
  28.       {
  29.         digitalWrite( ledPin[flag], HIGH);
  30.       Serial.println("ON");}
  31.     if(returnValue.charAt(returnValue.length() - 1) == '0')
  32.       {
  33.         digitalWrite( ledPin[flag], LOW);
  34.     Serial.println("OFF");}
  35.     returnValue = "";
  36.     flag ++;
  37.     if(flag>=2) flag =0;
  38.   }
  39.   unsigned long currentMillis = millis();
  40.   if(currentMillis - previousMillis > interval)
  41.   {
  42.     previousMillis = currentMillis;
  43.     Serial.print("GET /v1.0/device/7577/sensor/");
  44.     Serial.print(SENSORno[flag]);
  45.     Serial.println("/datapoints HTTP/1.1");
  46.     Serial.println("Host: api.yeelink.net");
  47.     Serial.print("Accept: *");
  48.     Serial.print("/");
  49.     Serial.println("*");
  50.     Serial.print("U-ApiKey: ");
  51.     Serial.println("175063fac1143fd891b2e1eb66f90ce6");   // 此处用你的APIKEY替代
  52.     Serial.println("Content-Length: 0");
  53.     Serial.println("Connection: close");
  54.     Serial.println();
  55.     }
  56. }
发表于 2014-6-6 10:47:15 | 显示全部楼层
从你的需求上看,flag的取值应该是0和1
但你的程序里,flag值跑飞了
http://www.arduino.cn/thread-5953-1-1.html
 楼主| 发表于 2014-6-6 10:48:47 | 显示全部楼层
那该怎么改呢,求指点
发表于 2014-6-6 10:55:39 | 显示全部楼层
マイナス37度 发表于 2014-6-6 10:48
那该怎么改呢,求指点
  1. flag ++;
  2. if(flag>=2) flag =0;
 楼主| 发表于 2014-6-6 11:16:02 | 显示全部楼层
代码已更新,还是不行{:soso_e101:}
有一点没想通为什么是》=不是《=
发表于 2014-6-6 14:05:05 | 显示全部楼层
マイナス37度 发表于 2014-6-6 11:16
代码已更新,还是不行
有一点没想通为什么是》=不是《=
先说控制一个灯的,你成功了么?
 楼主| 发表于 2014-6-6 15:41:29 | 显示全部楼层
i7456 发表于 2014-6-6 14:05
先说控制一个灯的,你成功了么?
恩,成功了
这是一个灯的代码
  5. char c ;
  6. void setup()
  7. {
  8.   Serial.begin(115200);
  9.   pinMode(13,OUTPUT);    //遥控pin13板载灯这一路
  10.
  11. }
  12. void loop()
  13. {
  14.   if(Serial.available())
  15.     c = Serial.read();
  16.   if(c == '{')
  17.     ResponseBegin = true;
  18.   if(c == '}')
  19.     ResponseBegin = false;
  20.   if (ResponseBegin)
  21.     returnValue += c;
  22.   if (returnValue.length() !=0 && (ResponseBegin == false))
  23.   {
  24.     if(returnValue.charAt(returnValue.length() - 1) == '1')
  25.       {digitalWrite(13,HIGH);Serial.println("ON");}
  26.     if(returnValue.charAt(returnValue.length() - 1) == '0')
  27.       {digitalWrite(13,LOW);Serial.println("OFF");}
  28.     returnValue = "";
  29.   }
  30.   unsigned long currentMillis = millis();
  31.   if(currentMillis - previousMillis > interval)
  32.   {
  33.     previousMillis = currentMillis;
  34.     Serial.println("GET /v1.0/device/7794/sensor/12316/datapoints HTTP/1.1"); /“/device/4290/sensor/9970/”device,sensor 后面的数值用你自己的替代
  35.     Serial.println("Host: api.yeelink.net");
  36.     Serial.print("Accept: *");
  37.     Serial.print("/");
  38.     Serial.println("*");
  39.     Serial.print("U-ApiKey: ");
  40.     Serial.println("*************");   // 此处用你的APIKEY替代
  41.     Serial.println("Content-Length: 0");
  42.     Serial.println("Connection: close");
  43.     Serial.println();
  44.     }
  45. }
 楼主| 发表于 2014-6-6 15:45:07 | 显示全部楼层
问题出在下面这,但是不会移植
char flag =0;??这句定义字符串类型?
还有下面这段
怎么把引脚和sensor联系起来的呢?想不通
if (flag<7)  // 7改成开关数量
    //get data from server
    getData();
    //put data to server
//     postData(readData());
    if(flag=7) {flag =0;}   // 7改成开关数量
发表于 2014-6-6 16:06:49 | 显示全部楼层
マイナス37度 发表于 2014-6-6 15:45
问题出在下面这,但是不会移植
char flag =0;??这句没看懂
还有下面这段
楼主位的程序是哪里来的?
8楼的又是哪里来的?
楼主位的程序思路是没错的,可能是某些细节没处理好
比如有两个灯,flag应该只有0,1这两个值,但程序中flag++后值一直再增加。
按照我四楼的方法加上一句程序后,监视一下arduino发出的字符串和返回的字符串,才方便分析是哪里出了小问题
 楼主| 发表于 2014-6-6 16:16:39 | 显示全部楼层
i7456 发表于 2014-6-6 16:06
楼主位的程序是哪里来的?
8楼的又是哪里来的?
8楼的那段是从源程序剪的
要移植的源程序地址放到顶楼了
问题应该就出在这段程序上,就像你说的我程序flag飞了
发表于 2014-6-6 16:20:26 | 显示全部楼层
マイナス37度 发表于 2014-6-6 16:16
8楼的那段是从源程序剪的
要移植的源程序地址放到顶楼了
问题应该就出在这段程序上,就像你说的我程序f ...
你说的源程序是什么?
我让你加的那句,目的是flag++后,如果flag的值大于等于2,就让flag等于0,这样flag的值就是0或者1两个状态。
最好等监视下arduino串口发出和收到的字符串,你贴出来看看。
 楼主| 发表于 2014-6-6 16:27:57 | 显示全部楼层
i7456 发表于 2014-6-6 16:20
你说的源程序是什么?
我让你加的那句,目的是flag++后,如果flag的值大于等于2,就让flag等于0,这样 ...
flag应该等于12,13,不是等于1和0
这是我要移植的程序
  1. /*
  2. Yeelink sensor client power switch example
  3. */
  4. #include <SPI.h>  //调用通读接口库
  5. #include <Ethernet.h>  //调用网络模块库
  6. #include <Wire.h>  //调用I2C通讯库
  7. #include <math.h>  //调用函数库
  8. byte buff[2];  //定义缓冲区???不是很明白
  9. float cm;    //浮点型变量???不是很明白
  10. char flag =0;  //定义开关循环控制变量
  11. // for yeelink api
  12. #define APIKEY         "xxxxxxxxxxxxxxxxxxxxxx" // 替换你的 API KEY
  13. #define DEVICEID       136 // 替换你的device ID
  14. String SENSORno[]={"3366","3367","3368","3369","3372","3373","3415"}; // 把sensor ID 依次替在这里,程序定义为数组,几个开关就写几个
  15. //for led pin
  16. byte ledPin[]={A0,A1,A2,A3,5,6,7};   //定义输出的针脚
  17. // assign a MAC address for the ethernet controller.
  18. byte mac[] = { 0x00, 0x1D, 0x72, 0x82, 0x35, 0x9D};
  19. // initialize the library instance:
  20. EthernetClient client;
  21. char server[] = "api.yeelink.net";   // name address for yeelink API
  22. unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
  23. boolean lastConnected = false;                 // state of the connection last time through the main loop
  24. const unsigned long postingInterval = 3*1000; // delay between 2 datapoints, 30s
  25. String returnValue = "";
  26. boolean ResponseBegin = false;
  27. void setup() {
  28. for(int i=0;i<7;i++)       //I<7,几个开关,就把7改成几,其实就是循次数
  29. { pinMode(ledPin,OUTPUT);}
  30.   Wire.begin();
  31.   // start serial port:
  32.   Serial.begin(9600);
  33.   // start the Ethernet connection with DHCP:
  34.   if (Ethernet.begin(mac) == 0) {
  35.     Serial.println("Failed to configure Ethernet using DHCP");
  36.     for(;;)
  37.       ;
  38.   }
  39.   else {
  40.     Serial.println("Ethernet configuration OK");
  41.   }
  42. }
  43. void loop() {
  44. // if there's incoming data from the net connection.
  45.   // send it out the serial port.  This is for debugging
  46.   // purposes only:
  47.   if (client.available()) {
  48.     char c = client.read();
  49.    // Serial.print(c);
  50.       if (c == '{')
  51.         ResponseBegin = true;
  52.       else if (c == '}')
  53.         ResponseBegin = false;
  54.       if (ResponseBegin)
  55.         returnValue += c;
  56.   }
  57.
  58.    if (returnValue.length() !=0 && (ResponseBegin == false))
  59.   {
  60.     Serial.println(returnValue);
  61.      if (returnValue.charAt(returnValue.length() - 1) == '1') {
  62.
  63.       Serial.println("turn on the LED");
  64.     //  digitalWrite( 7, HIGH);
  65.       digitalWrite( ledPin[flag], HIGH);
  66.
  67.     }
  68.       else if(returnValue.charAt(returnValue.length() - 1) == '0') {
  69.       Serial.println("turn off the LED");
  70.     //  digitalWrite(7, LOW);
  71.       digitalWrite( ledPin[flag], LOW);
  72.     }
  73.      returnValue = "";
  74.     flag ++;
  75.   }
  76.
  77. // if there's no net connection, but there was one last time
  78.   // through the loop, then stop the client:
  79.   if (!client.connected() && lastConnected) {
  80.     Serial.println();
  81.     Serial.println("disconnecting.");
  82.     client.stop();
  83.   }
  84.
  85. // if you're not connected, and ten seconds have passed since
  86.   // your last connection, then connect again and send data:
  87.   if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
  88.     // read sensor data, replace with your code
  89.     //int sensorReading = readLightSensor();
  90.     Serial.print("yeelink:");
  91.     if (flag<7)  // 7改成开关数量
  92.   {
  93.     //get data from server
  94.     getData();
  95.   }
  96.   else
  97. {
  98.     //put data to server
  99. //     postData(readData());
  100.     if(flag=7) {flag =0;}   // 7改成开关数量
  101.   }
  102.    // note the time that the connection was made or attempted:
  103.     lastConnectionTime = millis();
  104.   }
  105.   // store the state of the connection for next time through
  106.   // the loop:
  107.   lastConnected = client.connected();
  108.
  109. }
  110. // this method makes a HTTP connection to the server and get data back
  111. void getData(void) {
  112.   // if there's a successful connection:
  113. if (client.connect(server, 80)) {
  114.     Serial.println("connecting...");
  115.     // send the HTTP GET request:
  116.     client.print("GET /v1.0/device/");
  117.     client.print(DEVICEID);
  118.     client.print("/sensor/");
  119. //   client.print(SENSORID);
  120.     client.print(SENSORno[flag]);
  121.     client.print("/datapoints");
  122.     client.println(" HTTP/1.1");
  123.     client.println("Host: api.yeelink.net");
  124.     client.print("Accept: *");
  125.     client.print("/");
  126.     client.println("*");
  127.     client.print("U-ApiKey: ");
  128.     client.println(APIKEY);
  129.     client.println("Content-Length: 0");
  130.     client.println("Connection: close");
  131.     client.println();
  132.     Serial.println("print get done.");
  133.      }
  134.   else
  135.   {
  136.     // if you couldn't make a connection:
  137.     Serial.println("connection failed");
  138.     Serial.println();
  139.     Serial.println("disconnecting.");
  140.     client.stop();
  141.     }
  142.      // note the time that the connection was made or attempted:
  143.    //  lastConnectionTime = millis();
  144.   lastConnectionTime = millis();
  145. }
 楼主| 发表于 2014-6-6 16:34:30 | 显示全部楼层
串口发出的就是Serial括号里那些呗,至于收到的占时不知道怎么监控
发表于 2014-6-6 17:06:58 | 显示全部楼层
这是我要移植的程序
对于楼主位的程序来说,flag的目的值指定两个数组的组元,因为只有两个组元,所以flag的值应该是0,1。
发表于 2014-6-6 17:10:09 | 显示全部楼层
可以单独用一个USB转串口模块插在电脑上,只接这个模块上的GND和RX.
这样就可以单独监视arduino发出或者收到的字符串了。
“串口发出的就是Serial括号里那些呗”    这样想当然的想法,玩编程是不好的,要得的细心和准确的结果。
GMT+8, 2024-5-23 07:49 , Processed in 0.052954 second(s), 18 queries .
