楼主 |
发表于 2014-6-13 08:45:19
显示全部楼层
- #include <SPI.h>
- #include <Ethernet.h>
- int LCD1602_RS=12;
- int LCD1602_RW=11;
- int LCD1602_EN=10;
- int DB[] = { 6, 7, 8, 9};
- char str1[]="Welcome to";
- char str2[]="geek-workshop";
- byte mac[] = {
- 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
- // Initialize the Ethernet client library
- // with the IP address and port of the server
- // that you want to connect to (port 80 is default for HTTP):
- EthernetClient client;
- void LCD_Command_Write(int command)
- int i,temp;
- digitalWrite( LCD1602_RS,LOW);
- digitalWrite( LCD1602_RW,LOW);
- digitalWrite( LCD1602_EN,LOW);
- temp=command & 0xf0;
- for (i=DB[0]; i <= 9; i++)
- digitalWrite(i,temp & 0x80);
- temp <<= 1;
- digitalWrite( LCD1602_EN,HIGH);
- delayMicroseconds(1);
- temp=(command & 0x0f)<<4;
- temp <<= 1;
- void LCD_Data_Write(int dat)
- int i=0,temp;
- digitalWrite( LCD1602_RS,HIGH);
- temp=dat & 0xf0;
- temp <<= 1;
- temp=(dat & 0x0f)<<4;
- temp <<= 1;
- void LCD_SET_XY( int x, int y )
- int address;
- if (y ==0) address = 0x80 + x;
- else address = 0xC0 + x;
- LCD_Command_Write(address);
- void LCD_Write_Char( int x,int y,int dat)
- LCD_SET_XY( x, y );
- LCD_Data_Write(dat);
- void LCD_Write_String(int X,int Y,char *s)
- LCD_SET_XY( X, Y ); //设置地址
- while (*s) //写字符串
- LCD_Data_Write(*s);
- s ++;
- void setup (void)
- Serial.begin(9600);
- if (Ethernet.begin(mac) == 0) {
- Serial.println("Failed to configure Ethernet using DHCP");
- // no point in carrying on, so do nothing forevermore:
- for(;;)
- Serial.print("My IP address: ");
- for (byte thisByte = 0; thisByte < 4; thisByte++) {
- // print the value of each byte of the IP address:
- Serial.print(Ethernet.localIP()[thisByte], DEC);
- Serial.print(".");
- Serial.println();
- int i = 0;
- for (i=6; i <= 12; i++)
- pinMode(i,OUTPUT);
- delay(100);
- LCD_Command_Write(0x28);//4线 2行 5x7
- delay(50);
- LCD_Command_Write(0x06);
- delay(50);
- LCD_Command_Write(0x0c);
- delay(50);
- LCD_Command_Write(0x80);
- delay(50);
- LCD_Command_Write(0x01);
- delay(50);
- // this check is only needed on the Leonardo:
- // start the Ethernet connection:
- // print your local IP address:
- void loop (void)
- delay(50);
- LCD_Write_String(3,0,str1);//第1行,第4个地址起
- delay(50);
- LCD_Write_String(1,1,str2);//第2行,第2个地址起
- delay(5000);
复制代码 这是加了DHCP获取的代码。好像就不太行了,不过DHCP地址能获取到,我能从COM monitor中看到地址。不过老实讲,即使LCD,能显示,我也不知道如何将
转换显示到LCD上。呵呵。。有做过这个吗? |
