楼主: Ansifa
Arduino学习笔记A12 - 自制Makey模拟触摸键盘(此贴已经过时)
发表于 2016-7-10 15:39:44 | 显示全部楼层
大神!是不是用了Arduino Micro/Leonardo这个硬件就不需要再制作D5 D4 D2的链接了?直接在A0-A5连线出来就好了?
发表于 2016-7-10 18:34:48 | 显示全部楼层
Arduino:1.6.7 (Windows 7), 开发板:"Arduino Nano, ATmega328"
In file included from C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/UsbKeyboard.h:16:0,
                 from C:\Users\YanZhang\AppData\Local\Temp\arduino_1bbf2a828f82fe02335becf7e2a847f2\sketch_jul10a.ino:1:
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:455:26: error: variable 'usbDescriptorDevice' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
char usbDescriptorDevice[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:461:33: error: variable 'usbDescriptorConfiguration' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
char usbDescriptorConfiguration[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:467:29: error: variable 'usbDescriptorHidReport' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
char usbDescriptorHidReport[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:473:27: error: variable 'usbDescriptorString0' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
char usbDescriptorString0[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:479:31: error: variable 'usbDescriptorStringVendor' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
int usbDescriptorStringVendor[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:485:31: error: variable 'usbDescriptorStringDevice' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
int usbDescriptorStringDevice[];
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/usbdrv.h:491:37: error: variable 'usbDescriptorStringSerialNumber' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
int usbDescriptorStringSerialNumber[];
In file included from C:\Users\YanZhang\AppData\Local\Temp\arduino_1bbf2a828f82fe02335becf7e2a847f2\sketch_jul10a.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\arduino_library_UsbKeyboard-master/UsbKeyboard.h:42:39: error: variable 'usbDescriptorHidReport' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
PROGMEM char usbHidReportDescriptor[35] = { /* USB report descriptor */
C:\Users\YanZhang\AppData\Local\Temp\arduino_1bbf2a828f82fe02335becf7e2a847f2\sketch_jul10a.ino: In function 'void loop()':
sketch_jul10a:16: error: 'UsbKeyboard' was not declared in this scope
   UsbKeyboard.update();
exit status 1
  报告将会包含更多的信息
  "在编译时,输出详细信息"
  在 文件>首选项 中启用
发表于 2016-7-10 18:35:02 | 显示全部楼层
谁能帮忙看看出现什么问题了吗
发表于 2016-7-10 18:35:24 | 显示全部楼层
用的是一楼的程序
发表于 2016-9-6 20:27:52 | 显示全部楼层
为什么我弄好了他显示驱动错误?
发表于 2016-9-7 23:11:42 | 显示全部楼层
强帖留名,谢谢分享
发表于 2016-12-26 13:33:26 | 显示全部楼层
受益良多  谢谢
发表于 2017-5-18 13:15:43 | 显示全部楼层
謝謝分享,受益良多。
发表于 2017-10-22 08:37:46 | 显示全部楼层
感谢楼主分享
发表于 2018-6-3 14:19:15 | 显示全部楼层
键盘线如果买的话怎么搜呀
发表于 2018-7-27 09:25:32 | 显示全部楼层
试了,没有效果
GMT+8, 2024-5-11 11:09 , Processed in 0.045409 second(s), 25 queries .
