查看: 10764|回复: 0
本人是初学者,想请教各位一个问题:如何用GPRS模块发送GPS的数据到yeelink上?
发表于 2014-8-23 15:47:28 | 显示全部楼层 |阅读模式
下面的代码是发送普通数值的。(发送普通数值和发送GPS定位的数据有什么区别!?{:soso_e154:} )
#include <stdio.h>
#include <math.h>
  int i;
  int len;
  int times;
  int temp;
  int t;
  char xinlv;
   char post[]={//提交数据包
    "OST /v1.0/device/12797/sensor/aaaaa/datapoints HTTP/1.1\r\n"
    "Host: api.yeelink.net\r\n"
    "Accept: */*\r\n"
    "U-ApiKey:587407b0532721175514efd429f5dc98\r\n"
    "Content-Length: dt\r\n"
    "Content-Type: application/x-www-form-urlencoded\r\n"
    "Connection: close\r\n"
    "\r\n"
   "{\"value\":xxxxxx}\r\n"
       };//xx用来填充数值
    char post_reserve[]={//提交数据包
    "Accept: */*\r\n"
    "U-ApiKey: 587407b0532721175514efd429f5dc98\r\n"
    "\r\n"
       };//xx用来填充数值
char xinlv_sensor_id[]={"21121"};
/////1
void post_xinlv() //发送温度数据
{  connect();
   len=strlen(post);
    for(times=0;times<len;times++)
       if(post[times]=='a'&&post[times+1]=='a'&&post[times+2]=='a')
           post[times]=xinlv_sensor_id[0];
          post[times+1]=xinlv_sensor_id[1];
          post[times+2]=xinlv_sensor_id[2];
          post[times+3]=xinlv_sensor_id[3];
          post[times+4]=xinlv_sensor_id[4];
    temp=0;
    len=strlen(post);
   temp=Serial.print(xinlv,1);
        if(post[times]=='d'&&post[times+1]=='t')
               post[times]=(temp+10)/10+0x30;
              post[times+1]=(temp+10)%10+0x30;
   for(times=0;times<len;times++)//填改传感器数值,发送报文
       if(post[times]=='x'&&post[times+1]=='x'&&post[times+2]=='x')
              Serial1.print(xinlv,1);
              times=times+6;
        Serial1.print(post[times]);
    Serial1.write(26);//send order
      delay(3000);
     close();
      post[times]=post_reserve[times];
////////2
   Serial1.begin(115200);
   xinlv=0;
//   xinlv=xinlv+5;
//  if(xinlv==55)
// {xinlv=0; }
  post_xinlv();
delay(1000);
void connect()//TCP连接
  int i;
//  Serial1.print("ati\r\n");
//   delay(1000);
//   delay(1000);
   delay(1000);
    delay(500);
  Serial1.print("AT+CGCLASS=\"B\"\r\n");
   delay(500);
  Serial1.print("AT+CGDCONT=1,\"IP\",\"CMNET\"\r\n");
   delay(500);
  Serial1.print("AT+CGATT=1\r\n");
   delay(500);
  Serial1.print("AT+CIPCSGP=1,\"CMNET\"\r\n"); //uninet
   delay(500);
  Serial1.print("AT+CLPORT=\"TCP\",\"2000\"\r\n");
   delay(500);
  Serial1.print("AT+CIPSTART=\"TCP\",\"42.96.164.52\",\"80\"\r\n"); //the ip addr to yeelink
  delay(500);
   for(i=0;i<=3;i++)
  delay(1000);
  Serial1.print("AT+CIPSEND\r\n");
   delay(500);
void close()//结束TCP连接
  Serial1.print("AT+CIPCLOSE=1\r\n");
   delay(500);
  Serial1.print("AT+CIPSHUT\r\n");
   delay(500);
GMT+8, 2024-5-5 01:02 , Processed in 0.040816 second(s), 17 queries .
