查看: 19378|回复: 14
请问下关于树莓派MYSQL局域网访问的问题
发表于 2014-8-26 14:42:47 | 显示全部楼层 |阅读模式
MYSQL用户IP已经修改为% 但是局域网访问不了 是不是防火墙的问题 我参考过debian关闭防火墙的命令 提示没有这个服务什么的
发表于 2014-8-26 20:38:42 | 显示全部楼层
本机能访问么?
我印象中raspbian是没有防火墙的,随便一个端口开了就可以访问
 楼主| 发表于 2014-8-26 22:22:48 | 显示全部楼层
本机是可以访问的
 楼主| 发表于 2014-8-26 22:25:41 | 显示全部楼层
wing 发表于 2014-8-26 20:38
本机能访问么?
本机可以访问 本机登陆的时候我就把ROOT的IP改为%  没用 然后又新建了一个用户 改%也没用
发表于 2014-8-27 12:21:15 | 显示全部楼层
那就奇异果了,你不如指定一个内网IP然后试下能不能访问
 楼主| 发表于 2014-8-27 12:32:34 | 显示全部楼层
也试过了 也连不上
 楼主| 发表于 2014-8-27 13:00:52 | 显示全部楼层
iptables v1.4.14
Usage: iptables -[ACD] chain rule-specification [options]
       iptables -I chain [rulenum] rule-specification [options]
       iptables -R chain rulenum rule-specification [options]
       iptables -D chain rulenum [options]
       iptables -[LS] [chain [rulenum]] [options]
       iptables -[FZ] [chain] [options]
       iptables -[NX] chain
       iptables -E old-chain-name new-chain-name
       iptables -P chain target [options]
       iptables -h (print this help information)
Commands:
Either long or short options are allowed.
  --append  -A chain            Append to chain
  --check   -C chain            Check for the existence of a rule
  --delete  -D chain            Delete matching rule from chain
  --delete  -D chain rulenum
                                Delete rule rulenum (1 = first) from chain
  --insert  -I chain [rulenum]
                                Insert in chain as rulenum (default 1=first)
  --replace -R chain rulenum
                                Replace rule rulenum (1 = first) in chain
  --list    -L [chain [rulenum]]
                                List the rules in a chain or all chains
  --list-rules -S [chain [rulenum]]
                                Print the rules in a chain or all chains
  --flush   -F [chain]          Delete all rules in  chain or all chains
  --zero    -Z [chain [rulenum]]
                                Zero counters in chain or all chains
  --new     -N chain            Create a new user-defined chain
  --delete-chain
            -X [chain]          Delete a user-defined chain
  --policy  -P chain target
                                Change policy on chain to target
  --rename-chain
            -E old-chain new-chain
                                Change chain name, (moving any references)
Options:
    --ipv4      -4              Nothing (line is ignored by ip6tables-restore)
    --ipv6      -6              Error (line is ignored by iptables-restore)
[!] --proto     -p proto        protocol: by number or name, eg. `tcp'
[!] --source    -s address[/mask][...]
                                source specification
[!] --destination -d address[/mask][...]
                                destination specification
[!] --in-interface -i input name[+]
                                network interface name ([+] for wildcard)
--jump -j target
                                target for rule (may load target extension)
  --goto      -g chain
                              jump to chain with no return
  --match       -m match
                                extended match (may load extension)
  --numeric     -n              numeric output of addresses and ports
[!] --out-interface -o output name[+]
  --table       -t table        table to manipulate (default: `filter')
  --verbose     -v              verbose mode
  --line-numbers                print line numbers when listing
  --exact       -x              expand numbers (display exact values)
[!] --fragment  -f              match second or further fragments only
  --modprobe=<command>          try to insert modules using this command
  --set-counters PKTS BYTES     set the counter during insert/append
[!] --version   -V              print package version.
 楼主| 发表于 2014-8-27 13:01:39 | 显示全部楼层
这个是树莓派上的防火墙帮助内容 实在看不懂不会用 高手帮忙指导一下 可以让我局域网连上MYSQL
发表于 2014-8-27 23:31:28 | 显示全部楼层
我之前在RPI上写的http服务程序是不需要对网络进行特别设置就可以被局域网访问的,但是当时我用的是root来运行的。
我见其他人都是把root和mysql两个用户都设置为%的,
不知道会不会和运行mysql的用户有关
发表于 2014-8-28 00:01:13 | 显示全部楼层
至于那个iptables的问题嘛,我以为所有RPI是无规则的,至少默认情况下是没有,这个我回头确认下...
不过你也可以看看你的机器是不设置了规则
查看规则的命令是
iptables -L -n
然后清除所有规则的命令是
iptables -F
保存命令好像是.....save,但是我记不住那个该死的配置文件的位置,这个你可以上网查下。
最后通常都要重启服务才生效的
service iptables restart
发表于 2014-8-28 00:17:24 | 显示全部楼层
嗯...查过了,我的RPI是这样的
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
没有firewall的哟,印象中我没改过规则的,这个应该就是原来的样子。
发表于 2014-8-28 10:59:45 | 显示全部楼层
mysqld 默认监听在 127.0.0.1
看一下配置文件
cat /etc/mysql/my.cnf |grep bind-address
默认应该是
bind-address                = 127.0.0.1
改为 0.0.0.0
重启服务
然后确认一下绑定的地址
sudo netstat -lntp
有 0.0.0.0:3306 就 ok 了。
不过为了安全性考虑,不建议绑定到所有地址上。默认 127.0.0.1 很好了。如果只是为了管理需要,可以通过 ssh 通道连接。
 楼主| 发表于 2014-8-28 12:37:54 | 显示全部楼层
用了贱客的方法连上了  非常感谢两位的热心帮助
发表于 2014-8-29 12:39:34 | 显示全部楼层
呵呵~~~
终于等到高手出现了,
我也受教啦,感谢感谢
发表于 2014-9-10 19:46:35 | 显示全部楼层
我在树梅派派上安装好mysql之后怎么都启动失败,大家有什么解决办法没有?
GMT+8, 2024-5-10 23:14 , Processed in 0.040586 second(s), 20 queries .
