- // -*- c++ -*-
- // Copyright 2010 Ovidiu Predescu <[email protected]>
- // Date: December 2010
- // Updated: 08-JAN-2012 for Arduno IDE 1.0 by <[email protected]>
- #include <pins_arduino.h>
- #include <SPI.h>
- #include <Ethernet.h>
- #include <Flash.h>
- #include <SD.h>
- #include <TinyWebServer.h>
- #include <Adafruit_VC0706.h>
- #include <SoftwareSerial.h>
- /****************VALUES YOU CHANGE*************/
- // The LED attached to PIN X on an Arduino board.
- const int LEDPIN = 7;
- // pin 4 is the SPI select pin for the SDcard
- const int SD_CS = 4;
- // pin 10 is the SPI select pin for the Ethernet
- const int ETHER_CS = 10;
- // Don't forget to modify the IP to an available one on your home network
- byte ip[] = { 192, 168, 1, 177 };
- static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
- // The initial state of the LED
- int ledState = LOW;
- SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
- Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
- boolean has_cam=false;
- void setLedEnabled(boolean state) {
- ledState = state;
- digitalWrite(LEDPIN, ledState);
- inline boolean getLedState() { return ledState; }
- boolean file_handler(TinyWebServer& web_server);
- boolean blink_led_handler(TinyWebServer& web_server);
- boolean led_status_handler(TinyWebServer& web_server);
- boolean index_handler(TinyWebServer& web_server);
- TinyWebServer::PathHandler handlers[] = {
- // Work around Arduino's IDE preprocessor bug in handling /* inside
- // strings.
- // `put_handler' is defined in TinyWebServer
- {"/", TinyWebServer::GET, &index_handler },
- {"/upload/" "*", TinyWebServer::PUT, &TinyWebPutHandler::put_handler },
- {"/blinkled", TinyWebServer::POST, &blink_led_handler },
- {"/ledstatus" "*", TinyWebServer::GET, &led_status_handler },
- {"/" "*", TinyWebServer::GET, &file_handler },
- {NULL},
- const char* headers[] = {
- "Content-Length",
- NULL
- TinyWebServer web = TinyWebServer(handlers, headers);
- boolean has_filesystem = true;
- Sd2Card card;
- SdVolume volume;
- SdFile root;
- SdFile file;
- SdFile imgFile;
- uint16_t jpglen;
- int32_t time;
- byte wCount;
- boolean WriteFileing=false;
- char Filenamenow[13];
- void send_file_name(TinyWebServer& web_server, const char* filename) {
- if (!filename) {
- web_server.send_error_code(404);
- web_server << F("Could not parse URL");
- } else {
- TinyWebServer::MimeType mime_type
- = TinyWebServer::get_mime_type_from_filename(filename);
- web_server.send_error_code(200);
- web_server.send_content_type(mime_type);
- web_server.end_headers();
- if (file.open(&root, filename, O_READ)) {
- Serial << F("Read file "); Serial.println(filename);
- web_server.send_file(file);
- file.close();
- } else {
- web_server << F("Could not find file: ") << filename << "\n";
- boolean file_handler(TinyWebServer& web_server) {
- char* filename = TinyWebServer::get_file_from_path(web_server.get_path());
- send_file_name(web_server, filename);
- free(filename);
- return true;
- boolean blink_led_handler(TinyWebServer& web_server) {
- web_server.send_content_type("text/plain");
- // Reverse the state of the LED.
- setLedEnabled(!getLedState());
- Client& client = web_server.get_client();
- if (client.available()) {
- char ch = (char)client.read();
- if (ch == '0') {
- setLedEnabled(false);
- } else if (ch == '1') {
- setLedEnabled(true);
- PicSave();
- return true;
- boolean led_status_handler(TinyWebServer& web_server) {
- client.println(getLedState(), DEC);
- return true;
- boolean index_handler(TinyWebServer& web_server) {
- send_file_name(web_server, "INDEX.HTM");
- return true;
- void file_uploader_handler(TinyWebServer& web_server,
- TinyWebPutHandler::PutAction action,
- char* buffer, int size) {
- static uint32_t start_time;
- static uint32_t total_size;
- switch (action) {
- case TinyWebPutHandler::START:
- start_time = millis();
- total_size = 0;
- if (!file.isOpen()) {
- // File is not opened, create it. First obtain the desired name
- // from the request path.
- char* fname = web_server.get_file_from_path(web_server.get_path());
- if (fname) {
- Serial << F("Creating ") << fname << "\n";
- file.open(&root, fname, O_CREAT | O_WRITE | O_TRUNC);
- free(fname);
- break;
- case TinyWebPutHandler::WRITE:
- if (file.isOpen()) {
- file.write(buffer, size);
- total_size += size;
- break;
- case TinyWebPutHandler::END:
- file.sync();
- Serial << F("Wrote ") << file.fileSize() << F(" bytes in ")
- << millis() - start_time << F(" millis (received ")
- << total_size << F(" bytes)\n");
- file.close();
- void setup() {
- Serial.begin(9600);
- Serial << F("Free RAM: ") << FreeRam() << "\n";
- pinMode(LEDPIN, OUTPUT);
- pinMode(SS_PIN, OUTPUT); // set the SS pin as an output
- // (necessary to keep the board as
- // master and not SPI slave)
- digitalWrite(SS_PIN, HIGH); // and ensure SS is high
- // Ensure we are in a consistent state after power-up or a reset
- // button These pins are standard for the Arduino w5100 Rev 3
- // ethernet board They may need to be re-jigged for different boards
- pinMode(ETHER_CS, OUTPUT); // Set the CS pin as an output
- digitalWrite(ETHER_CS, HIGH); // Turn off the W5100 chip! (wait for
- // configuration)
- pinMode(SD_CS, OUTPUT); // Set the SDcard CS pin as an output
- digitalWrite(SD_CS, HIGH); // Turn off the SD card! (wait for
- // configuration)
- // initialize the SD card.
- Serial << F("Setting up SD card...\n");
- // Pass over the speed and Chip select for the SD card
- if (!card.init(SPI_FULL_SPEED, SD_CS)) {
- Serial << F("card failed\n");
- has_filesystem = false;
- // initialize a FAT volume.
- if (!volume.init(&card)) {
- Serial << F("vol.init failed!\n");
- if (!root.openRoot(&volume)) {
- Serial << F("openRoot failed");
- if (has_filesystem) {
- // Assign our function to `upload_handler_fn'.
- TinyWebPutHandler::put_handler_fn = file_uploader_handler;
- if(initCam()>0)
- has_cam=true;
- // Initialize the Ethernet.
- // Serial << F("Setting up the Ethernet card...\n");
- Ethernet.begin(mac, ip);
- // Start the web server.
- // Serial << F("Web server starting...\n");
- web.begin();
- Serial << F("Ready to accept HTTP requests.\n");
- void loop() {
- web.process();
- Writefiles();
- uint8_t initCam()
- if (!cam.begin()) {
- // serial.println("Camera Found:");
- //} else {
- Serial.println("No camera found?");
- return 0;
- // Print out the camera version information (optional)
- // char *reply = cam.getVersion();
- // if (reply == 0) {
- // serial.print("Failed to get version");
- // } //else {
- // serial.println("-----------------");
- // serial.print(reply);
- cam.setImageSize(VC0706_640x480); // biggest
- // serial.print("Image size: ");
- Serial.println("640x480");
- return 1;
- uint8_t PicSave()
- { if(WriteFileing)
- return 0;
- if(has_cam==false)
- return 0;
- if(!cam.takePicture())
- Serial.println("Failed to snap!");
- // else
- // serial.println("Picture taken!");
- // Create an image with the name IMAGExx.JPG
- char filename[13];
- strcpy(filename, "IMAGE00.JPG");
- for (int i = 0; i < 40; i++) {
- filename[5] = '0' + i/10;
- filename[6] = '0' + i%10;
- // create if does not exist, do not open existing, write, sync after write
- if (! checkExists(root,filename)) {
- //*//* if(i==19)
- //* Delxx(20,40);
- //* if(i==39)
- //* Delxx(0,20);
- strcpy(Filenamenow, "IMAGE00.JPG");
- Filenamenow[5] = '0' + i/10;
- Filenamenow[6] = '0' + i%10;
- break;
- // Open the file for writing
- imgFile.open(&root,filename, O_CREAT | O_WRITE);
- // Get the size of the image (frame) taken
- jpglen = cam.frameLength();
- Serial.print("Storing ");
- Serial.print(jpglen, DEC);
- Serial.print(" byte image.");
- time = millis();
- //pinMode(8, OUTPUT);
- // Read all the data up to # bytes!
- wCount = 0; // For counting # of writes
- WriteFileing=true;
- // Serial.println(" ms elapsed");
- return 1;
- void Writefiles()
- if (!WriteFileing)
- return;
- if (jpglen > 0) {
- // read 32 bytes at a time;
- uint8_t *buffer;
- uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
- buffer = cam.readPicture(bytesToRead);
- imgFile.write(buffer, bytesToRead);
- if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
- // serial.print('.');
- wCount = 0;
- //Serial.print("Read ");
- //Serial.print(bytesToRead, DEC);
- //Serial.println(" bytes");
- jpglen -= bytesToRead;
- return;
- imgFile.close();
- time = millis() - time;
- Serial.println("done!");
- Serial.print(time);
- Serial.print(Filenamenow);
- WriteFileing=false;
- boolean checkExists(SdFile& parentDir, char *filePathComponent) {
- SdFile child;
- boolean exists = child.open(parentDir, filePathComponent, O_RDONLY);
- if (exists) {
- child.close();
- return exists;
- void delExists(SdFile& parentDir, char *filePathComponent) {
- SdFile child;
- boolean exists = child.open(parentDir, filePathComponent, O_WRITE);
- if (exists) {
- child.remove();
- child.close();
- Serial.println("del!");
- Serial.println(filePathComponent);
- void Delxx(int starf,int endf)
- for (int i = starf; i < endf; i++) {
- delExists(root,filename);
复制代码 |
